Washer showing F5 fault code; what is solution ?
  • 6,694 Answers
If you wish to get some details; visit the site linked here. Pull up older posts.
Posted on Dec 31, 2016
Bravos XL F5 error
Here is a link to the error codes for your machine. There are several F5 error codes. F5 E4 Lid not opened between cycles F5 E3 Lid unlock fault F5 E2 Lid lock fault F5 E1
Lid switch fault
Oct 31, 2017 | Washing Machines
What does f mean on my cabrio washer, just f
your not reading the error codes right, the F simply stands for fault then the other lights indicate a number code like f2 f4 or f5 etc Whirlpool Cabrio Washer Error Codes Repair Help Washing Machine Diagnostic Test Error Codes Cabrio Bravo Kenmore Oasis
Dec 21, 2016 | Washing Machines
Fault Code At Remote = F5
Indoor Unit PCB
LED1 = Lit
LED2 = Lit
LED3 = Lit
LED4 = Lit
Outdoor Unit PCB
LED1 = Lit
LED2 =
LED3 =
LED4 =
Measuring Of Fault Code = Signal from RC to ID faulty.
Air Conditioning Fault Codes
Feb 28, 2014 | Heating & Cooling
F5 code
The "F5" fault code indicates a water temperature sensor error.
Dec 19, 2011 | Maytag MAH6700AWW Neptune Front-Load...
Fault code F5 & P10 on Ferroli opimax he 31c boiler
my air cond runs for 20 minutes than shows f5 and shut down compressor
Dec 02, 2010 | Heating & Cooling
I have a hotpoint aquarius wmf740 that is showing a fault f--5 and wont empty out the water
Something wrong the pump would prevent the machine draining and generate an F5 code.
Service manual above.
Jun 25, 2010 | Washing Machines
E1 and F5 are on digital read out instead of 500degrees and cleaning
The E1 and F5 is a code that the door latching system is creating a fault. YOu might be able to take apart the door latch mechanism, and recondition it.
Apr 26, 2009 | Kitchen Ranges
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Fault codes
F5- means poer to element relays are disabled in cook mode. Reset it(by removing the power to the unit) and if it happens again, sensor could be intermittent or contact on prb(power relay board) is deffective
Aug 16, 2007 | Jenn-Air JGS8750 Gas Kitchen Range
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
