Question about Dometic Refrigerators
I have a Dometic rm2652 runs for about 30 min and circuit breaker between 12v leads at the heater element trips
    Top Expert:
  • Dometic Master
  • 8,673 Answers
Bad element
Posted on Aug 30, 2017
3 Suggested Answers
dididsaythat
  • 291 Answers
SOURCE: Dryer will run about 5 mins. then trips the circuit breaker.
I would change the breaker frist and see if that sovles the problem
Posted on Oct 14, 2007
  • 19 Answers
SOURCE: 50K BTU Reddy Heater Trips Circuit Breaker
If the unit lights Check the photo cell this can be done with an ohm meter and good light. Should have continuity in light.
Posted on Mar 02, 2008
Place heating element on dometic 2652 . The 2 heater leads j7 and j8 need plugged back in. Does it matter which goes where? they are both black wires
heating elements are simply resistance wires and allow current flow in either direction
so there is noconsideration for polarity
either way will be correct
Mar 08, 2016 | Dometic RM2652 Refrigerator
Why does dometic RM2652 rv fridge run on electric and gas at same time
12 volt runs board 120 volt runs heater element some have 12 volt heater element and LP
Jul 20, 2014 | Dometic RM2652 Refrigerator
Why is the gfci tripping on my hot tub after being on for 30 min. After resetting the breaker after the 30 min. run, it trips immediately!!!
You will want to make sure that all of your spa equipment is functioning properly. It is best for a spa technician or electrician to determine this issue.
It is likely that a particular piece of equipment is turning on around the 30 min time frame and causing the breaker to trip. Pump, ozonator or similar. Also check the heater element, a pin sized hole in the element will cause it to fail. Lastly your spas breaker itself could be bad.
Nov 20, 2012 | Pool & Spa
New fridge in RV
It will be either the compressor or the element. I suspect the compressor firstly. Pull plug out then pull the 3 wires off the compressor terminals then switch back on. Make sure wires are seperated and not touching anything. If no trip off after 10 min, you know it is the compressor. If not, then replace the wires and remove the heater wires from the element. Switch on and see if power trips off or not. If not, then it is the element. Replace.
May 19, 2010 | Dometic RM2652 Refrigerator
Dometic RM2652 RV Refrigerator trips GFCI
Hi!!
Right beside the circuit panel, there is a grill, remove the 4 screws to gain access to the transformer/battery charger. You'll see a double power outlet, one cord is from fridge, the other is from the transformer. UNPLUG Transformer cord and reset breaker.
It will take a couple of minutes for the fridge to change to AC if you have it in AUTO. If everything works fine, REPAIR OR REPLACE TRANSFORMER/BATTERY CHARGER.
Don't forget to rate this answer, Good Luck!!!
Apr 19, 2010 | Dometic RM2652 Refrigerator
Throwing breaker when plugged up to AC
The heating element most likely has a short in it. Pull the to leads leading to it test the ohms to see if you have a short
Aug 09, 2008 | Dometic RM2652 Refrigerator
Refrigerators Logo
37 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
