Question about Hamilton Beach Kitchen Appliances - Others
Hamilton Beach electric kettle won't shut off automatically. is this fixable?
SOURCE: user guide for hamilton beach espresso model # 40729
If you go to www.hamiltonbeach.com you will find a user guide there for this model.
Posted on Jul 04, 2008
SOURCE: hamilton beach 3 in 1 slow cooker
You can call Hamilton beach Long wait on phone, but YOU CAN ORDER THE Crocks and Lids 1-800-937-8997. You can not order on line!
Posted on Apr 08, 2009
SOURCE: I have a Hamilton Beach scovil gourmet center,
I need a replacement cutting blade for an old Hamilton Beach Gourmet Center and Meat Grinder. The model no. is...174W
Thanks, Rosanna
Posted on Feb 15, 2010
  • 4 Answers
SOURCE: Hamilton Beach Espresso Machine not working
I have the same issue -- machine is NOT clogged. I've torn the think apart, and looking at the way it is designed I am thinking that the pressure relief valve (at least that is what it appears to be) is malfunctioning.
The steamer will work briefly, but runs out of steam almost immediately. If your machine is having a similar problem, I suggest that you open it up and look at how it works (there are two screws on the top under the door for the scoop. You've got to drill out the cover caps to get to the screws underneath -- at least that is how I got them out...they covers are really long plastic plugs and trying to get them out with a thin screwdriver did not work -- but using a drill bit pulled them right out).
I don't know where to find a replacement valve -- sorry.
Posted on Mar 13, 2010
  • 4 Answers
SOURCE: How to open a Hamilton Beach 40729 Espresso machine
Easy to open. It is servicable if you have enough ingenuity and can find some generic parts to fit, but certainly not designed with servicability in mind -- the thing was obviously build as a "throw away". There is plenty of space in there for generic parts, but keep safety in mind since you are dealing with electrical parts that get hot and operate under pressure!
First, you need to remove the little plug caps that cover the two screws under the door for the scoop / emergency tamper (sorry, but IMHO a more substantial tamper is a requirement!). I found that the only sane way to remove these caps is with a drill. Carefully drill into the caps. The drill bit will catch, and you can pull the plug right out.
Next you need to deal with the odd screws. They are triangle, so even if you are a serious electronics guy like myself you are probably not going to have that screw bit. No problem though, use a very small flathead screwdriver that fits as closely in one side of the triangle as possible. It will easily remove the screw (and reinsert when you are done)
Once the screws are out, gently pry the top off as indicated by john. The plastic top should have two catches in the front near the edges, and two catches on the sides about mid-way back.
Posted on Mar 15, 2010
Hamilton beach electric kettle not heating. Stainless-Steel model 40996
Defective heating element is the most likely cause, but doubt you can have it repaired as they seldom make replacement parts as there is little demand to repair them..
Dec 08, 2016 | Hamilton Beach Kitchen Appliances - Others
My Hamilton beach 40996 kettle Suddenly it stopped boiling. The on button lights up and reads temp but never boils. It worked and then suddenly stopped. Any chance this is a program problem somehow?
What a crazy over-complicated kettle!
Disc element kettles do tend to have a limited life that is a small fraction of the lifespan of standard kettle elements. The ones I have had usually only last until the guarantee has expired. To discover whether it is the kettle or the base it will be necessary to use a multimeter to check the supply from the base.
Nov 17, 2015 | Hamilton Beach Kitchen Appliances - Others
How do I fix the lid.
Maybe It is physically damaged, and there is a very slight chance of getting it fixed. Better try the new Hamilton Beach 40880 version. Usually, Electric kettles don't last more than a year if you use it regularly.
Best Electric Kettle Guide Reviews The Grand Kitchen
Jul 21, 2015 | Hamilton Beach 40870 Electric Kettle
Lid is stuck on my Hamilton Beach electric kettle.
That is because we do not have anyone that can help with that problem. Call or go on line to:
Feb 26, 2014 | Hamilton Beach 40870 Electric Kettle
Hamilton Beach 40996Z kettle is displaying an "E1" error code
That appears to be a thermistor problem. The thermistor controls the temperature and is normally not user-replaceable. Call the 800 number for verification and possible replacement of the kettle.
Jan 22, 2014 | Hamilton Beach - 1.7L Kettle -...
How to clean my hamilton beach electric kettle model 40875
Clean the kettle with soap and water just unplug it first and dry it thoroughly afterward
Nov 27, 2013 | Hamilton Beach 40875z 1-liter Electric...
On/off switch is BROKEN,HOW CAN I TURN THE KETTLE
Hanif, buy a new one because it will be difficult to find replacement and may even be costly. Kettles are cheap.
Oct 23, 2013 | Hamilton Beach 40870 Electric Kettle
Need manual
Go to the Hamilton Beach/Proctor Silex web site and find your unit. You should be able to download the manual there, which would include the safety procedures.
Please remember to rate my solutions! Thanks
Feb 05, 2009 | Hamilton Beach Proctor Silex K4077...
Kitchen Appliances - Others Logo
131 people viewed this question
Top Hamilton Beach Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
ken skalski
Are you a Hamilton Beach Kitchen Appliances - Other Expert? Answer questions, earn points and help others
