Question about Sharp Ar 5316
Sharp AR 5316 is blinging error code L1 - Sharp Ar 5316
Copiertech
  • 16 Answers
SOURCE: error code
Hi Sorry cant send manual U have to buy like every one else.But here are the codes you require It is service code 24 sub code 04 to reset PM counter and sub code 07 to rest drum sub code 09 to reset print count and sub code 11 to reset developer. Hope this helps
Posted on Aug 22, 2007
  • 33 Answers
SOURCE: sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
Posted on Jan 02, 2008
  • 990 Answers
SOURCE: My sharp copier AR-5316 has the problem. Error
Hello sir; You need to do a reset procedure as follow; Press "#", "interupt", "C", " interupt". then enter 14 press start, machine go back to normal.
Posted on Oct 09, 2009
  • 74 Answers
SOURCE: Error code F2 on sharp ar 5316
F2 sub code 00 - Toner Sensor problem, ID pattern reading error;
Posted on Mar 27, 2010
  • 9 Answers
SOURCE: after installation my sharp ar-m420u
L1 MEANS U HAVE TO REMOVE THE SCANNER LOCK WHICH IS ON THE SIDE OF THE MACHINE.
F2 MEANS SOME PROBLEM WITH YR TONER CATRIDGE.CHANFE IT AND SEE
Posted on Jan 16, 2011
My sharp al2021 showing f5-02 and e7-11 what can do to work
The service manual was not available for the AL-2021 but the error codes are the same for the AR-5316
F5-02 error cause and remedy
Sharp AR 5316 Service Manual Page 27
E7-11 error cause and remedy
Sharp AR 5316 Service Manual Page 26
Jan 07, 2015 | Office Equipment & Supplies
SHARP L1 ERROR CODE
scan forward problem ,motor,sensor,board
Oct 24, 2011 | Sharp AR-5316 Advanced Digital Imager...
I have Sharp AR 5316 L1 00 error in my copier pls give tips urgent
L1 00 Content Scanner feed trouble.
Detail The scanner does not complete feeding in the
specified time.
Cause Mirror unit abnormality.
The scanner wire is disconnected.
The origin detection sensor abnormality.
Mirror motor harness abnormality.
Check
and
remedy
Use SIM 1-1 to check the mirror reciprocating
operations.
When the mirror does not feed.
Check for disconnection of the scanner wire.
Check the harness and the connector between
the mirror motor and the MCU PWB.
Replace the mirror unit.
Replace the MCU PWB.
When the mirror does feed.
Use SIM 1-2 to check the mirror home position
Jul 28, 2010 | Sharp AR-5316 Advanced Digital Imager...
I Have Sharp AR 5316 when i power on copier L1 00 error pls help me
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} 00-The scanner does not complete feeding in the specified time
I have a sharp photocopier AR-5316 flashing error code is h4 how to reset this code and solve the problem
i have a sharp photocopier AR-5316 flashing error code is E7 how to reset this code and solve the problem
Jul 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
Error code "L" & "1"
L1 indicates a scanner feed problem. Make sure the scanner isn't locked in the shipping position. It is underneath the scanner where the paper exits the machine. Look for a plastic dial and turn it one way or the other.
Jul 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error code L1
YOU EITHER HAVE THE SCANNER LOCKED OR THE SCANNER RAIL [SILVER BAR UNDER GLASS NEEDS TO BE LUBRICATED.
Dec 30, 2008 | Sharp AR-5316 Advanced Digital Imager...
Scaner don't worlk
L1, on a Sharp is scanner locked.
Check the lock tswitch, that on a sharp looks like a round shaped oject on the left side of themachine, under the scanner.
If it is not the lock switch, then the scanner is jammed, in this case call a technician.
Dec 20, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp Ar 5316 Logo
56 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
