Rock-ultra record carousel snaps records when it gos around Model 437
  • 211 Answers
SOURCE: Record Changer Arm
When the carousel reaches the correct count, the computer sends a signal to the gripper motor to start it. You could have a bad motor or a bad computer. But!....if the little switch at the front of the machine is in the off position (Gripper motor On/Off) that will give exactly the same effect. It's easy to knock Off when you are loading CDs.
Posted on Oct 20, 2008
  • 211 Answers
SOURCE: Wurlitzer model 556
Are you sure you mean 556? Sounds an odd model to me. The model number is on a black metal plate the size of a credit card on the back of the jukebox (usually).
Manuals can be found at www.victoryglass.com (USA) and The Jukebox Man in the UK.
Dave.
Posted on Nov 09, 2008
  • 211 Answers
SOURCE: Wurlitzer 3600 series wont select a record ?
If the buttons don't latch in, the machine is not in credit. Put on free play or put some money in.
Dave F.
Posted on Jun 25, 2009
  • 211 Answers
SOURCE: Rock-ola 498 Carousel Spins Continuously
There is a sensor which detects the start position of the carousel and if it isnt working it goes round forever. (Although I am not very familiar with this box)
Posted on Oct 28, 2009
  • 98 Answers
SOURCE: Jukebox lights work - when turned on the record
The problem could be the selection and credit computer or possibly the K7 switch actuator. I can repair the computer and I stock the K7 switch actuator. Please email tech@wurlitzer-ohio.com
Posted on Jan 28, 2011
My Rockola Tempo 1, just stopped mid record. Previously the carousel would slow down/hesitate at a certain point when selecting, but never stopped. Switched it on occasionally, with no movement.
I would put money on the belt snapping. 5 years is about right. Especially if you do not use it often. The slow down and hesitate is even more indication of a belt getting hard and then slipping and snapping. They need to keep moving to stay soft. Get a new belt and you will be likely good to go.
Oct 16, 2016 | Wurlitzer Rock-ola Jukebox
As record holding wheel gos around. It snaps and breaks records
Record holding wheel, what exactly is this, sounds defective maybe replace
Feb 08, 2016 | Audio Players & Recorders
Sound leisure vinyl jukebox Model Nostalgia 1015 Fault , rotates several times after selecting record , stops at wrong record and does not select record from carousel Please can help
the selector switches are black corroded by now
and need cleaned and the plateing restored with plating fluid
take it too a restore person
Dec 21, 2014 | Audio Players & Recorders
Rock ola 460
Contact the Guy at American Restoration in Las Vegas NV, he rebuilds these.
Jul 13, 2017 | Audio Players & Recorders
Rock o la jukebox wont pick up record to play
I actually have the answer to your problem, there are 3 things, if you make a selection and it goes to it but wont grab it, that means the gripper motor is bad.
If your carousel keeps spinning I think its like the wurlitzers, your index light or orbital reader bulb is bad, 2 names but same bulb, depends on who your talking too,
and the last thing it might be is yes your safety switch, happens when someone grabs the arm it can be moved and then your dead in the water, the cd models also have an on & off swtich so check that too. Hope it helps
Feb 20, 2012 | Audio Players & Recorders
Look on Ebay for manuals or try at www.victoryglass.com
Regards
Alan Hood
ami-man
UK
Sep 02, 2009 | Wurlitzer Jukebox 1015 One More Time...
45's records won't turn and prior to that they only played side B
There's a motor under the back of the carousel about 11 oclock. You can see the drive gear if you bend down and look under the toothed base of the carousel. If you press the lever to rotate the carousel you'll be able to see if the motor is turning or not. If it is turning but the carousel isn't moving you could have a stripped nylon gear.
Oct 25, 2008 | Wurlitzer Jukebox 1015 One More Time...
Rowe ami jukebox
Check the optical sensor, it may be blocked with dust.
Jun 09, 2008 | Audio Players & Recorders
32 people viewed this question
 Grubhead
Grubhead
