Question about Dishwashers
My litehawk 2 chopper wont turn left. It all works but when i move left the chopper spins out of control.
3 Suggested Answers
SOURCE: fully charged the choppers battery,the
The light will keep flashing unless you are on the correct channel A B or C and you hit the "Light" button on the front of the unit.
As far as the high speed take offs I suggest identifying which A B or C setting is correct for your copter. In order to do this turn off the RC controller. Set the Selector switch to "A" move the left joystick "throttle" half way up and then turn on the power. Assuming that the copter is still ON it will either fire up or do nothing. If it does nothing try the same sequence with the selector switch set to "B" and try again. If nothing try "C".
Now, as far as the rapid accelleration, I read one online comment that indicated that there is some type of "programming" sequence that the unit learns by pushing the left joystick throttle all the way forward and then back to zero when you start to fly it. So after the first "blast off" set the copter back down or even hold it in you hand by grasping the the landing runners and move the throttle forward until the rotor spin up and it lifts off. In your hand it is easier to keep it from going up too quickly.
Posted on Aug 30, 2011
Macmarkus
  • 2605 Answers
SOURCE: Kenmore 665.13762K602 dishwasher had a
Hello Allen, welcome to FixYa.
I understand by reading your post which indicates it is a Kenmore 665.13762K602 dishwasher you appear to have a concern with, specifically the wash motor "humming". I've tried on many occasion to get these things started by turning them and trying to break them loose to no avail.
I would say you are indeed on the right track...the motor is the culprit unfortunately. You can opt to replacing just the motor as you said for around $100 or the entire assembly shown here for around $150-$175, it's your call.
I've attached what I think is a pretty helpful tutorial video clip. I can also offer any guidance if questions arise.
http://www.youtube.com/watch?v=LjRxJy2IUE8&feature=player_embedded#!
I'll watch for your reply and try and help going forward. Good luck and thank you for choosing FixYa and please keep me posted.
Regards,
Macmarkus :)
Posted on Sep 01, 2011
My dragon stinger helicopter wont fly,its only turn around even the throttle stick is totally pull
maybe the battery in the chopper or controler woesn't full, or u should check the chopper if there's any missing pieces. last time mine can't fly and i found out that there's a missing gear. but it's an old one, so i took it apart. good luck:)
Jan 05, 2014 | Toys
How many hours do I charge it
check the instruction book or watch the chopper and the controler carefully and try to find out the change in the color of the led light in the controler and chopper.
Jan 02, 2014 | Spin Master 1001130 Air Hogs - Sharp...
Fully charged the choppers battery,the controller has all new batteries,turned on the chopper power switch,turn on te controller power switch and wait till light stops flashing.push on the power controll...
Aug 21, 2011 | JCPenney Gyropter RC Helicopter
I bought a World Tech Toys ZX-A68690 helicopter and I cant get it to work. I charged the battery pack as outlined in the operation manual. I installed the "AA" Duracel batteries in the...
Try turning the controller power on ( before turning on the chopper) and then quickly moving the left throttle stick up to the fastest setting and then immediately back to the slowest speed setting...The flashing should stop. This calibrates the remote throttle range.
Turn on the helicopter and you should be OK
Jun 01, 2011 | Worldtech Devices Toys
Kitchen aid dishwasher not cleaning dishes well. especially the top rack. practically taken the whole thing apart can't find any clogs.
sounds like you have a broken chopper. have you checked the chopper how far have you taken it apart? if the unit is put back together point all wash arms in the same direction turn the dishwasher on after it has started washing give it about 2-3 minutes open the door and see what wash arm is not moveing. if the upper wash arm is not moveing you need to check the chopper.
Oct 18, 2009 | KitchenAid 24 in. KUDP01DLBS Free-standing...
Shuttle 9094 r/c helicopter spinning on take-off
usually trim adjustments are on the controller... not on the vehicle itself.
a potentiometer os a fancy word for dial adjustment. It wont be a metal screw, but probably a metal square with a plastic looking slot that can be turned. usually white or blue plastic
Dec 22, 2008 | Shuttle 9094 Emax Remote Control...
Rinse arms not spinning
Could be a a couple different issues.. Not filling with enough water or food chopper brokeen or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
Remove lower spray arm and rear water supply tube to upper spray arm. Remove torx screws that secure the sump cover. Remove the rounded cover on the left side to expose the chopper assembly. Inspect for breakage of blockage. There may be an additional plastic screen to remove first.
Jun 10, 2008 | Dishwashers
Ultimate chopper motor not spinning
ik heb een mes van ultimate chopper nodig
Sep 24, 2007 | Ultimate Chopper Food Processor
Kenmore Ultra Wash Dishwasher
Cyber, did you get down to the chopper screen? If that is clogged with gunk it will restrict the flow and the top arm will not spin. Im going to try to attach a pic of the chopper assy and screen. Catriver..post back
Apr 02, 2007 | Kenmore 24 in. 16582 Built-in Dishwasher
Dishwashers Logo
35 people viewed this question
Top Dishwashers Experts
