Question about Dayton Heating & Cooling
We installed a bran new dayton heater and when it starts up it makes a loud noise. It doesn't stay for longa but concerned because we don't know what the problem is.
Therinnaiguy
  • 1420 Answers
SOURCE: Loud Knocking
If the noise is not coming from the fan as Buffalo suggests, it is most likely the expansion and contraction of the heat exchanger. The old school way to lessen the noise of expansion is to bank the combustion chamber with a hammer. I don't recommend it today because the metal is so thin (thus all the noise) and you may damage it. You will get used to it and the noise may soften the more it is used. You will never get it to stop.
Posted on Dec 04, 2007
Buffalo12980
  • 625 Answers
SOURCE: buzzing noise - loud
check for dirt in the air gap that is formed between the electromagnet and the contact form. if there are any shading coils on the magnet check for a broken one.
Posted on Dec 31, 2007
billyvangogh
  • 108 Answers
SOURCE: I have Dayton space heater 3E 229, pilot wont stay
The thermocouple is likely defective...(Copper wire heated by the pilot) or the pilot itself is too small or dirty....the pilot must be BLUE , not yellow like a candle...and it must envelop the top portion of the thermocouple....you could also have an auxiliary limit or ECO wired in series with the thermocouple circuit that could be open.....also make sure the thermocouple is inserted all the way and is in the pilot flame as mentioned above
Posted on Oct 25, 2009
Testimonial: "Thank you for the feed back, do I have to remove the entire side panel in order to replace the thermocoupler?"
Therinnaiguy
  • 1420 Answers
SOURCE: My dayton NG heater fan will not shut off properly
Sounds like a bad fan switch. The switch is located on the heat exchanger and is 110 volt bi-metal switch. Follow the wires from the blower going back to the heatexchanger. Graingers can get you a new switch if you give them your model number. www.grainger.com.
Posted on Dec 12, 2009
SOURCE: Dayton Model 1VNX5 Kerosene clicks like crazy but won't light
I have the same heater with the same problem. I took the top cover off, removed the ignitor and bent the probes slightly closer. Use two needle nose to prevent breakage of the holder. It has been working fine since.
Posted on Jan 31, 2010
When I go at about 40miles(speed ) it's a loud the gears don't stick but the higher the speed the louder it get's need to kind of know what to tell a mechanic is to where to start to look.I doesn't
I would suspect it is a wheel bearing issue, if it sounds similar to a baseball card in the spokes of a bicycle, stays somewhat same pitch just louder with speed that is where I would look. Does noise go away or change when making turns?
Nov 08, 2011 | Hyundai Motor 2002 Sonata
Dyson DC17 making loud noise
Hi Liz,
I'm sorry to hear that you're concerned about the noise your DC17 is making. It will be difficult for us to help without hearing the noise, so it's probably best if you get in touch with us directly. One of our Helpline experts will be able to determine the cause of the issue, and will be able to recommend the best course of action.
You can call us free on 1866MYDYSON, or email askdysonUS@dyson.com. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Oct 27, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
There is a loud noise while going through final stages of wash. Sounds like pump motor whineing.
Hello
When an appliance such as a dishwasher starts making a new noise, you need to isolate the cause of the noise so that you know whether or not it is damaging the machine. Several things can cause a noisy dishwasher.
Motor
Dishwashers are driven by an internal motor that gets quite noisy when defective. The problem occurs when a seal breaks down and allows water to access the bearings in the motor, removing the grease needed for proper lubrication and creating a loud motor noise when the dishwasher runs. The seal or bearings need to be replaced in this situation quickly or more extensive damage to the motor may occur.
Inlet Valve
If the inlet valve on your dishwasher is broken or breaking, you will hear a distinctive thumping or clattering noise whenever a load is run. A thumping noise doesn't always indicate this problem, however, depending on when you hear it. If you hear a noise like this when the water is filling up the dishwasher at the start of the cycle, the noise likely points to an inlet valve problem.
Squealing
A high-pitched squealing noise is an indication that something is wrong with the fan. Fan bearings that are worn out indicate that the fan apparatus needs to be replaced. If the noise you're hearing is in fact coming from the fan, it will only occur when the dishwasher is drying the dishes. Dishwashers use a fan to generate and distribute heat to dry the dishes quickly.
Minor Concerns
Sometimes even a minor concern can cause a great deal of noise. The thing to watch for is whether or not the noise repeats itself on multiple loads. A loud noise on a single load that doesn't repeat could be caused by things like a loose utensil or small implement rattling around loose in the dishwasher. Also inspect the bottom of your dishwasher. Hardened bits of old food can become rock hard under the heat in the dishwasher and cause noise when the unit runs.
Sep 11, 2011 | Fisher and Paykel 23 in. DD603H SS...
Just bought a Dayton electric heater to heat a 12' X 20' greenhouse in October. When the heater comes on it now makes a loud sound as if the fan is hitting something. I have it mounted horizonally near...
If it sounds like the fan is hitting something, It is likely you will have to get a step ladder, and look closely at what is making the noise-
Likely something fell in there-- and needs to be removed.
When you shut the thermostat down, does the fan stop instantly?
Mack B
Dec 28, 2010 | Dayton Electric Heater
My Dayton Gas Unit heater will not stay on. The
Have you tried the flue vent? If not, an easy way to check this would be to take the vent pipe off of the unit and see if it continues to have the problem. In most cases, this happens when you have blocked return air or dirty filters, flue blocked, or induction is blocked from switch or housing. One other possibility would be a dirty/clogged a coil which isn't allowing sufficient air to push out causing the limit to trip. I hope this helps somewhat.
Feb 06, 2010 | Dayton Gas Furnace Heater
Dec 13, 2009 | Dayton Heating & Cooling
Dec 12, 2009 | Dayton Heating & Cooling
I have Dayton space heater 3E 229, pilot wont stay on,I have install new gas operating valve and checked transformer ( 30V) . Pilot lights up but wont stay on even if I hold button down for 2-3 min. please...
Oct 25, 2009 | Dayton Gas Furnace Heater
150,000btu Dayton htr (torpedo) lights, runs10 min fine, then shuts off
check for proper pump pressure. Restricted fuel flow. Proper venting of fuel cap.
Feb 19, 2008 | Dayton E52 Utility Heater
Buzzing noise - loud
Dec 30, 2007 | Dayton U33/U32 Utility Heater
Heating & Cooling Logo
Top Dayton Heating & Cooling Experts
paulcarew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
