Question about Whirlpool Washing Machines
My whirlpool duet keeps stopping and beeping 5 minutes in. All I can do is shut off the power and star again. How can I fix this?
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Duet Washer
F11 is a serial communications error. This is a symptom of an electronic control board starting to go bad. As defined by the technical information provided by Whirlpool, the error could also be caused by a loose or broken wire connector and/or the central control unit (CCU) (front panel). I would double check all your wire connections leading to the control board and CCU, first. Don't be surprised, however, if the problem persists and you eventually have to replace the electronic control board. To check, follow these steps: 1. Unplug washer. 2. Remove the three screws along the top of the washer in the rear that holds the top panel on. 3. Once the screws are removed the top should slide back then lift up. 4. The electronic control board is gray (or white) in color and located in the rear of the washer. It's impossible to miss. Double check all the connections ONE AT A TIME. 5. Double check the wire harness connections leading to the front panel as well. I hope this resolves your problem, but experience has proven that this is usually an Electronic Control Board failure. It could actually be a combination of the CCU as well. The part numbers are as follows: Electronic Control Board: 959503 Central Control Unit: 1025824 Both boards cost about $150 each. Let me know if this helps you.
Posted on Sep 03, 2007
Master_Tech
  • 770 Answers
SOURCE: Whirlpool Duet dryer error code
E1=Thermistor open
post your email and i will send you the steps to fix and check it too much to type here
Posted on Aug 05, 2008
  • 36 Answers
SOURCE: Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
Posted on Dec 16, 2008
  • 587 Answers
SOURCE: RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Posted on Jun 09, 2009
  • 240 Answers
SOURCE: My Whirlpool duet washer lights flash/beep
probably your door then, look at the door itself, at the latch is it broken? should form a complete square hole with four sides. if broken some part is probably inside lock asm. if complete, look at lock and determine if its in the lock position with door open, a arm will be up preventing the latch from going in. replace as necessary. Old duets (red lights) use standard lock asm same as GE and samsung. New duets (green lights) use whirlpool/new maytag unique asm. New locks come in two interchageable models, German (made in china) and Mexican, Mexican model is more troublesome, get german.
If lights flash during a cycle or other time, its giving a code, note the F code displayed
Posted on Jul 19, 2009
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
My washer will run for a short time and them stop and just beep repeatidly
Frigidaire washer beeps for no reason, driving us crazy ...
? 1:03
https://www.youtube.com/watch?v=gP51k2bhbbg
Nov 6, 2011 - Uploaded by NatalieJonathan
Our Frigidaire washer keeps giving us ridiculous beeping issues, and for no reason. ... Mine stack dryer above ...
My washer pauses during wash cycle and will not restart ...
www.shopyourway.com > Manage My Life > Questions
The washer will stop during wash cycle and just beep. Sometimes we can turn it off and it will run again. Getting worse ... My washer is a Whirlpool 3.5 cu. ft.
FIXED Whirlpool Duet Washer Stops and Beeps - ApplianceBlog
www.applianceblog.com/.../48786-Whirlpool-Duet-Washer-Stops-and-B...
Jan 16, 2015 - 6 posts - ‎2 authors
It's a front loading Whirlpool Duet Washer 4.0 cu ft, with Tumblefresh ... wet it stopswashing and starts beeping (three beeps, pause, three beeps, pause, etc). ... The clip that holds them into the CCU (I think that's the right term) has a ... with my fingers so I could get a couple loads of laundry done until I can .
Jan 05, 2016 | Washing Machines
How do I stop my washing machine door alarm beeping?
do this and fix it. God bless you
However read the instr. manual section troubleshooting /
if doesnot have download from www.fitness.manualsonline.com
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Sep 28, 2012 | Hotpoint WMA74 Front Load Washer
go to instru.manual section troubleshooting and fix it. God bless you
if doesnot have it download from www.fitness.manualsonline.com
However try this.
Sep 28, 2012 | Hotpoint Ultima WF860 Front Load Washer
F8 error code Whirlpool Duet
see this causes and fix it. See yur section troubleshooting in your owner manual, or call some tech.
F8 Board failure Replace control board (also called ERC or clock).
Sep 25, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My front loading washing keeps coming up with f 13 code, what does this mean
This means that the washer has detected a condition it needs to check. Press "Cancel" to clear the display and to stop the beeping sound, then try turning the washer off and on again. If you still see the "F," turn off the power to your washer and wait five minutes before turning it on again. If you hear the beep or see the "F" when you try to washing again, then it need to be troubleshoot.
thanks for using fixya.
Sep 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dryer won't start
whirlpool duet dryer has power but will not start--when I press start, it beeps once and the sensing light comes but the dryer doesn't start
Nov 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
End of Cycle signal keeps beeping
Try pressing "rinse" + "pre-wash" buttons together for over 5 seconds. It will lock. Repeat again for 5 seconds, it will unlock.
Nov 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washer keeps beeping
HATE TO SAY IT BUT THE BOARD WOULD NEED REPLACEMENT.BEEPING NORMALLY INDICATES A FAULT CONDITION WHICH WOULD STOP THE CYCLE(WASH) OR THE COMPLETION OF A CYCLE.
Jun 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
22 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
