Question about Garden
Areins 920013 makes clicking noise when wheels are engaged.
  • 31 Answers
SOURCE: Loud clicking noise when 4wd is engaged on left wheel when turnin
Check your cv (constant velocity joint) , It may have a big clearance which is the source of the noise when turning left or right and when 4wd is engage. Juts like front wheel drive cars, if the cv joint is with clearance it will tend to sound in the left or right turns. It is not exactly clicking sound , nmore like knocking sound , low in pitch, but not heavy.
Posted on Dec 10, 2008
SOURCE: clicking noise from font driver side wheel 4 wheel drive
There is a vacum powered actuator on the front differential housing on the passenger side. It pushes one way for 2WD and the other way for 4WD. If it gets an erratic vacum signal it can cause the clicking as it goes between 2WD and 4WD. It gets it's vacum from two valves mounted on the firewall just behind the battery(to left). The white line feeds manifold vacum to the valves. Check for vacum at white line with engine running. If no vacum there is a break in line from manifold (not likely in this case). If vacum check the pink and blue lines by applying vacum to each one. The vacum should hold. If not check lines from valves to vacum actuator. If both lines hold vacum check valves. Remove electrical connectors from both valves. Connect a wire from one of the terminals of the valve to ground. Touch a wire from the battery + to the other terminal of the valve. Listen for a clicking sound. If no sound valve is bad. Replace valves(s). Also have someone watch position of actuator shaft as you move the selector between 2WD and 4WD. There should be movement. If there is an intermittent problem sometimes it will and other times it won't.
Posted on Jan 08, 2009
lester482529
  • 226 Answers
SOURCE: mowing deck makes ticking noise when blades are engaged.
A FEW THINGS TO LOOK AT ARE ,1THE PULLY SHIELDSMAKE SURE THEY AREN'T BENT TO CLOSE TO THE PULLEY'S.2 THE PULLEY BEARING'S MAY BE WORE OUT AND TO BREAK .3LOOK UNDER THE DECK TO MAKE SURE YOU DIDN'T GET SOMETHING TRAPED IN THE CUTTING DECK.HOPE THIS HELPED.
Posted on Jun 11, 2009
  • 73 Answers
SOURCE: Four wheel drive computer clicks when i try to engage 4x4
tap on the 4wd motor on the transfer case while someone is pushing the button, if engages you need a new motor
Posted on Jul 01, 2009
bikinimechan
  • 220 Answers
SOURCE: when the wheel is turned it makes a clicking noise
That is the distinct sound of your CV joint letting you know it needs replacement. When you order your parts, you might as well order for both sides cause its best to change them both out at the same time.
Posted on May 13, 2010
96lumina 4t60etrans is making clicking noise when wheels turn. It has no rev and to get it to d I have to rock back and forth til engages. Clicking noise coming from inside valve body. suggestions?
clicking noises when wheels are turning normally indicates worn cv joints
as they come out of the transmission it is possible that the noise is transferring to the box
take it to an accredited drive line specialist shop for a proper diagnosis and quote
Jun 22, 2016 | Chevrolet Lumina Cars & Trucks
I have a 2000 ford expedition 4x4 the front right side makes a clicking noise while driving. Any ideas
Clicking Noise From Left Front Tire Area - F150online Forums
www.f150online.com/.../47713-clicking-noise-left-front-tire-area.html
Aug 11, 2001 - I have a clicking type noise comming from the left front tire. It does not ... I can really hear it when I'm driving beside a sound wall or the side of a building. ... the sound. (Yeah right!) ... Almost forgot: 1999 Ford F150 XLT Supercab 5.4 4X4. ... My 2000 4X4 had a ting ting noise coming from the left front wheel. Intermitent Grinding Noise on 2004 F150 4x4 - Page 5
Jan 15, 2010
Popping noise in front end.
Oct 26, 2009
Clicking noise at low speeds.
Aug 7, 2009
Annoying clicking sound in rear of truck?!?!
Jun 8, 2009
More results from www.f150online.com
Jan 05, 2016 | Ford Cars & Trucks
4 wheel won't engage, says it does in the cab, and makes awfull clicking/rattle ing noise when I'm driving
The splines on the drive shaft are probably worn down. See junk yard or dealer for replacemwent.
Dec 06, 2013 | 2004 Ford F150
My 06 Nissan Xterra just started making a loud clicking noise after driving it in 4wd for a short period of time. It seems to come from the front driver side wheel area. The noise lasted for about 2 days...
Have someone check the u joint in the cv shaft for that wheel.. they make a clicking noise when 4wd is engaged.. it puts a load on the shaft.. .. often cheaper to just replace the cv shaft
Jan 23, 2018 | Nissan Xterra Cars & Trucks
What is the horible noise when four wheel drive is engaged?
problem cv joints and or "U" joints and or worn slip joints in drive lines
no make model year listed so impossible to know exactly
Mar 27, 2017 | 2002 Nissan Xterra
Every time i push the button for the four wheel hi it makes the click noise in the front but DOES NOT ENGAGE. only the back tire spins
Depending on the year, it is not posted, it may be a bad transfer case motor. The clicking you are hearing is the motor trying to engage transfer case & front axle. It looks like a windshield wiper motor & when it gets power & works properly it engages front wheels. Again, depending on the year, may be 4 wheel drive actuator or switches bad on front axle or transfer case.
Jan 17, 2011 | GMC Jimmy Cars & Trucks
Clicking noise when moving
This noise can vary depending where its coming from .If its coming from the front of the chair it could be your front wheels may have bad bearings that make the click each time you move .Or if its coming From the back it could be you break engaging and dis engaging. I would proably look at the casters first .
Good luck .
Jan 13, 2011 | Pride Go Chair Travel Power Chair
I hear a click and engages the vehicle to make a noise
Does your vehicle have wheel covers? Could be a stone inside the cover.
May 02, 2010 | 1991 Mitsubishi Montero
Nov 17, 2008 | 1996 Isuzu Trooper
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
