I have a Goldair Air Cooler GAC 700w and would like to know how you take the water out of the container at the back
I need to know an example of each part of the water cycle listed below: a. Evaporation b. Precipitation c. Runoff d. Condensation e. Transpiration
Hi Stan:
Evaporation - Hot sun shining on damp ground in morning. The moisture on the ground EVAPORATES as the ground dries.
Precipitation - Rain falling onto the ground is PRECIPITATION
RUNOFF - When rain falls onto the ground, some of it is absorbed into the ground. The portion that is NOT absorbed becomes RUNOFF in that it runs off the surface that it fell on.
CONDENSATION - Air contains water vapour, and the higher the temperature, the more water vapour it is capable of containing. This is expressed as relative humidity. When warm air that contains lots of water vapour is cooled, there will be a temperature reached where it cannot contain all of the water vapour that is present, so the excess water vapour CONDENSES on cooler surfaces. This process is called condensation.
If you Google TRANSPIRATION you will get a link to Wikipedia where you can read the definition. If you have problems with my explanations, you can also use Wikipedia to get the formal definitions.
Mar 13, 2015 | Washing Machines
How do use my mira-cool portable cooler/heater no instructions or manuals
My mira- cool blows out hot air when I turn on cooler, do I need to fill container with water in the back
Dec 21, 2014 | Heating & Cooling
I lost my manual and dont no how to operate my goldair gac 700w cooler
HOW DO I CLEAN THE TANK FROM THE GOLDAIR AIR COOLER (MODEL GAC-700W)
Dec 01, 2013 | Heating & Cooling
GoldAir Airconditioner F9 Error
Is the power supplie dedicated to just the ac because it should be check power needs in manual
Feb 20, 2013 | Heating & Cooling
Hamilton beach water cooler has mildew taste
Hi, your post is showing a photo of a vacuume cleaner? Don't think so,lol. If you water cooler has a mildew taste in the air, you need to go to a hardware store, just about any, and buy a roll of evaporative water cooler tablets that you add to the water to prevent this from happening. They are the size of a quarter and come in a roll or other container depending on the amount you buy. They have different names, so just ask for the tablet additive for your water cooler and they will no what you need. I hope this has helped you.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Oct 23, 2010 | Vacuums
How do you clean the baby pro bottle warmer?
Ice container, measuring containers, and baskets: Dishwasher-safe (top rack only).
Measuring containers should be placed in a dishwasher basket. Or wash in warm water
using mild liquid soap. Rinse with clear water.
Bottle Warmer unit and removable cooler: Always turn OFF and unplug before cleaning.
Wipe surface of unit as well as inside of cooler and cooler lid, and inside of warming
chamber with a damp cloth or sponge using mild liquid soap. Wipe with clear water. Air dry.
Do not immerse in water. Do not use scouring pads, solvents, or abrasive cleaners, as
these could damage the unit.
Warming chamber (optional): Mineral deposits (usually white in color) may form on the
inner surfaces of the warming chamber and can cause damage to the unit. To remove them:
1. Unplug the unit.
2. Remove the basket, and wash separately as indicated above.
3. Pour 2 oz. vinegar into the warming chamber and let it stand for an hour or two (longer if
necessary).
4. Pour out the vinegar and rinse the chamber two or three times by pouring in, then
emptying out, 3 or 4 oz. of plain tap water. Do not immerse the Bottle Warmer in water.
Wipe dry or air dry.
Aug 21, 2010 | Avent Philips iQ Bottle Warmer without...
Heating & Cooling Logo
197 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
