Question about Royal Procision 7910 Carpet Extractor
Have a Royal procision 7910 will not dispense any water. What are the common things I should look at for a solution?
I have filled with cleaning solution and water, will dispense the cleaning solution and pick up/retrieve water/solution into the reservoir. have tried using the soap off option and no water is release either.
2 Suggested Answers
  • 175 Answers
SOURCE: royal 7910 extractor doesn't dispense soap
You might have a selenoid valve gone bad. That allows the soap to dispense.
Posted on Nov 30, 2009
Bissell carpet shampooer model 9200-9 that is not dispensing cleaning solution
I had the same problem with my Bissell carpet cleaner. I tried all the recommendations but nothing worked. After reading all the blogs, I discovered that many people had the same problem. Fortunately, I still had the receipt from Costco which they honored and gave me a full refund. I was ready to throw it in the trash.
Oct 06, 2015 | Bissell 2X Proheat 9200 rug cleaner
Hose does not dispense cleaning solution, and the cleaner solution will immediately go down to the dirty water tank. It can suction, though. Any tips?
sounds to me as if you have calcium deposits from hard water.
Take your cleaner solution reservoir and fill it with Vinegar and Hot water. Place your machine in a dry bathtub and run it until the tank is empty. Do this a couple times. When it works properly run some clear water through.
Mar 19, 2013 | Kenmore 85930 PowerSpin Deluxe Upright...
Featherlite model 3M-852H
see this instructions:God bless you
Ensure the Dirt Devil is connected to a working power supply if it does not turn on or operate. Check the fuse or breaker and replace or reset as necessary.
  • 2 Empty the dirty water tank if there is little or no suction. Turn off the Dirt Devil and grab the top of the dirty water tank. Push on the latch to release the tank and pull the tank off the base. Remove the lid and empty the dirty water into a sink. Replace the cap and hook the front of the tank onto the machine base. Hook the nozzle on the base so that the nozzle is level with the cleaner base. Push the back of the dirty water tank down and into position.
  • 3 Check the dirty water tank and empty as necessary if there is water leaking from the cleaner. Open the latch on the top of the solution reservoir and pull the reservoir forward. Fill with Dirt Devil brand cleaner to the fill mark. Fill the rest of the reservoir with hot water and close the cap. Replace on the base unit.
  • 4 Make sure the solution reservoir is seated firmly in the base unit if there is no cleaning solution dispensing from the unit. Fill the solution tank with cleaner and water if the level is low.
  • 5 Examine the hose and nozzles for possible obstructions if the carpet cleaner does not seem to be operating correctly. Remove any blockages.
  • Jul 19, 2012 | Vacuums
    No cleaning formula or water is coming out of the dispenser. Any suggestions.
    Just a thought, did you fill the dispenser or just the bladder inside the dispenser with water? The bladder inside is filled with water through the hole on the left side of tank. The waste water then goes in the tank around the bladder, a 2 in 1 deal.
    If you have filled it correctly and are still having problems, please write back.
    I hope this helps. If it does, please place a vote or comment for me. Thanks,
    Handie Andie
    Mar 30, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
    Water not dispensing
    Check the release valve on bottom of clean water reservoir unscrew if needed, once again if your not sure run hot water in the solution tank through the system to help remove old soap residue and always run hot water through to prevent future problems after cleaning carpet and storing.steve
    Jun 06, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
    I have a Bissell ProHeat Turbo. It has only been
    i use white vinegar to clear my line.. and it doesn't hurt the carpet.
    check the little filter on the top of the machine (mine is on the right side) if it is full of lint, etc and blocked it will not dispense or pick up.
    Mar 28, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
    Clean water tank
    Will the water come out of the tank when you depress the valve at the bottom og the tank? The tank sits on a resevroir asm., is the seal on it, black and round. Inside the handle is a rod, so when you squeeze the trigger, it pushes onto the reservoir to release the water, check to be sure it is, if not then you have a problem inside the handle or a bad reservoir asm. is bad.
    Feb 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
    Bissell pro heat cleaner
    This could be due to dried out soap in the works below the dispenser. Try cleaning the hole, putting plain water in the soap dispenser to clean it out further. You could just put some soap in with the water. Be sure to run lots of rinse water through afterward to clean out the heating unit.
    Aug 18, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
    Royal Procision 7910 Carpet Extractor Logo
    80 people viewed this question
    Top Royal Vacuums Experts
    Electroboy
    Electroboy
    Are you a Royal Vacuum Expert? Answer questions, earn points and help others
