My thermablaster 32000 wall mount heater works well,except occasionally it will flame up high when it comes back on. I have to turn it down then turn it back up. Do I need to clean it or adjust it?
  • 1420 Answers
SOURCE: Empire DV-215 Low Flame Issue
Either a restriction in the gas train, low gas pressure or a bad gas valve. Check the pressure on the gas line when on pilot and again when the burners are running. Depending upon what type of gas it runs on, you should have at least 4" W.C. if Natural Gas and 10" W.C. if Propane. If gas pressures test good and all valves are open, you are looking at replacing the gas valve.
Posted on Dec 10, 2007
  • 345 Answers
SOURCE: Only half of the wicks burns/ flame varies in height/ smokes !
Sounds like you have a wick that has burnt unevenly in the past and now there is not a good setting for an optimum burn. Either the wick needs to be trimmed even or you need a new wick.
Posted on Nov 14, 2008
SOURCE: Pilot adjustment on Williams wall heater
The insert sounds like the cap covering the adjustment screw. Pin hole is for cap removal. Wondering why flame is so high?! Shouldn't have orange flame. If heater doesn't light with lower flame... thermocouple (thing that the flame heats up) may be bad.
Posted on Jan 03, 2009
  • 3182 Answers
SOURCE: shuts off when switched to low and smells when running.
clean the burner and the orifice you can use a air line or blow off a vacum cleaner
Posted on Feb 07, 2009
  • 4 Answers
SOURCE: I have a blue flame GLO WARM 20btu wall model # WMP20A
Look for and clean the flame sensor.
Posted on Dec 06, 2009
My gas wall mount heater works a while then shuts down. why?
When it is running check the flame. It's triggering a rollout switch.
Feb 27, 2013 | Heating & Cooling
When the dryer is cold the heater flame will
The heating circuit is working perfectly except for the solenoid coils as indicated by the occasional glowing of the igniter but no gas is ignited. A gas valve closes as the solenoid coil weakens as it gets hot and does not open until it has cooled down. Replace both gas valve solenoid coils to get the dryer back into proper operation. The solenoid coils are part numbers 694539 and 694540 but also can be purchased as a kit here.
Apr 27, 2010 | KitchenAid KGYS850LT Gas Dryer
Need manual and wall mounts
I don't have a manual for the HGA, but that heater is identical to the ML300HBA, with the exception that it has a black piece of sheet metal that hides the flame.
The manual for the ML300HBA can be downloaded from my website:
A wall mount bracket comes with the unit, but if you don't have one, you can call Procom Customer Service at 877-886-5989 or World Marketing Customer Service at 800-776-9425 and ask for one.
May 06, 2009 | Procom ML300HGA Heater
Heater will not stay lit
sounds like the thermocouple is going out this is the part the flame from the pilot burns on and tells the gas valve to stay open by producing a small amount of electrical current in milli-amps these can be purchased @ a good hardware store and you must position as it is when it comes out , and must be the same length , make sure to connect to gas valve clean and tight , also is there a moisture trap in the line if so you might need to turn off gas and make sure it is free of moisture , this is a good place to start with these items
Jan 16, 2009 | Desa International GWP20T GLOWARM Wall...
Wall mount propane heater ignites, but won't stay lit
I have a Reddyheat IWH16NLTD with this problem. When the heater fan turns on it blows the pilot light slightly up and away from the thermocouple causing the safety valve to close after the ceramic cools down. The manual says that low gas line pressure can cause the flame to rise too far from the thermocouple causing this problem, so either it is a problem with gas pressure, or it is an assembly plant problem.
Jan 10, 2009 | Reddy Heater-10-12-15,000 Btu L.P.
Wall heater not working properly--sputtering blue flame
Ok, either your fuel pressure is too low or too high.. When you light the unit, Light it in low, then turn it up slowly Just crack open your tank valve.about1/4 turn. The air in the tubes has to be displaced with gas before you get a good flame
Dec 02, 2008 | Reddy Heater RLP100 Portable Forced Air...
Flame shooting to high
call the gas company to have it serviced sounds like it needs it
Nov 23, 2008 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Blue flame heater pilot wont stay lit
There is a therma-couple that the flame burns against. When it is working correctly it allows gas to travel to the flame. When it goes out you get no gas, as a safety feature. Replace the therma couple and it should work again.
Oct 06, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
