Question about Sony Audio Players & Recorders
Sony sch2000 speaker's: there's no sound coming out of my speakers only popping sound then it goes silent
  • 682 Answers
SOURCE: STR--DG910: no rear speaker sound, no center speaker sound
if you confirmed all connection repeat your speaker setup.
Posted on Aug 02, 2008
SOURCE: Speakers pop and rear speakers cut out of surround sound
your problem is a bad solder connection of the relay linked to the lautspeaker sockets. I had the same problem and googled for the solution. Since I resoldered the pins everything is fine. That problem is well known and happens to a lot of Sony receivers.
I can send you a link with a detailed how-to-do solution with pictures, however it's written in german language. But you can use some online translators.
Here is the link:
Ralf (from Germany)
Posted on Feb 15, 2009
SOURCE: Onkyo digital reciever has poping noise when in dolby sound
I have the same reciever, and had the same problem.  Contact Onkyo, this is a known issue where defective DSP chips were used and manifest problems with a popping / clicking sound when using surround settings.  These receivers also have a Dolby Digital input issue that can cause audio dropouts when watching cable or SAT broadcasts that encode DD using a 'newer' broadcast encoding methods.  Onkyo is covering the cost of that repair for me now, even though the receiver is 5 years old now....
Posted on Mar 06, 2009
  • 814 Answers
SOURCE: Sony str-de675 receiver has no sound at speakers when turned on.
This unit is having a problem with the preamplifier and power amplifier section. The reason to suspect this is that you can still hear sound, this is not likely if you ahd a failure in the power supply section. The unit may have had a failure in the amplifier areas of these sections, These are the signal amplifier sections that increase the power of the signal to drive the sound in the speakers .The Unit is probably in the protection mode reducing all power to prevent further damage to the rest of the receiver. You can go to the website support section and look in the frequently asked question and troubleshooting sections for problems like yours and see if they have any answers. On this website you can also find customer support. Ask them questions about the problem and see if they have any solutions.If all this fails to answer you problem, you can try opening the unit and looking for the problem yourself. Only work on the unit with it unpluged from the power source. Take off the top cover and look for any damaged areas, on the pc boards.They would be brown areas from excessive heat due to component overheating and possible failure.Look for capacitors that may have gone bad, they will be bulging from the top and bottom and may be leaking material from inside of them. Any component like this needs to be replaced. You may find burnt resistors and other failed components that will require a digital voltmeter to test.If you have expperience with this type of repair you might be able to isolate the problem and replace the parts. This may require the help of service information due to the complexity of the receiver's operations. Try to get a schematic or service manual from the web or a repair shop. This will have all the parts and a diagram of the all the different sections of the receiver. Usuall there is a power supply section, a tuner section, a preamplifier section, and a amplifier section. There also could be a equalizer section and other sections according the functions of the receiver. The failure most likely has occured in the preamplifier section or amplifier section. The problem in the preamplifier section could be a signal diode failure or a signal amplifier failure. in the amplifier section the problem could be in the output power devices which may be transistors or ic's depending on the type of output amplifier use in the unit. Usually not that hard to find with good service information and test eauipment.You may want to take this to a school that teaches electronic servicing and see if they will work on the unit for you for the cost of parts and a small labor fee. Call them first and see if they can help you out. I hope this helps you with your problem.
Posted on May 18, 2009
SOURCE: no sound from Sony STR-DH500 when playing dvds with HDMI
no sound via hdmi cables, you must use optical or coaxial
Posted on Dec 18, 2009
Plays for a few minutes and pops and goes off?
Check the connectors on the speakers arent shorting and are connected correctly. A sony downloadable manual is available on the sony website it will tell the correct way to connect speakers. If tht doesnt stop change sound field to 2 channel that worked for me .
Jul 28, 2011 | Sony DAV-DZ30 Hometheater System
Radio on 2008 dodge nitro stops working it goes out for a while then comes back on. no sound even when turning the volume up and down. it makes a loud popping noise and goes out.
Im having the same problem! No pop, just a hum, and my volume dial won't adjust. Like the actual dial isn't working. I can't use radio, cd, or aux. Silence SUCKS.
May 31, 2011 | 2008 Dodge Nitro
I have a 3 yr old Panasonic 42" Plasma
it might be coming from the actual audio/video source. try hooking up a dvd player or gaming system and see if it still does it.
Jul 11, 2009 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
No sound from the speakers
The main thing on problems like this are the speakers, either grounded out or the voice coil is bad. Being on the water it is subject to way more moisture. I would suggest disconnecting all the speakers and either tiring them one by one to see if they function or "pop" them with a 9 volt battery.
OR you can cut 1 speaker at a time from the wire harness at the back of the radio to see if the stereo comes back on. (goes into protection mode when a speaker grounds out)
If that all fails then the deck may be done ---- more than likley one of the speakers though.
May 27, 2009 | Car Audio & Video
My computer speakers just went silent in the middle of a song
Do the speakers have power? Check the fuse.
Where are you plugging your headphones?
Where are the speakers connected? Is it the same jack as the headphones?
Have you tried plugging the speakers into the headphone jack vs the soundcard?
Mar 13, 2009 | Harman Kardon HK695 Computer Speakers
No sign of life in external notebook speakers
  1. If the powerlight is turning on some times and off sometimes, Then it may be a problem with the powersupply connected to the speakers. Check it.
  2. If the speakers are on and are not playing, Then try playing some music through alternate source like ipod,walkman etc.If the speakers are playing with alternate music source, The try reinstalling the audio drivers of your note book.
  3. If not then your speakers might have fried up due to some reason.
Feb 01, 2009 | Audio Players & Recorders
Humming Noise
There might be something wrong on the volume dial, or the speaker connection.
SOLUTION: Check the speaker cables on the back.
Mar 28, 2008 | Philips FWC577 CD Shelf System
Sound problem
Make sure all speakers that are hooked up sound ok. If any of them sound lower then the others or sound distorted you may have a speaker with a partially shorted voice coil. If speaker or speakers pop when power is first applied you may have a grounded speaker that should not be grounded. Each speaker wire rides on 6vdc and if any speaker sees a ground you will have 6v across voice coil which would explain any popping noise when first turned on and radio may play for awhile then overheat. be sure speakers are 4 ohm min per ch otherwise amp will run to hot. Just a few Guesses
Jan 13, 2008 | Denon AVR-1708 Receiver
Earpiece sound silent volume 7 sounds like a volume 2 or 1
Hi, just remove the cover and check the speaker volume.. may be some new plastic coating an the new cover will be blocking the sound from coming outside properly. If it is not the case then please do come back all the best sreejith
Jul 16, 2007 | Motorola Mobility RAZR V3
Not getting sound from right speaker
How do you have the audio hooked up from the TV set? If its s video or RCA plugs? If it is switch them around and see if it swaps channels that goes out . If it does then the output cable or the jack is bad. If your using an HDMI ir a scart cable. The cable or connections could be bad. Unplug it and reinsert it or while the units on mover it around and see if the audio comes back on.
Sep 22, 2006 | Yamaha RX-V550 Receiver
51 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
