Question about The Audio Players & Recorders
There's no sound coming out of my speakers, I've checked every cord and their in correctly. The only thing its doing is making a popping sound for a few then there's silence
SOURCE: Speaker makes a popping sound when car starts
may be the antenna jack such is connected in cassete is n't good
Posted on Jul 09, 2007
  • 163 Answers
SOURCE: popping sounds from tv
You are getting a spike through the audio circuit for some reason.. Does the screen stay 100% Normal when it happens? And is it a steady timed thing or intermittent?
Posted on Feb 29, 2008
  • 9 Answers
SOURCE: Speakers making a constant poping noise.
this could be due to some static  please get your electrical point checked up 1st  is your tv hooked to watch television thru RF or AV please have the interlink cables if this does not help get back with more details
Posted on Oct 15, 2008
  • 104 Answers
SOURCE: one speaker making a popping sound
try switching the popping speaker to the other side and see if it still pops if it does then you have probably damaged the driver in the speaker if it doesnt pop then the problem probably is in the receiver
Posted on May 28, 2009
  • 150 Answers
SOURCE: I use an azur intregrated amp 540A and a Azur Pre
I've never repaired one of these but I have an amp at home that makes a intermittent static "popping" noise that i'm going to put down to a dirty volume pot (control) that needs cleaning. I will also have to change some of the electro capacitors that have dried up inside which cause "shot noise". With the right lubricant (electrical contact cleaner, nothing else) you could take to lid off and spray a small 1 second blast into the hole of the pot and any other balance or tone control yourself but I would take it to the electronics repairer to get the capacitors checked over.
My theory only
Good Luck!
Posted on Jan 17, 2010
I have marantz Av surround receiver model SR301 I have tried a lot but I am having sound from only 2 speaker when I put in setero mode but when I put in surround no sound from any speakers I checked all...
First off you will need to do a little bit of trouble shooting. Is the source (dvd, Blu-ray, cable box, etc...) plugged into the receiver with the standard red and white RCA cord or by an optical (toslink-fiber optic) or digital RCA (orange color code). If you are connected with a standard RCA cord then that it your problem and you need buy digital cord that both the source device and the receiver can accept (toslink - http://www.we-supply.com/browse.cfm/optical:-audio/2,779.html or Digital RCA). If the connection is now correct then you need to make your receiver do a "test-tone" to insure that a signal can be sent to every speaker (this is an internal test that just checks the speaker connections). If the tone tone operates correctly then you know the amplifier is functioning. If both of the mentioned things are now done and still not surround output then you need to check the internal menus on your source device and make sure that it does not require you to manual change a setting in the audio menu to make it work (i.e. change from 2-ch 44KHz to 5.1 or 7.1 or Dolby Digital or AC3 or some other surround sound protocol.)
Austin
www.we-supply.com
Aug 08, 2013 | Audio Players & Recorders
1996 Ford Explorer factory Radio works but when i install the aftermarket radio no sound comes out from it what do i do ..??
Does it light up? Does it have a mute button? Does it have a mute wire for in vehicle phone systems? If so, it may need to be grounded to take it out of mute, or it may need to go to 12 volts + It depends on how the circuit was designed.
If those check out, or it lights up but no muting make sure the speakers are connected to the correct wires. Also check to make sure the speakers are not grounded. Two wires should go to each speaker. you can check the condition of the speakers with a 9 volt battery touched across the leads, you will hear a pop sound. make sure those two wires for each speaker are connected to the radio correctly.
Jan 23, 2012 | 1996 Ford Explorer
Logitech Z5500 5.1 speaker system Hi, Any suggestions on how to troubleshoot this problem? there is no sound coming from the subwoofer or the speakers, but when I connect my mp3 player to the pod...
Try pulling the power from the unit for a few minutes, the reconnect. Make sure you've got the surround settings correct. If that doesn't do it, you've likely popped the amp or the amp's power supply in the sub box.
Jun 16, 2011 | Logitech Z-5500 Computer Speakers
No sound and video
Video issue:-
Assuming the system power comes up, does the monitor power come on? Most monitors have a status LED on the front bezel that should show green, orange, or blinking if the monitor is powered on. You can hear CRT monitors power on with a gentle sound, though I can't describe it beyond saying it's the sound of a CRT tube warming up. Make sure the monitor is plugged into a good outlet by testing the outlet with a lamp or any other device that will prove beyond a doubt that the outlet is good. Make sure that the power cord is either permanently attached at the monitor end or that it is seated fully in the socket, since partial cord insertion is the most common failure for monitors with detachable cords.
LCD displays don't make any sound when you turn them on, but they don't have a simple power cord, either. Older LCD monitors are usually powered by an external transformer, which in turn is powered from a regular AC outlet. If the LCD display doesn't show any signs of life, make sure that the cords into and out of the transformer are fully seated. Some transformers are equipped with a status LED to show when they are operating. The power connection to the LCD display is often awkward to inspect, recessed into the back of the display. The important thing is to make sure it is started correctly, then seated all the way.
Sound issue:-
No Sound From all speakers
  • Check that the speakers are powered on.
  • Check that the speakers are connected to the correct ports on the PC. This is particularly important If the customer has both integrated sound and a sound card.
  • If the speakers have a volume control button - ensure that this is turned up.
  • Check that the Windows Audio service is running. If this is not running then many of the subsequent troubleshooting steps will not work. Go to Start->Run and type services.msc. Double cliick on Windows Audio. Select Start if possible and check that the Startup Type is Automatic. Click OK.
  • If the speakers are digital speakers then try forcing the sound card to use digital. Go to Start->Control Panel->Sound and Audio Devices.. On the Volume tab, click the Advanced button in the Device Volume section. In the Volume Control window, below the Play Control Volume slider, click Advanced. If this does not show select Advanced Controls from the Options menu. Select Digital Output Only
  • If possible try an external audio source like a Walkman, CD, or MP3 player (connect the speakers to the headphone jack)
  • Check that the volume control in Windows isn't muted or turned too low. See the screen shots below. Go to Start->Control Panel and double click on Sounds and Audio Devices.
Aug 06, 2010 | Computers & Internet
Speakers are popping
you may have a bad cord to your speaker or a bad rca cord ive had some what the same thing it turned out too be a bad groung on the rca cord
Nov 29, 2009 | Audio Players & Recorders
Mackie SRM450 speaker keeps making a 'popping' sound
First thing is to verify that a ground loop from your driving equipment is not causing the problem. Easiest way is to drive it with a BATTERY operated little CD player so no ground loop could exist.
Verify that your power cord is in tight and try another cord to verify it is OK.
Beyond this, service is probably required. If unit is out of warranty, you could have a person open it up to see if anything is obvious.
A possible proble is bad connectors or worse, a cracked circuit board.
Analyzing if noise is from both the woofer and high range speaker is a first step.
Aug 31, 2009 | Music
Popping sound coming from Acer X1200 desktop speakers
If the popping sound is happening during regular use it's possibly the wires connecting your speakers to the sound card. You can make sure the jacks are fully in there sockets on both the speakers and the port on your computer.
The next option if checking the connections doesn't help would be to replace the wires. You may be able to purchase or order the cords from the dealer you bought them from, another dealer or the manufacturer.
Then finally if that doesn't work or you feel that either do to time, money or both it's not worth replacing the cords. You can always replace the speakers outright.
Another possibility is electromagnetic interference. A cellphone near your speakers or computer can do this as well as a few other electronic devices. Maybe moving the speakers further away from a harddrive, moving stereo or some other device that either has a broadcast signal or moving parts. As electronic devices become more and more common this becomes a bigger issue. Hope all this helps.
Jan 27, 2009 | Computers & Internet
Sound
Make sure your volume is not on mute. If the speaker icon on your lower right has a red x means its on mute. To test go to control panel and double click sounds and test. If Windows sounds work without speakers then problem is with speakers. Make sure volume is up, make sure its properly connected to correct output jack (usually green or light green). Also make sure speaker power on. If those things are correct check your device manager ( right click my computer) select "manage", click on "device manager" and on right pane check to see if theres any yellow exclamation, question mark or red x on the sound device section. Yellow exclamation or question mark means to update or install correct drivers. Check your speaker box if it comes with a CD.
Jul 29, 2008 | Dell Inspiron 530s Desktop Computer...
How do i know where the grren cord goes, there is 2 different green slots and i tryed both of them
Hi, itryed
Well, first thing first! you mean, someone Format your computer? if so. Just see in device manager if the person install the correct drivers for yous specific sound card . (device manager) if not install them from the CD that is drivers for your computer. (sound)
then put the cables and check!
that should do the trick
Nov 19, 2007 | Ozaki DT-500 3-Piece Speaker System...
Popping noise
Our Sony (almost new) is experiencing sound problems. The sound go off and on about every 10 seconds. Cords appear correctly connected. It sounds as if its coming from the television.
Can you help with this problem?
Thanks,
Mike
Oct 21, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
23 people viewed this question
Top The Audio Players & Recorders Experts
bihug
bihug
Level 1 Expert
D. E. Hev
AliennoisE
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
