Question about Garden
Petrol pipe attachment within tank on McCulloch 2 Stroke Strimmer
Cabrio 245 strimmer. If the ''oil line'' pipe attaches to the filter within the tank, where does the ''petrol line'' pipe attatch to? Is it just left free?
  • 109 Answers
SOURCE: 2 stroke mixture ratio for strimmer
The basic fuel/oil mix is 50 to 1
Posted on May 06, 2009
  • 27 Answers
SOURCE: do I just fill up my petrol strimmer with petrol,
yes 2 stroke in weedeaters, trimmers, etc, look on the cap, or sticker and see the gas/oil mix ratio
Posted on Jun 10, 2009
moretons
  • 155 Answers
SOURCE: mcculloch strimmer/brush cutter - cuts out when throttle opened
Hi sounds like it could need a diaphram kit in the carby if it has mixture screws one markedl for low speed and one marked h for high speed you can try winding out the low speed screw a bit but if that does not work it will definatly need a kit.
Posted on Jul 25, 2009
  • 3 Answers
SOURCE: Starting problems on a mcCulloch strimmer - How
pls
Posted on Sep 18, 2009
hunter19_46m
  • 7482 Answers
SOURCE: EFCO petrol strimmer - can anyone tell me how to
If you need to clean the filter, remove it from the fuel tank and blow compressed air into it, otherwise you may have to do the following:
Sounds like you will need to clean your carburetor
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 24, 2010
What is the fuel oil ratio per litre for a husqvarna 535rxt strimmer
If it is 2 stroke, take petrol /fuel and mix it with preferably synthetic2 stroke oil.
Ratio is usually 10L petrol mixed with 200 ml or 2 stroke oil, that is the best result, used it on my chainsaw, strimmer, moped, working for years without a glitch.
Jul 20, 2015 | Husqvarna Garden
Strimmer instructions what mix do I use for a bluebird strimmer
Hi Chris the usual mix for any trimmer is 40 parts petrol to 1 part two stroke oil. Each tank of fuel I do usually gets a dribble to make it look slightly pinkish. Not to dark though or it smokes terribly.
Apr 22, 2014 | Garden
Spear & Jackson 33cc Petrol Grass Strimmer SGT33N, black fuel pipe split. How to replace it?
empty the petrol,feed the black line (the fuel intake) into the tank and grab the end of it thats attached to the filter inside the tank. now you can feed a new fuel line through into the tank and reattach to the filter. hopefully this will solve your problem ive just done this but mine still wont start, either flooded or spark plug. by the way i bought mine new and the fuel line was split.
Jun 05, 2013 | Garden
Petrol strimmer,, spark at plug,, petrol & 2
I have a flymo 430 petrol strimmer and cannot start it. ive cleaned the filter, put in new plug it went first time and then stopped and wont start again the plug seems to get wet all the time any ideas
Jul 03, 2011 | McCulloch Heavy Machinery
What is the 2 stroke petrol mix for a garden strimmer, Ryobi 25cc PLT 2543 please?
hi there keithprobert
the ratio to use if using top quality 2 stroke oil is 50:1 that is 20 mills of 2 stroke oil per 1.0 litre of petrol that you mix.
but if not using top quality 2 stroke oil use ratio 25:1 that is 40 mills of 2stroke oil per 1.0 litre of petrol that you mix.
cheers pauly46
dont forget the thumbs rating
Jun 02, 2011 | Garden
I need a user manual for McCulloch strimmer MT270X 28cc Petrol 2 stroke. Have you any idea where I could get one? Thankyou.
try this web sight, it is one of the largest of the on line manuel sights, i make no promises but they have come threw many times in the past.
http://www.manualsonline.com/?src=12022010
May 14, 2011 | Garden
What fuel does my strimmer require - McCulloch 240
Most trimmers require a mix of regular unleaded fuel and two cycle oil...the ratio is usually 50:1...you can purchase the oil in convienient packages that allow you to add the whole package to 1 gallon of fuel to obtain the proper mix
Apr 24, 2011 | McCulloch Trimmer Plus Attachment: Add On...
Fuel mix for ALKO RT250 strimmer
Mix one ounce of 2 cycle oil per quart or 4 ounces of oil per gallon of unleaded gasoline. Hope this helps and best wishes.
Aug 28, 2009 | McCulloch Lawn Care: Trimmer Plus...
Garden Logo
219 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
