Question about Pioneer Audio Players & Recorders
No remote on my pioneer Kuro trying to get my receiver and speakers to work but no sound. Plugged in optical cable but probable need to switch the input on the TV but can't without remote....help!
    New Friend:
  • 3 Answers
Make sure you have charged batteries in your remote
Posted on Dec 31, 2016
Testimonial: "That is the worst answer ever. I don't have the remote anymore. Read my question above more carefully"
No sound using optical cable connected to LG smart tv 60LN5600
Your receiver has 2 optical inputs. If you plugged in the cable to Input 1, you can select the "CD-R" Input on the receiver. Then use the "Signal Select" button to select Optical 1 (O1).
You can also use the "Input Select" buttons on the remote until the receiver says "Digital". Then use the "Signal Select" button to select Analog (A), Coaxial 1 (C1), Optical 1 (O1), or Optical 2 (O2).
Mar 08, 2015 | Pioneer VSX-820-K Home Theater Receiver
Pioneer 409 setting up for surround sound
I think there is a switching problem in the surround receiver. I would take the receiver to a qualified servicer. There is nothing user serviceable in the unit. Question .Why are you using optical output from ps3. I recommend you connect all you a/v devised to the tv. Then connect the opt out of tv to receiver. that way what ever you are viewing will send audio via opt out of tv to receiver. that way you do not have to switch input on receiver. Hope this helps.
Jan 07, 2014 | Pioneer VSX-D511 Receiver
Have got sound through all devices plugged in however no picture. Using video cable (Yellow) and red/ white audio. Have got yellow plugged in monitor out....
your video source (cable box or Blu-ray or satellite box) has to be plugged into a proper video (yellow) input on the Pioneer A/V receiver and you must select on the TV, the video input where the yellow video cable is plugged in from the Pioneer A/V receiver (use TV remote). Also select on the Pioneer which source component you want like the cable box or whatever. Check cables for quality. Swap RCA video cables to see if cable is bad. Try new video cables. May need to adjust a user setting on the Pioneer A/V receiver. Make sure cable box or whatever is plugged into the yellow video input for that component you are selecting on the Pioneer.
Mar 27, 2011 | Pioneer VSX520 Receiver
Not controlling the power properly
Do you have Kuro Link enabled? The Kuro Link is enabled by default. If you haven't changed this setting, I would advise you to turn Kuro Link off as many users have had problems with the Kuro Link.
Hope this helps. If it doesn't, consult the Official Thread on the Pioneer VSX 1019 AH-K on avsforum. They will surely help.
Sep 05, 2009 | Pioneer VSX-1019AHK A/V receiver
No sound from speakers after connecting to pioneer a/v vsx81
I had the same problem and resolved it last night. You'll also need to connect an audio cable (EVENTHOUGH YOU SHOULDN'T HAVE TO - to bad pioneer didn't fully implement the HDMI standard in this receiver) solution. I suggest using an Optical cable. This really annoyed me...see the manual on P.17 section #3.
Dec 28, 2008 | Pioneer VSX-818V-K Receiver
When i play music cd all speakers work but when put a dvd on only the 2 front ones and centre speaker goes? Tried all settings. Y are my 2 surround sound speakers not working? I have a pioneer vsx-816...
What is happening is the the pioneer is set up so that you can choose how you listen to your DVDs. So first you must see how your DVD is connected via the audio. I am fairly sure that the Default on the Pioneer is to play it through the standard stereo if all you have plugged in is the left and right audio plugs. If you buy an optical cable or a plug in the Digital Coax out put to the pioneer receiver, then the pioneer will decode the sound and out put true surround sound. Some DVD players don't have a digital out put, but these are the cheapest ones out there. If yours doesn't have a digital out put, then you need to get one that does. They can be purchased for as little as 39.00.
Okay lets assume you bought a DVD player with Digital out put for audio and you have it connected to the receiver. Now, you have to change the mode on your pioneer to let it know that your audio is coming in DIgital when you select the DVD. (Though this may already be the case and you won't have to do anything once you connect it.)
Dec 08, 2008 | Pioneer Televison & Video
Pioneer VSX-D608 Optical connection
The manual states that the default association of each digital input in as follows:
  • Optical 1: CD
  • Optical 2: MD
  • Optical 3: TV
  • Coax: DVD
Use the "Signal select" button to set the receiver to use a digital input, and the Dolby/DTS button (above "Signal select") to enable decoding.
As samz11 stated above, a remote is required to alter the digital input mapping.
Sep 19, 2008 | Pioneer VSX-D608 Receiver
Pioneer receiver VSX-D411
Yes techtod you are right you do have to tell the receiver what you want it to do usually on the front panel you can access set up menu and go into input set up This is an example Say you plugged the dvd into optical one or coax 1 you must go to the input that says dvd click down till you highlight dig input and then select optical 1 or coax 1 there can be as many as 8 digital inputs so just check wich one you plugged it into and then tell the amp then you should be back to watching your digital movies
Mar 21, 2008 | Pioneer VSX-D411 Receiver
VSX D511 No input select
I am getting no sound via my optical cable input. The back of the AMP says that the optical is TV/SAT but i can't change the input to digital it will only go to analog. DVD player is set to Bitstream all dvd options set to DTS, but still no sound going through. Any help would be apprecaited
Jan 29, 2008 | Pioneer VSX-D511 Receiver
HELP Blu-Ray to Pioneer DVD Suround System connection
The receiver that came with your speakers should have a digital input for a dolby digital source. On the back of the receiver it's probably labled "digital coax" or it could be an optical as well.
Your new Blu-Ray has these outputs on the back. it's as simple as getting the correct cable and selecting that input on the receiver.
To make sure you get the right cable, look at the back of the receiver, and the blu-ray. Look for the digital input on the receiver, and get a cable that matches that. It's either a single RCA cable, or an optical.
So when done, you will have the HDMI or Component out from the Blu-Ray going to the TV, and the digital audio going to the receiver. To hear the sound through the receiver, just go to that input on the receiver.
Dec 23, 2007 | Pioneer HTZ-55DV System
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
