Question about Cell Phones
The phone is asking me to reboot. Should I? - Cell Phones
How do I factory reboot my phone?
Before beginning, make sure there is power to the phone
1. Go to setttings.
2. go to backup and reset. Depending on which type of samsung this can be found under accounts or "user and backup"
3. Select factory data reset (it may ask to put in pin code)
4. The phone will start the start factory reboot.
Jan 26, 2016 | Samsung Cell Phones
How do i reboot my phone
There is always an option that pops up when you long press the power button in your phone, asking you if you want to reboot or switch off.
Also if you switch off and switch on again its more or less a reboot
Oct 18, 2014 | Cell Phones
My nokia n73 shows memory full close some some application when i use internet my phone memory is already empty pls help me
hi ,
just reset your phone by doing this..with simcard type *#7370 # ,it will asking for locked code ..if not change the default is 12345, enter this then select yes ..it will reboot ,wait until its done and your phone is ok now..
Feb 07, 2011 | Nokia N73 Cellular Phone
IT SAY SIM LOCK AND ASKING THE CODE
This may not work on all Samsung phones!
THIS IS THE TEMP UNLOCK CODE FOR A SAMSUNG PHONE
Do this at your own risk:
Instructions
Press *#06# and write down your IMEI
Unlock Codes
Code 1: *2767*688 then your IMEI and then press #
For example *2767*688352708000828246# (Everything before the / for C225)
Code 2: *0141#
Code 3: 00000000 (8 zero's)
Entering the Codes
1. Switch your phone off. Remove the original SIM card 2. Insert another SIM card from an alternative network. Power up your phone. You should now see the "Wrong Card" message. 3. Type Code 1 into your phone, if this is entered correctly your
phone screen should now turn black and reboot itself. (C225 doesn't go
black but does reboot) 4. After the phone reboots the SIM card will be recognized and your
SIM will work. Be patient while your phone reboots and DO NOT press
any keys. At this point the phone is "Temporarily" unlocked.
5. Now at your idle screen type in Code 2 (*0141#) and hit the call button.
This should give you a message saying the phone is "Personalized". 6. Power off the phone and insert the original SIM, then power up. 7. At the SIM code prompt, it will ask you to enter a password. At
this stage enter Code 3. 8. After entering hit "OK" and your phone should complete initialization.
[/b]Instructions[/b]
Unlock Codes
Code 2: *0141#
Entering the Codes
any keys. At this point the phone is "Temporarily" unlocked. 5. Now at your idle screen type in Code 2 (*0141#) and hit the call button.
Your phone is now Permanently unlocked.
Another easy way is you put in a foreign sim put in the code *2767*2878# much easier and works just the same.
*2767*688 <your IMEI number>
Jan 09, 2010 | Samsung SGH-X820 Phone
Sim problems
when i put sim into phone it ask insert sim
Feb 25, 2009 | Cell Phones
I forget the lock code and when i start my phone it ask me to enter code
ok try following steps:reboot your phone when they getting reboot press = green button(answer key) + 3 star key(*) but befor that make sure that your phone data will be lost above procudere may restore factory settings of your phone
Oct 23, 2008 | Nokia 6600
Sim unlock code needed for Samsung E250
turn phone on with unaccepted sim dont insert the sim fully in the slot insert about half way input *2767*3855# and phone will reboot after reboot input*7465625*638*00000000*00000000# phone will reboot after reboot input #7465625*638*00000000# phone wiil reboot turn off phone and fully insert sim and turn phone back on your should now be unlock to accept sim mine works best of luck
Feb 28, 2008 | Cell Phones
Cell Phones Logo
22 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
