Question about Jenn-Air Kitchen Ranges
I have a Jenn-Air Model CVEX4370B Stove top that will heat up and cycles for about 4-5 times, but then cuts off. After some period of time, I can try it again and the same situation happens. Any ideas
SOURCE: Jenn-Air S160
What is 15 year old Jenn air stove, model S 160 worth? It is in good shape and has just recently been checked by SEARS and operates fine. New racks, new knobs, and new broiler pan. Completely cleaned up. Looks like new!
Posted on Oct 17, 2008
SOURCE: Jenn-Air electric stove top - burners/fan won't come on
I had the same problem. Went to an appliance store that carries Jenn Air. Replaced both plug in units. Now they work perfectly and it cost less than $350 total! Good Luck!
Posted on Dec 12, 2008
  • 3 Answers
SOURCE: jenn air cook top
Yes you can. Call Jenn Air ((877) 232-6771) and give them your model number (serial is helpful too). They sent my replacement glass within a week. I have a model JED8430ABD from 2000 and they had the top. Fit perfectly and took about an hour to replace.
To change it out, after unplugging the cooktop, I removed the metal tape connecting the external vent shaft to the blower. Then I just lifted the entire cooktop out up out of the countertop so I could access the screws on the sides of the cooktop (looking at the edges of the new cooktop glass helped me figure out which screws to remove around the edge). Then I removed the 2 screws in the vent area on top (1 black screw on each side). And that released the cooktop glass from the metal box that holds the burners. I then took the rubber rings out of the knob holes so I could put them in the new cooktop (I almost missed that...). Finally, I put the new cooktop glass on, put the screws back in, lowered the cooktop back into the counter, and retaped the blower to the vent shaft. Voila!
I really wouldn't be afraid of doing this yourself if you are handy at all. And it will save you a ton. Good luck.
PS The screws around the perimeter are hexigon shapped, so you can't just use a screwdriver. I found my Black & Decker electric screwdriver had that same shaped hole that it held the bit, so I just pulled out the bit and used the screwdriver that way. Worked like a charm.
Posted on Mar 16, 2009
garing
  • 998 Answers
SOURCE: crack in glass flat top jenn air range
big job... too much money
Posted on Aug 08, 2009
SOURCE: I have a Competence B1180, it cuts out after
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turnig then replace fan. If mains voltage is not present then its the thermal switch.
Posted on Sep 17, 2009
My Jenn Air Electric stove is making a clicking noise. When I put my hand on one of the cook top knobs I can actually feel a vibration when the click occurs. What is this?
Gas stove? LP? It is probably the electric spark ignitor. Many times when you clean the stove top water from the sponge gets below. The water droplets (align mysteriously) make the connection between the wires, and the stove thinks it's supposed to be igniting. When the water evaporates, the switch will work fine again & the clicking should only occur when igniting & then backed off.
This happened to me once before.
Nov 21, 2010 | Jenn-Air 4 in. JEC0536ADS Electric Cooktop
Constant heat not produced on Jenn Air Schott Ceran stove top
It's a piece of ****, replace it the first chance you get.
Dec 26, 2009 | Jenn-Air JED8230 Electric Cooktop
Jenn-air stove Model SCE30600B. Won't heat
check all the wiring at the main bus, and at the board connections could be a bad board
Oct 08, 2009 | Jenn-Air Ovens
APIRIL 28 2006 WE BOUGHT A JENN-AIR COOKTOP 30"BLACK STAINLESS STEEL. WITHIN THAT PERIOD WITH THE WARRENTY, AND EXTENDED WARRENTY I HAD TO HAVE THE LG DUAL BURNER REPLACED 5 TIMES THATS FIVE TIMES...EVERY...
THE STORE I BOUGHT IT AT HONORED THE IN STORE CREDIT AND REPLACED THE STOVE TOP.I HAD TO HAVE IT INSTALLED..BUT THAT DOESNT ANSWER MY QUESTION???? I WANT JENN AIR TO KNOW ABOUT THIS PROB INCASE IT HAPPENS AGAIN. HOW MANY TIMES DO YOU THINK THE STORE WILL REPLACE THE STOVE TOP WITH INFLATION THE WAY IT IS NOW.........TELL JENN AIR MY STORY PLEASE C TOP JEC9530ADS.....
Jan 09, 2009 | Kitchen Ranges
I have a Jenn-air electric stove model S125, which is about 20 yrs old. Lately, the ventilation system quits after about 25 minutes. I usually turn it on manually, but it goes on automatically during...
The answer your provided by email only confirmed what I suspected -- that the vent system was probably overheating and would cut out at a certain point.
Thank you for fast reply. I may have to get a pro to confirm this, as I'm an old lady with NO skills for taking stove apart and installing new vent motor.
Dec 29, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air S160
I did it by mistake. I tried to move the lever over and of course, it didn't open but went to restart. I hit the cancel button and then tried the door again and it opened. Yup, we all here feel likes dorks!
Thank you!
Sep 06, 2008 | Kitchen Ranges
you may have lost a leg of your 240V service. make sure you have 240 to the appliance and then start chasing down where you lost it. there is no onboard trip or reset on this unit
Apr 20, 2008 | Jenn-Air JED8230 Electric Cooktop
Jenn-Air stove locked
Check the trouble shooting section of your owner's manual for your various fault codes. It may point you in the right direction as to your next course of action.
Oct 04, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Kitchen Ranges Logo
32 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
