Question about Hawking Computers & Internet
My device will not join the hawking 121 repeater. It finds it but only spins and will not join so I can set it up
Como resectiar unhw2r1
At the back of your device next to the WAN Port (internet port) you will find a small hole with a button inside it, turn your device off then press and hold the small button in while switching on your device, keep pressing down on the button for about 5 seconds, that will reset your to default settings.
Dec 29, 2013 | Hawking HW2R1 Dual Radio Smart Repeater
Hawking smart repeater pro
I CAN FIX THIS WITH A REMOTE CONNECTION...call 225-290-5733
Dec 26, 2013 | Hawking Hi-Gain Wireless-300N Smart...
Installing a hawking HOW2R1 Repeater and setup requires a security key; where do I find this?
The Setup Wizard will now prompt you to automatically
configure your IP settings (recommended) and enter a
security key if the network you are connecting to is an
encrypted network. Enter the key and click Continue.
If you do not know the security key of the network you are connecting to, consult your network administrator.
Oct 15, 2013 | Hawking Computers & Internet
Hawking HW2R1 repeater doesn't get internet
first of all bring the repeater closer to your router (after upgrade you can return it to its original location)
Mar 25, 2017 | Hawking HW2R1 Dual Radio Smart Repeater
How to setup up for repeater mode
This particular Hawking device must be configured after it is connected to your LAN and powered up.
Before you can do this, you will need the software from Hawking. If your devices Serial Number begins with HEMCHWREN1 use the link below"
http://hawkingtech.com/products/downloadfile/114.html
If you have a Revision 1 device with a Serial Number begins with HEMCREN1R1 use this link:
http://hawkingtech.com/products/downloadfile/117.html
Once you have the software, here are the steps you need to follow:
  1. Connect the A/C power adapter to an
    electrical source, and then connect it to the
    'Power' socket of the Range Extender.
  2. Connect your Range Extender to a LAN
    port on the Router or AP that you would
    like to extend (repeat) the range on.
  3. Connect your PC to any of the LAN ports
    located on the back of your router/AP.
  4. Now run the appropriate program you obtained from the instructions in the beginning of the answer.
When the auto-load page appears, click the Setup Wizard option on the right and follow the Setup directions.
Scan for your Range Extender by clicking the 'Search' button. Once found, click the device to highlight it and click 'Next".
Choose a name for your Range Extender. You will use this name to identify and connect to your extended network. Optionally, you may change your login username and password. Click 'Next'.
At this point, the Setup Wizard should automatically obtain a new IP address for your Range Extender from the Router. Please wait for this IP to generate into the IP address field. Note the new IP address and click 'Next' to continue.
In the Search box, find the Wireless Network that you would like to extend. This Range Extender works best with other wireless-N networks, but also supports wireless-B and G networks as well. Select your preferred network and then click 'Next'.
For Security Settings, you must make sure that the Range Extender's security settings are identical to that of the Router/AP that is having the signal extended. If you do not know these settings please contact your network administrator.
At this point the Setup Summary displays all configured settings of the Range Extender. If the information displayed corresponds to your desired networks settings, you can go ahead and click 'SET' to apply the settings. The HWREN1 will automatically reboot. Please be patient.
More information can be obtained on the hawking site:
http://hawkingtech.com/products/hi-gain_wireless_networking/range_extenders_&_repeaters/hwren1.html
Sep 24, 2011 | Hawking Hawkin HiGain HWREN1 Wireless300N...
Extender reboots my Netgear router
I would start with stripping ALL security and encryption settings, see if they work with basic IP addressing setup. Verify that the subnet address ranges are the same and that that the same IP schema is used (IPv4 vs IPv6) on both devices. Then make sure that the security settings are complementary to each other and not in conflict (opposite or identical). Then add the pair to the existing network and check antenna connections.
An alternative suggestion would be to install a Yagi type antenna on the Netgear DG834GT. This will give you a very long and useful range. A Yagi antenna can be made rather inexpensively using a coffee can (Google "coffee can Yagi antenna", I suggest the entry from iHacked.com, this gives a good lesson on the antenna and basic concepts).
Nov 16, 2008 | Hawking HWREG1 Repeater
Assign address manually
hmmm....so, how is the IP address NOT working for you? Can't see it from your computer? A bit more detail please..
Mar 15, 2008 | Hawking HWREG1 Repeater
Can't connect!
make sure its IE that you use the configure the extender config as using firefox may not save the settings. check if theres an option of save all settings within the config.
Nov 15, 2007 | Hawking HWREG1 Repeater
Computers & Internet Logo
41 people viewed this question
Top Hawking Computers & Internet Experts
Steve
Mike
Are you a Hawking Computer and Internet Expert? Answer questions, earn points and help others
