Question about Grilling
I have a 3 pound bone in pork roast. I want to cook it for 4 hours st 200degF ... how long would I then cook it for if I move the temperature up to 350?
3 Suggested Answers
jerry_kramer
  • 3904 Answers
SOURCE: How long do I cook a 3 lb bone in pork roast and at what temperature
That should take about an hour a pound if you are slow roasting at 275 degrees
Posted on Jan 01, 2015
laura62825
  • 190 Answers
SOURCE: I have an all clad pressure cooker I need to know how long to cook a 5 pound pork roast for pork tocos
Pressure cook the pork for 50-60 minutes at high pressure and use natural pressure release.
Here is my pressure cooker carnitas (pulled pork) recipe - if you're not already following one:
http://www.hippressurecooking.com/carnitas-pulled-pork-mexican-pressure-cooker-recipes/
Ciao,
L
Posted on Feb 13, 2016
I am cooking a pork crown roast for Christmas it says to cook it at 3:50 for 2 hours however I will not be back for 3 to 3 1/2 hours at what temperature should I cook it so that it will turn out well
Hello, Vicki -
I hope you have a meat thermometer.
I suggest you roast the pork at 250 degrees Fahrenheit, so the cooking time will take longer. When you return home, pull the roast out of the oven and insert your meat thermometer. The internal temperature of the meat needs to be between 140-145 degrees F. If it is not, put the pork roast back in the oven and turn the heat up to 350 degrees F. Check the internal meat temperature every 15 min.
You CAN set the cooking temperature even lower to allow for an even longer cooking time. But NEVER set it lower than 200 degrees F.
Note: Be sure to turn your oven off when no longer needed. Plus, allow the meat to rest 10-15 min. before carving.
Dec 24, 2017 | Cooking
Can you tell me how long and at what temperature I need to roast a 9lb. boneless pork loin roast in a Cook Essential roaster oven? Thank you.
Pork should be cooked using the formula;
25mins per pound plus 20mins for medium
35mins per pound plus 20mins for well done.
Dec 22, 2017 | Grilling
How long and what temperature do I roast a 12 lb. boneless pork loan roast?
This cut is long and narrow so cooking it for so many minutes per pound won't work. The best way is to use a probe thermometer. If the skin is on it, score it and pour a full kettle of boiling water over the skin. Pat dry and season it. The skin will come nice and crisp.
Sirloin Pork Roast 4-5 lbs. 145°-160° F. 25-40 min. per lb. Stuffed Pork Loin Chops 11/4-11/2-inches 165° F. Varied (based on type of stuffing) Tenderloin (roast at 425° F.) 1-11/2 lbs. 145°-160° F. 20-35 min. Whole Pork Loin (boneless) 8-10 lbs. 145°-160° F. 8-11 min. per.
Roasted Boneless Pork Loin Recipe - The Spruce
https://www.thespruce.com/roasted-boneless-pork-loin-recipe-995289
Rating: 4 - ‎350 reviews - ‎1 hr. 15 min. - ‎324.9 cal
In a small bowl, combine the oil, garlic, salt, pepper, and herbs and mix until paste forms. Dry the pork loin with paper towels and rub it all over with the seasoning paste. Then set it on a rack in a shallow roasting pan. Insert a meat thermometer on a slight angle into the very center of the roast.‎Herbed Roast Pork Loin · ‎Roast Pork Loin With Apricot ... · ‎Barbecued Pork Loin
Roasted Pork Loin Recipe - Allrecipes.com
allrecipes.com/recipe/21766/roasted-pork-loin/ Rating: 4.4 - ‎895 reviews - ‎1 hr. 20 min. - ‎238 cal
Directions. Preheat oven to 350 degrees F (175 degrees C). Crush garlic with rosemary, salt and pepper, making a paste. Pierce meat with a sharp knife in several places and press the garlic paste into the openings. Place pork loin into oven, turning and basting with pan liquids.‎Roasted Pork Loin Video · ‎Roasted Pork Loin - Printer ... · ‎Roasted Pork Loin Photos
boneless pork loin roast Google Search
https://www.porkcdn.com/sites/porkbeinspired/library/2014/06/2924.pdf
Dec 18, 2017 | Grilling
How long do I cook a boneless pork sirloin end roast 1.710lb
20 - 25 min / pound.
You can use "wine" as a seasoning and onions too.
May 02, 2017 | Grilling
WHAT IS THE LARGEST CENTER CUT PORK ROAST YOU CAN PURCHASE?
Up to about 25 pounds, about 30 minutes per pound or until center reaches 175F
Dec 06, 2016 | Grilling
How long do i cook a 13 lb. turkey and at what oven temperature
What temperature do you cook a 13 pound turkey at?
After about 3 hours, insert an oven-safe thermometer deep into the thigh without touching the bone. Begin checking the turkey for doneness about 30 minutes before the recommended cook time. Your turkey is done when the temperature with a meat thermometer is 180° F in thigh and 165° F in middle or stuffing.
How To Roast a Turkey ' Butterball®
www.butterball.com/how-tos/roast-a-turkey Search for: What temperature do you cook a 13 pound turkey at?
Nov 20, 2016 | Kitchen Appliances - Others
How long should I oven roast a 6.53 boneless pork shoulder roast and at what temperature
Cook at 250 for 4 hours and cover with foil , parchment or even news paper and cook at 250 until it reaches 187 degrees this will melt all fat and connective tissue. Total time will be about 6 to 8 hours.
Mar 02, 2016 | Grilling
How many minutes per pound for a pork roast?
10-12# Boston B @ 300-325 degrees = 4hrs +/- Its all about temperature. Wrap @ 165* internal temp in heavy foil & cook to an internal temp of 195-200*.. remove from oven and let it rest for 30 minutes.. You are done.
Feb 24, 2015 | Grilling
Jan 01, 2015 | Grilling
What temperature to roast a boneless pork loin? No recipe in booklet
Hi there.
Most recipies suggest 350 degrees for a pork loiin, approx 25-30 mins per pound. Once you are near the end of the cooking time check the center of the roast with a meat thermometer. It should read 170-180 degrees to make sure it's thoughly cooked.
And don't forget to let it rest, covered for about 15 mins before slicing so the juices re-distribute.
Dec 29, 2010 | Cuisinart CVR1000
Grilling Logo
108 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
