I need to order a refill. - Office Equipment & Supplies
I want to order my refills of astalife-r How can I order ; from whom; how much
You need to contact the maker of the product for refills, we do not have or sell them.
Nov 21, 2016 | Office Equipment & Supplies
Which one refill kit I need on this page?
HP Easy Refill Kit for (HP) Color Inkjet Cartridges Printer
Jul 10, 2012 | HP Easy Refill Kit for (HP) Color Inkjet...
How to refill ink cartridge of Epson me32?
Follow these steps:
Buy an Epson ink refill kit. A refill kit gives you all the tools you need to refill Epson ink cartridges. Kits typically include a syringe, rivets, ink, and instructions on how to refill the cartridge. You can find Epson ink refill kits on the Printer Filling Station along with instructions for each specific model (see Resources).
Cover your workspace with a paper towel and fill up the syringe with the ink color you need. Epson refill kits will either include black ink or the color combination cyan, yellow and magenta. On average, you'll need 10 ml of black ink or 5 ml of color ink for Epson ink cartridges.
Find the rubber seals on the back of the Epson ink cartridge. Insert the rivets into each seal.
Empty the contents of the syringe into the Epson ink cartridge. You'll want to perform this action slowly in order to avoid spilling or overfilling the cartridge.
Remove the rivets. Use tape to cover the holes you made in the ink cartridge. Return the ink cartridge to the printer. Allow the printer to go through several print cycles in order to ensure that the Epson printer operates properly.
In case of any additional help please revert back
Jun 12, 2011 | Office Equipment & Supplies
After refilling the catridge printer shows a error "insert catridge card "
in order to have a succes refilling you need
to insert a new sim card that is always with
the new toner
in case you have n't got it with the refill bottle
you can check on net for aftermarket cards
that cost about 10 $ each
Jan 10, 2011 | Xerox Phaser 3200MFP All-In-One Laser...
I just had an ink cartidge refilled but printer still says that there is no in
Hello, unfortunately, most makers of modern printers incorporate a chip into the cartridges so that you cannot refill them....well, saying that, you CAN refill them but they won't work as the chip tells the printer it's empty. Some refill companies make a chip resetter that you can buy, but they will only work on certain makes, and apparently you can't reset original HP cartridges. Do a google search for your printer and include 'chip resetter' Regards, nicam49
Jan 01, 2011 | Office Equipment & Supplies
Refilled the ink and it is still saying it needs
Unfortunately, you may need to buy new Epson manufactured ink cartridges. Some of the ink cartridges and/or printers have a setting that says this cartridge is empty and refilling the cartridge does not clear the empty code.
(It is annoying but the cheap printers are paid for by the ink purchases after the fact.)
Dec 13, 2009 | Epson Stylus CX9400 Photo Printer
Refilled my #21 cartridge, poor or quality or nothing is printed.
You have an air bubble between your print head and ink supply. This is something that commonly happens when you hand fill these cartridges. These cartridges need to be filled under vacuum to prevent this from happening. I recommend refills from Cartridge World because they have good prices with a 100% satisfaction guarantee.
Jun 17, 2009 | HP LaserJet Q2612A Printer
Refilling Ink Cartrdige failer!
I have a Lexmark X5495 printer and I had it refilled a couple of weeks ago, suddenly i have a message that goes "Order new ink" or something and i check the cartridge but it is still full. I try restarting the printer and even the computer but the printer STILL won't let me print.
Oct 11, 2008 | Lexmark X5495 Printer
Refilled cartridge
press stop for 5 sec after changing the cartridge
Sep 01, 2008 | Canon FAX-JX200
