Question about Silentaire Technology Super Silent 20-A Air Compressor
My silentaire airbrush compresser starts humming then turns off be for Motor starts running the repeats after about 15 seconds
My pump hums when you turn it on but doesn't turn. If I then give the impeller a gentle turn it kicks in? It then runs till I assume it's hot, then the motor stops till it cools.
the hum is from the motor being powered but not turning. repeatedly letting this happen may burn out the motor. It is possible that one of the windings is already fried so the motor cannot develop enough torque to start rotation.
Apr 20, 2016 | Home
Quiet Partner IV. Why is the pots and pans light blinking and it won't run?
Its normal for the drain pump to run for 5 to 15 seconds and then your washer should fill and you wash pump should run if your was pump is not running and just makes a humming sound then your start capacitor may need changing see the link below this is a simple task and not expensive. When ordering a new capacitor make sure it is the same size in ?F.
Washer Motor Capacitor part 8572717 How To Replace
May 28, 2015 | Whirlpool Dishwashers
Super silent air 20-air compressor not running it humms for 3 seconds an then turns off every say 10- 15 seconds.
Hi, does it build up preasure? Possible problems can be too much water in the tank, air intake pluged, auto shut-off not properly adjusted or defect. Was it run hot before without oil?
Oct 26, 2013 | Silentaire Technology Super Silent 20-A...
Blower motor hums, but does not turn on
Try spinning the blower wheel by hand to see if it starts, if it does a new run capcitor will be needed. If not a new motor will be needed.
Dec 26, 2012 | Goodman Heating & Cooling
Intermatic R8806P101C timer hesitates when turned on manually
1) Copy following link for troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timers.html
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
2) Blow out timer with compressed air.
Turn power off and spray highly flammable WD 40 vapor onto gears
Buy new 240volt WG733 clock motor, and timer will be good as new:
3) Add comment dec 2012 and say what you discover
Dec 14, 2012 | Intermatic Hardware & Accessories
1985 vette starts and runs great untill you shut it off and try to start it again...i have to wait 15 - 20 minutes before it will start again, whats this all about???
when it won't start do u hear the hum of the in tank electric fuel pump when the key is tured to run, it will only hum for 1 sencond, so turning it back off and to run repeated times helps to hear the pump.
May 20, 2010 | 1985 Chevrolet Corvette
Rx8 car has trouble starting you need to step on the gas 7-10 times for the car to start
The RX8 has always been a bit problematic at starting, at least until Mazda started fitted uprated starters (~2006). The standard, weak starter motor spins the engine quite slowly, causing problems getting compression to start the engine.
There's various things to try...
DON'T pump the gas whilst starting - foot OFF the accelarator (might be beneficial to depress the clutch just to reduce the loading on the starter motor). Check all the RX8 owners' forums - standard advice.
DO use a confident turn of the key - keep cranking until it catches (but not for more than 10 seconds - in which case leave for 10 seconds before trying again) - don't just crank for a second or two, then retry. That's as per owner's manual.
DO ensure that you leave the engine to warm up ALWAYS before shutting off - to avoid fuel being left in the rotor - that affects compression badly if left any period of time, resulting in very poor starting (risk of flooding).
If non of the above helps, get a hot-engine compression check to ensure that the engine isn't shot. If the engine is okay, then consider getting an uprated starter motor, or 3rd-party replacement. Many 2004/2005s have had their starters replaced (I considered mine, although I've had no problem over winter :)
Jan 07, 2010 | 2004 Mazda RX-8
Blower motor hums but wont start
Check motor capacitor and try spinnig blade or wheel to see if spins freely if doesn't then the bearings are bad in motor and needs replaced
Apr 09, 2009 | Heating & Cooling
Dishwasher starts to fill then just hums
Sounds like a motor problem. Behind the chopper is an access to the impeller, try turning the impeller or the chopper blade and see if the motor will rotate. If it doesn't, then something is stuck preventing the motor from running.
Mar 07, 2009 | Dishwashers
Ford focus 1.8 1999 engine turns over but won't start
you may not have enough fuel presur yet. try this -
turn key to on, listen for fuel pump noise (humming) for about 5 seconds. If no hum, you have a problem. If it hums, good. Now, turn key off for 30 seconds and turn key to "on" again. Repeat 5 times. Then try to start car.
The fel pump does run in "start" mode continually.
Jan 09, 2009 | 2000 Ford Focus
Silentaire Technology Super Silent 20-A Air Compressor Logo
93 people viewed this question
Top Silentaire Technology Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Silentaire Technology Air Tool and Compressor Expert? Answer questions, earn points and help others
