Question about Fleco Televison & Video
FLECO dvd player codes for universal remotes have a raca universal but cant find this brand code and auto code search isn't working
SOURCE: help with dvd player DRC282 remote code
I purchased this same DVD player (DRC282) and none of my universal remotes worked for it. Since I was lucky enough to buy one without a remote, I ended up purchasing an RCA universal remote (RCR3273). Once again, none of the codes worked so I had to unplug the unit for 5 minutes, then plug it back in and hold the Standby button for 15 seconds to return it to it's factory settings. I manually searched through 71 codes before I found a match but the play, pause, rewind and many other functions failed. I tried again skipping over 71 and found the right code at 115 tries. That one had all the functionality I needed. You should try the same strategy with your Comcast universal remote. Skip the first match and keep going until you hit the second manual match.
Posted on Aug 21, 2008
  • 6 Answers
SOURCE: universal remote codes
I just tried the solution suggested by jcallahan on my Motorola DRC800 remote for my Cyberhome CH-DVD 300. The code that worked was 1023.
Posted on Aug 28, 2008
SOURCE: durabrand dvd player code
Here is the code for the dvd player
0449, 0405, 0446
code for the tv/dvd combo
0189, 0135, 0157, 0153, 0254, 0458, 0217.
website to find the other codes if you need.
http://www.jascoproducts.com/support/download-files/RemoteCode-4-digit.pdf
have a good day walmart shoppers.
Posted on Jan 07, 2009
  • 46 Answers
SOURCE: codes to program a universal remote to this device
You can try the following four digit codes:
0670, 0695, 0873, or 1919.
Posted on Jan 20, 2009
SOURCE: Code to configure the Universal Remote for my Jwin DVD player (VD141)
jWIN products do not have a series of uniformed universal remote codes, therefore, they can not be provided at this time.
Posted on Jan 28, 2009
Need to reprogram GE remote to Samsung tv
GE Universal Remote Codes ' Jasco
https://jascoproducts.com/support/ge-universal-remote-codes
A version 2 through version 4 remote will have a "V2" to "V4" after the model number. ... Program your GE Universal Remote using the correct code list and ...
GE Universal Remote Codes and Instructions ' direcTutor
www.directutor.com/content/ge-universal-remote-instructions
Direct Code Entry for GE remotes with 4 digit codes. 1. ... Press and release the button for the device you are programming (TV, VCR, DVD, etc.). For AUX, press ...
How to Program a Universal Remote - Frontier
internet.frontier.com/resources/how-to/program-a-universal-remote/
Here's how to program universal remotes from RCA and GE: ... with whatever device you're currently attempting to program (i.e. the TV, the DVD player, etc.) ... If you havea V2, V3 or V4 remote and are programming a DVD player, press PLAY ...
How To Program A GE Universal Remote ' Codes For ...
codesforuniversalremotes.com/program-ge-universal-remote/
Feb 03, 2016 | GE Televison & Video
I have a Sony Blu-Ray player and bought a GE universal remote model 24927 and did a auto code search and still dont work
There is no set-up code to Sony blu-ray player with GE URC. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 15, 2014 | Sony Televison & Video
Universal remote
Setup code for RCA DVD playere is 0409
Buy one remote control which have this setup code in its code list. Brand name isn't matter.
Apr 27, 2012 | Televison & Video
I have an rca universal remote and want to control a polaroid DHM-0100 dvd player
The Plaroid brand is not one of the listed brand for this remote. But you can try the Apex (081,082,084,087) or Diamond Vision (131,132,133) codes if those don't work then try the Manual Code Search or Auto code search in the manual link below to see if the codes were also used for another brand. Then use the Code Retrieval to record which code worked if any for that brand. Otherwise the remote doesn't contain the code needed and you will need to try and find a Universal that lists and contians the codes for the Polariod DVD. Learning Remotes can be programmed from the original remote to work when there is no code listed. Hope this was helpful.
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=rca&dv=universalremote&md=rcu410bl&kw=&st=&ar=&dt=&so=&pg=3&file=others/rca/rcu410bl-manual.zip
Mar 14, 2010 | One For All URC4110 Remote Control
Universal remote
You can try a code seach which many universal remotes will do, this may be called auto search, if you have the manual for the RCA see if it is listed, instead of entering a 3 digit code, you cycle through all codes until the correct one responds to the unit you are trying to program.
Feb 12, 2009 | JVC TH-G30 Theater System
Ge universal remote code for mintek dvd players
You most likely will not be able to find a code for it because it is an off brand (not-so-well known brand) and most universals will not have codes for that brand. if your universal remote doesnt have codes for the Mintek brand or has them and they dont work then, sorry that remote will not work for you. you will need to try and get a different one. or try and get the original remote. you can try finding the original remote at ReplacementRemotes.com by typing in the model of the Mintek DVD player. or you can try Ebay.
Dec 22, 2008 | Philips Magnavox Learning Universal Remote
Universal Remote Code for Wharfedale DVD Player DIVX-990USB
You could try the helpline number that generally arrives with a universal remote or alternatively many universal remotes are able to search for a code. Try reading the manual again.
Nov 15, 2017 | Televison & Video
GE Universal Remote Code for my Insignia DVD Player NS-DVD1
if you have already tried "code search" then you may have to return that remote and get a different name brand of universal remote.
May 30, 2008 | GE JASRM24912 Remote Control
Televison & Video Logo
35 people viewed this question
Top Fleco Televison & Video Experts
Are you a Fleco Televison and Video Expert? Answer questions, earn points and help others
