Question about Toys
My new litehawk 2 helicopter will not turn left. When I move left it spins out of control. What can I do?
4 Suggested Answers
  • 30 Answers
SOURCE: my helicopter spins to the left
theres trim on the remote just hit the r until it stops spinning to the left and it it spins the right then hit the l
Posted on Jan 07, 2009
jhinsincity
  • 616 Answers
SOURCE: cobra mini helicopter controller range problem
Take it back and get a new one!
Posted on Dec 25, 2009
SOURCE: My new u-control helicopter is experencing spinning
I had the same problem, the helicopter would spin out of control and the trim did not help. I took a closer look and noticed that only the top rotor was turning. I took the bottom off of the round gear box to find a tiny white gear had slipped off the second motor. With a pair of needle nose tweezers I was able to reattach the gear and I was flying in no time.
Posted on Feb 02, 2012
I recently got a DH-1 AeroQuest Mini Helicopter. It was working fine until I crashed it against the wall. So now the top Propeller spins but the bottom propeller does not and the helicopter just spins...
I had the same problem. Bottom blade would not spin. There are 2 shafts that spin 2 gears. The outer shaft that spins the bottom blade has 2 set screws and my set screws got sheered off. I replaced both set screws and everything works now....
Sep 04, 2011 | Toys
SYMA S107 Helicopter. Advertised as 3 channel. Remote has channel marking of A B C, but the switch is only 2 position. How do you achieve 3 channels with only 2 position switch?
This helicopter have 2 channels I see.
Maybe A-B is first position and B-C is secound position channel. Helicopter have not switch ABC, simply turn off and turn on for change channel.
Jan 14, 2011 | SYMA Toys industrial New Syma S107 Mini...
Can't figure out how to change frequency on the S107 copter itself (not the controller). Can someone advise. Thx
Found this for you.
it appears that the helicopter dynamically configures the control channel upon first detection of a signal from a controller. So, If you 1) turn off the helicopter, then 2) turn on the controller, then 3) select the desired channel on the controller, then 4) turn the helicopter back on, then 5) hold the throttle down on the controller, the helicopter will start up (after a slight delay) and be controlled via the new channel.
Jan 04, 2011 | SYMA Toys industrial New Syma S107 Radio...
The helicopter syma s032 not fly, noy function, not syncronize with the remote control. This charging for 90 minutes and the battery of the remote control is new. The helicopter light led is good, to...
0) Obviously, helicopter will operate best when fully charged... if charging light gets brighter when unplugged from helicopter, then it's not at full charge. Charge fully, then allow battery to cool for 10 minutes. Good batteries in remote also.
1) Power on helicopter.
2) Place on level surface and let gyroscopes sync. There is a red light inside the body (NOT the red/blue flasher in the nose) that will blink when you turn helicopter on, and will keep blinking until craft is level and stable for a few seconds, then will stop blinking.
3) Make sure left joystick is all the way down.
4) Power on remote.
5) Throttle up (left joystick) until blades move and then all the way back down.
This should get you flying. Let me know.
hope this helps,
r
Dec 28, 2010 | SYMA Toys industrial Syma S032 Ready to...
Right out of the box yiboo uj 381 r/c helicopter. Copter charged and new batteries in the controller. Lights flash on the copter and flashing light on the controller but nothing happens. what's wrong
did you turn the radio on first. It must be powered up with the throttle stick at minimum. Turn power on and then move stick to maximum and back to minimum. The remote lite should stop flashing and then power on helicopter.
Dec 25, 2010 | Toys
How to change channel/band for cyclone 5009 gyro helicopter?
1. Switch the controller to the desired channel. 2. Turn on the helicopter you want to control. 3. Move the joystick forward and back until the rotors start spinning.
Dec 21, 2010 | Toys
The Esky BELT-CP 450 V2 that I purchased has some issues that I need help on. Questions are as follows. After I plug the battery in and sync the gyro and controller I ease up on that throttle as...
Hi
The one problem with some of these copters on 49MHz and 27Mhz are that the manufacture used a splash technique for the frequency. Meaning there is no frequency separation. If two of you are on 27mhz then neither will work. Same for 49mhz. One 27mhz and 1 49mhz should work OK. Now foreign countries use different frequencies because their cell phones are on 27 mhz and 49mhz. So you may have a problem there.
Aug 12, 2010 | Esky 6-Channel 2.4GHz BELT-CP 450 V2 RC...
How do i fly my spin master air hog rc helicopter all it does is go in circles
If its a Reflex twin rotor Heli use the trim wheel on top to counteract the spin and at least stabilize the craft at hover. Then use the right/left froward backward fans to control flight, (right joystick on the controller). These fans are not very powerful so don't expect alot from them other than turning the craft right left and reverse. Seems there is too much down draft from the rotors to effectively move the Heli forward. Not a real good design. The Sharpshooter is easier to fly but uses the batteries in the controller as a charger so they don't last real long.
Feb 05, 2010 | Spinmaster Air Hogs RC Reflex Micro...
My Havoc Heli is really hard to control and I need help.
You have to keep tapping the right trim button. Keep tapping it until it stops spinning. If the spinning stops and it just turns, Use the the left right moving analog un til it flies straight.
Mar 15, 2009 | Air Hogs Havoc Heli Helicopters
Where can I get copy of instructons - Air SBEGO Mini IR Helicoper
have you made sure that the helicopter is charged completely?
if so when you try to take off if it spins to the left then hit the r trim on the remote and if it spins to the right then hit the l trim on the controller.
honestly all the instructions do is tell you how to put batteries in the controller.
Dec 30, 2008 | Sky I Blade Mini IR Helicopter W/ Remote...
Toys Logo
41 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
