Question about Whirlpool Dryers
Whirlpool imperial Series dryer Model number TGDS840JQ1 Users manual
Whirlpool Imperial gas dryer won't heat up.
There are two thermal cutoffs. If you pop open the top of the dryer and find the heating element the bigger one is mounted directly on top of it and the other one is located below it. Those are the thing to check first. You can test with a multimeter set to test continuity. If those are bad that means that the exhaust vent is getting clogged. Those run about 34 bucks for the set. The other piece to check is the element itself. You can test that the same way. Those run between 50 and 70 bucks. Good luck.
Jun 28, 2012 | Whirlpool Dryers
I have a whirpool dryer that is not heating model number wed5550sq0 Imperial series. I took the heater coil off. is that the only thing it could be?
On the heater element housing is 2 limits.
If either of these are open the dryer will not heat but it will run.
More Here
May 18, 2011 | Whirlpool Dryers
Whirlpool imperial series dryer heats not spinning
This problem is almost always a broken belt. Yes you can do it yourself.
Go to repairclinic. com and put in your model number for the exploded view of your dryer. Locate the belt part number and belt orientation.
Jan 03, 2010 | Whirlpool Dryers
Whirlpool Imperial gas dryer won't spin
It's a broken belt. Replace the tensioner assy also
Nov 03, 2009 | Whirlpool Dryers
Looking for the age of Whirlpool electric dryer model number LET7848AQO Imperial Series CleanTouch 7 cycle 4 temp.
Link Below will give you the ability to calculate your manufacture date from the letters in the SERIAL number.
Whirlpool Date Codes
Sep 09, 2009 | Whirlpool Dryers
Need model number or part number for whilpool dryer
The model number for your dryer is usually located on a plate or sticker inside the door on the body of the dryer hidden by the closed door.
The most common (but not the only) belt number for Whirlpool dryers is 341241 and the idler arm for that common dryer has tabs that fit into the floor beneath the motor drive pulley. Take a loop of the belt with ribs inside the loop and pass it through the opening below the roller and loop it around the motor pulley. If it's the most common unit the end result should look like the image below for Whirlpool:
Belt Configuration
Good Luck
Sep 07, 2009 | Whirlpool Dryers
Timer not working on estate model TGDS840JQ1
Try first tripping the circuit breaker for ten minutes and see if this reset the board.
Here is the part: PS394424
Check also the connector:PS345626
Here all diagrams for your appliance.
Parts must be tested before replacement.
May 07, 2009 | Estate TGDX640JQ Gas Dryer
Dryer will not heat
Model number needed to look up fuse location or simply use to look up the fuse location yourself. These newer models have not been out long enough for a retired old dude like me to come across one. But I bet I could repair it.Since yours is this new you might want to get factory service to take a gander at it before you attempt a DIY to prevent voiding any warranty you may have left.
Jan 10, 2009 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
32 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
