Question about Danby Freezers
Is a cover recommended as an insulator for Danby freezer
What makes it sweat on the sides of the freezer
The insulation inside the walls is deteriorating, or you have a very high moisture atmosphere in the room where it is.
If the freezer is in a garage or not in a setting where looks is important, you can glue polystyrene insulation on the side of it. If it is in view, you need a new one.
Oct 06, 2016 | Danby Freezers
I need a key for our Danby Freezer. D725-6. Could you help me please.
Go to the Danby website at www.danby.com/customer service/buy parts. You could also call 800-496-6049 for replacement parts not covered by warranty. If you haven't registered your freezer with the company, you may have to register at this point to get any help. Good luck.
Feb 27, 2015 | Danby Freezers
Change defrost thermostat on model dff9102w
Danby, has recall on defrost timer . please try that on ,if still you like to change defrost thermostat open the back cover in freezer you can seeit
Nov 07, 2014 | Danby DFF9102W Mid-Size Refrigerator White
Danby DUF408WE Upright Freezer not working
Does the compressor feel warm to the touch. If it does, it will be proof that the thermostat is calling for cooling and is probably good. For the obvious questions: Is the freezer in an area below 80 degrees F, is the wall outlet in good shape and not hot to the touch, is the freezer plug not blistered around the prongs, is the door gasket against the face all the way around the mating surface on the chasis. If the compressor is hot, listen for a click every 2 to 5 minutes. If the click is present the starter is your last best hope. The click is the compressor trying to start. Without the proper tools you are pretty much up against a wall. One last suggestion is to check for loose wires under the compressor terminal cover. I would suggest you look up the compressor manufacturer for a visual on cover removal. Dont forget to unplug before attempting compressor cover work. I hope you havent tried to put screws through the outside walls of this freezer or damaged the shelves inside. Both are fatal for the freezer and no repair can be made. Good luck.
Jun 03, 2012 | Danby DUF408WE Upright Freezer
FREEZER NOT FREEZING CONTENTS
I have a similar problem with danby and have been unable to get help - I now HATE Danby Chest Freezers
Mar 10, 2009 | Danby 5.5 cu. ft. / 156 liter Chest...
New 3.6 Danby freezer not freezing
maybe you should go with a different brand???
Feb 04, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
Frigidaire Chest Freezer Door Insulation smells like fish
might sound stupid but take the cover off the compressor electrics and make sure no plastic is overheating.
Oct 08, 2008 | Frigidaire 5 cu. ft. / 142 liter Chest...
Kenmore 12 Chest Freezer - Needs New Lid
searspartsdirect.com
All you need is the model number
It gives you a list of all parts you can buy to replace what's broken, as for the frost try placing a sheet of plastic over the insulation, under the the plastic cover to keep moisture and humidity out of the insulation.
Apr 25, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Temperature control
I have a danby mini fridge and freezer and noticed the same problem. The temperature dial has NO NUMBERS ON IT! it just has a strip that goes from light to dark blue. That's it. I looked in the manual and it doesn't say anywhere which way is colder...it makes sense that the darker the blue the colder the temperature but why keep us guessing?
Mar 15, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Freezers Logo
105 people viewed this question
Top Danby Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
charles
Are you a Danby Freezer Expert? Answer questions, earn points and help others
