Question about Nextbook Tablets & eReaders
Nextbook tablet Model no NX785QC8G screen lights up white with 3 lines about 2/3 up the screen
  • 8 Answers
SOURCE: there is a white line across the middle of my screennof my nextbook next7p12 how can I fix it??
The line indicates the screen is defective. It will have to be replaced. If it is under warranty the manufacturer will replace it. They may replace it even if out of warranty. You might find a new screen on ebay and replace it yourself. Good luck.
Posted on Dec 13, 2014
  • 236 Answers
SOURCE: rca tablet model rct6272w23 screen pixalted white then went black now wont turn on
I would recommend calling RCA support at (800) 252- 6123 so they can suggest some troubleshooting steps you can take. If it is still under warranty and you're unable to get it working then you can send it back and get a replacement
Posted on Dec 28, 2014
  • 103 Answers
SOURCE: I Just bought the nextbook tablet PC with Windows
My first thought is the usual colour of 'fully charged' is green not orange. Red or orange are often 'charging' colours, and if flashing it usually means 'battery / charging error' but suppose it could be different on this model.
Since this tablet is new, you ought to take it back to the retailer and ask them. More than likely they will know if it is broken or defective and replace it for free. My only other thought is let it charge overnight and see if that changes anything. Also make sure you're pressing the correct button, as I don't know the model I don't know if the power button is clearly marked as 'power' or with the 'power' symbol clearly.
Last possibility is if it seems to come on, but only the screen doesn't come on (you weren't clear if that was the case) then that could either be Windows 8 and a software issue or still a hardware issue. The plug to the screen inside the device for instance may have come loose. Alternately it could be just windows. I haven't heard much good about the latest release of their operating system. First thing I'd do though is take it back to the retailer if charging longer doesn't work. It might be a common defect of these tablets, and they should replace it for free with a good one.
Posted on Jan 03, 2015
ny4eva11798
  • 13 Answers
SOURCE: my tablet has white lines on my tablet screen help
Needs to be replaced.hope you have insurance.
Posted on Jan 16, 2015
chriseg1981
  • 38 Answers
SOURCE: My nextbook 8D12F will not open apps. Notifications are Unfortunately, Messenger has stopped. Unfortunately Google Play Services has stopped and so on and so on. All I can see is the home screen.
try to hold the home button down and hit clear all then task manager and hit stop all and reboot
Posted on Jan 20, 2015
Testimonial: "Thankyou Christopher. I'll try this. I've just turned it off and am waiting for it to reboot."
How to reset nextbook tablet model nx785qc8g
need turn the tablet off
press power button and the volume up button at the same time
till the screen comes writing press the down button to go down to the wipe data highlight that
then press the power button to ok that
go down to yess highlight yes press power button ok it it will reset your tablet
then when it rest it will go back to the writing go to reboot press power button ok it then it will restart your tablet
Mar 14, 2018 | Nextbook Tablets & eReaders
My Nextbook model NX785QC8G freezes when you turn it on. How do I reset it to the factory settings? I have looked, but have not found a reset button.
Check http://support.nextbookusa.com/support/index.php?/Knowledgebase/Article/View/84/0/reset-instructions-for-nx785qc8g.
1. Hold down the Volume (+) and the Power button at the same time, until you see No Command on your screen. (The tablet will act like it's going to turn on and go black, continue to hold your buttons until No Command shows up on your screen)
2. Release your buttons when you see the No Command appear on your screen.
3. Tap the Volume (+) once, and a blue menu will appear on your screen.
4. You will use the Volume (-) to navigate and the Power to select. Tap theVolume (-) until you highlight "Wipe Data Factory Reset"
4. Press your Power button to select it.
5. You will see a list of "No's" and one "Yes." Use the Volume (-) to go to the onlyYES on your screen.
6. Press your Power button to select the Yes.
7. This will prompt your tablet to go through the motions of resetting itself. When you see the words ''Wipe Data Complete", tap your Power button once to selectReboot System Now.
8. Your tablet will power off and power back up on its own; this will take a little longer than normal, so give it a couple minutes before it boots.
Dec 29, 2015 | Nextbook Tablets & eReaders
I have a nextbook NX785QC8G that wont turn on or charge only had it for two weeks went dead couldnt get it to to show a charge juat wount do nothing what shouldered i do???
Hello, it is still under warranty, take your receipt and go back where you purchased or call your cust. service for your product.
Nov 15, 2015 | Nextbook Tablets & eReaders
My tablet keeps shutting off
Nextbook 8 NX785QC8G shutting down on its own FreakTab com
shaunmt might have answer
Read through the other threads here about the NX785QC8G. They all have problems with the battery connector. The cable comes loose from the socket, which leads to incorrect batter level monitoring, sudden shutdowns and improper or no battery charging.
You'll most likely have to remove the back of the tablet, unplug and firmly replug the batter cable and consider options to prevent the cable from pulling loose again.
Jun 23, 2015 | Nextbook Tablets & eReaders
How do Move apps to external sd card?
Download and install ES file explorer. When run, you'll see the main and added memory. Find the app you want to move, hard press and hold it, and drag to new place.
Feb 22, 2015 | Nextbook Premium 8 Se Android
There is a white line across the middle of my screennof my nextbook next7p12 how can I fix it??
Dec 13, 2014 | Nextbook Premium Series Next7P12
How do i get the sound back on my nx785qc8g?
menu setup sound should be alternative phone/normal?
Jun 28, 2014 | Nextbook Tablets & eReaders
White screen with colorful lines
If this is a touch screen it is broken. It is probably not cost effective to replace the screen.
Apr 13, 2014 | Nextbook Tablets & eReaders
Remove vertical line screen
I have a nextbook premium 8 SE tablet. What ever screen I am in even when it is turning on it has two horizonial lines.
Jan 14, 2014 | Nextbook Tablets & eReaders
Tablets & eReaders Logo
21 people viewed this question
Top Nextbook Tablets & eReaders Experts
D. E. Hev
Tom
Dustin
Dustin
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
