Question about Exercise & Fitness
My console will not come on
When i turn on the treadmill i hear a click like it is coming on but the console doesn't light up, I thought it might be the fuse, but i can't find the fuse, not sure what else to check.
  • 145 Answers
Hi There....what make and model or treadmill? Safety key is installed?
Posted on Jan 03, 2017
  • 6,694 Answers
If you wish to get some details about treadmill repair and service ; visit the site linked here. Pull up older posts.
Posted on Jan 01, 2017
I moved treadmill to another location and all lights up but when I click start it counts down 3, 2, 1 and then nothing. The tread does not start. Any thoughts on what might be wrong?
Hi There, usually when we move fitness equipment we tend to pull cables loose a bit here or there. Please recheck your connections and if you have troubles you can always email gregATbuyfitnessrepairpartsDOTcom for more help. Good Luck!!
Feb 06, 2016 | Precor TRM 833 Treadmill - P30 Console
Why won't myHealthrider Treadmill console lights up, but belt won't run?
There is something wrong with the panel connection to the belt. Get the panel looked at or buy another treadmill. Everything is made to last a short amount of time these days.
Aug 19, 2014 | HEALTHRIDER Exercise & Fitness
Keypad doesn work
the red light should only blink when it is running. does the incline work? if nothing works most likely a console issue
Aug 11, 2014 | Proform XP 580 Trainer Treadmill
My t3 treadmill doesn't come out of energy saving.
rese the treadmill and try again.
if the problem persist go to the MENU, and turn OFF .
God bless yo
Jan 14, 2013 | Life Fitness T3 Treadmill with TRACK...
My Nordictrack X9i treadmill console says it is operating at speed, however the track is not moving. Occasionally the belt will move for just a moment then it stops.
do you hear the motor running but the belt is not? if it is the belt need tightened or the drive belt may have broken. remove the motor hood to inspect
Aug 23, 2012 | NordicTrack Exercise & Fitness
Motor is not responsive and it read LOW SPEED message and time L51
Double check that all connections are secure, especially the console cable. Unplug and reconnect the console cable to verify.
Make sure the console cable is not pinched or damaged in any way.
Turn the power off, unplug the power cable and wait 60 seconds. Remove the motor cover. Wait until all red LED lights have gone off on the motor control board before proceeding. Next, verify that none of the wires connected to the lower board are loose or disconnected.
Oct 20, 2011 | RTO Sole F80 Treadmill
The power light is on, but the console doesn't light and the motor doesn't start.
hi, please check communication cable from speed controller to console
Jun 29, 2011 | RTO Sole F80 Treadmill
I have a 2yr old A2550 which just recently started showing only demo information. The belt would not come on nor would the key change the system to manual mode. I used information mode just to see if...
When in Demo Mode, the console will go through a repeating lighting pattern. This
mode will only become active when the treadmill is plugged in, the main on/off switch
is turned on, and the safety key is not inserted into the console.
The Demo Mode was added to attract attention to the treadmill while it is on display. By
default, all treadmills with Demo Mode will come with it turned on. Demo Mode can be
turned off at any time.
Method #1 to switch from the Demo Mode:Press and hold the STOP button while inserting the safety key to enter the user
information mode.
Look in the Calories window. When Demo Mode is active, the letter 'd' will
Press the SPEED DOWN button to toggle the mode on and off.
Once the mode is set as desired, remove the safety key.
May 17, 2011 | Nordic Track NordicTrack Treadmill, A2550
Treadmill lights up and goes off
Check the main harness running up to the console through the leg. unplug it and use a volt meter to test the red and black wires. You should have 9-12 vdc if you do and the console is not lighting check that the safety key is in place. If it is and it is still not coming on the console is malfunctioning and would need replaced. If there is no voltage coming through the harness then you will need to check the harness for continuity. If harness tests ok then the controller is malfunctioning and would need replaced.
Jul 26, 2010 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
