Question about Kitchen Ranges
Changing liesure model ck100g232c from natural gas to lpg have changed injectors . But where is the flame controlling valve so I can fit the relevant bypass screw.
  • 288 Answers
SOURCE: changing lp heater to use natural gas
Yes. the orifice has a tiny hole in it.It is located at the tip of the pilot before the flame, and at the tip of the injectors. Natural gas and propane molecules are different sizes in the vapor state. The orifice regulates how much vapor comes out. You need to change the orifice in the pilot and the burner injectors for it to work properly. If you don't you will get a very large flame or a very small one, depending which way convert from. If you have the papers from the company that made the heater, they should be able to help you changer over. You also may need to make some adjustment if you are at high altitude, 2,000' or more, as the air is thinner (less oxygen) so the regulator needs to be set to higher volume.
Posted on Mar 10, 2008
  • 222 Answers
SOURCE: injectors for hobs convert from LPG to natural gas
try to call wat brand u have to buy a injector for convertion,big different the injector for LPG and the natural gas,the LPG injector is small hole & the natural is have big hole.
Posted on Dec 02, 2008
SOURCE: gas convertion
stoves have a pressure regulator as the flex line from the house connects to the stove, it's about 2 inches by 3 inches in dimension and it has a knot in the middle and one to the side of it that is to the front of it that second one you can unscrew and put that knot the other way or upside down, that's the position for natural gas, now some regulators do not have it, in that case get one that can do that,or that is for lp and natural gas. then you must close the air a little bit on all the burners the vent is located as the burner meets the valve that supplies gas to the burners. and that vent is part of the burner.
Posted on Dec 12, 2008
SOURCE: Flame on gas hob not correct.
I'm not sure what you mean by a proper efficient flame. I just recently went through an experience I'll relate to you here. I purchased a GE Profile dual fuel range. I can get more specific if you'd like but here's the point. The highest burner on the range was rated at 17000 BTU's. A friend recommended the range to me and sang it's praises. I took delivery of my new toy and couldn't wait to get a pot on the stove to start cooking a long wait for pasta. Twenty minutes later I was finally seeing bubbles! I spilled the water out and measured 12 cups of water into the pasta pot at room temperature. That's three quarts of water. 20 minutes to see bubbles and never would it come to the expected "rolling boil". My experience has always been with electric ranges and I am new to gas but 20 minutes? Something had to be wrong, right? Wrong! Much research later I've found it is common for natural gas to LP conversion stoves to lose a good deal of their oumph when converted. GE as it turns out is one of the most notorious for a serious degredation in BTU output. After exploring GE's site I found that this same stove running under LP gas is rated(for the highest burner) at 11000 BTU's! No wonder I couldn't boil water! Back to the store it went and I am still in search of a stove that will meet my needs. Don't know if this will help you or if this is the same issue you are dealing with but maybe just maybe. Good luck!
Posted on Dec 17, 2008
  • 3361 Answers
SOURCE: can you convert any natural gas hobs to LPG?
They are convertible. Most come with converting parts attached to the interior of the range.
Posted on Feb 21, 2009
Hi, I have Osaka Gas Heater model 43-540.
A natural gas heater can only burn natural and vice versa unless there are changes such as orifice and regulator. They can easily be converted to use either fuel, but you have to know what fuel supply you have, and what the appliance is set up for. Since you've already tried LPG, if it turns out the appliance is natural gas, then replace the spud (burner nozzle) before trying to operate it again. LPG cannot pass through the small nozzle hole in a natural gas appliance.
Nov 25, 2013 | Heating & Cooling
Rheem 300170 HWS service manual
1) Rheem does not post service manuals.
Call Rheem and ask why, since the other big manufacturers, AO Smith and Bradford White do post service manuals.
2) You need new propane gas control valve, and matching combustion parts to fit existing tank.
3) Rheem does not recommend changing gas type, especially from natural gas to LPG.
LPG is higher pressure, and burns much hotter and requires cast iron burner, unlike the lighter-weight metal used for Natural gas burner.
The manifold tube and thermocouple must match the gas control valve, and gas-type and have correct thread for propane.
The combustion chamber and heat transfer surface can also be heavier metal for propane heaters.
Feb 08, 2013 | Water Heaters
Adjust natural gas to lpg
You need a new orifice - the store you bought the appliance from should have the kit. DO NOT use lp with a natural gas orifice - you will get a huge flame!
Dec 18, 2012 | Premier SCK 1000 Kitchen Range
I have a rinnai LPG 6 burner gas heater, it starts fine but wont ignite the middle left burner. It has a blue flame over the top that occasionally radiates down the burner. All the other 5 burners work...
sounds like the injector hole is too largefor that burner have you had it converted reciently
lpg injectors are only half the size hole of natural gas injector, could have a blockage in the injector diverting the gas flow
Jun 09, 2011 | Rinnai Heating & Cooling
Hi im a plumber/gas fitter who has been asked if i can convert a wildcat 410 (a2) ser 1983 from lpg to ng which is currently in use at a crash repair spray booth is this possible?
Yes look up the gas valve part # and find the LP kit for that model number. It will come with new pilot orifice, new burner orifices and the springs to replace inside the gas valve. Remember that natural gas is .08"wc and LP is a heavier gas it needs to be set at 11"wc .You need a manometer to check the pressure before you light it again .Did you know that propane provides more energy per unit volume than natural gas. Heat is measured in BTUs, or British Thermal Units. Propane provides about 2500 BTUs for the same volume of natural gas that only gives 1000 BTUs.
Nov 22, 2010 | Heating & Cooling
329H portable heater Can this be converted to a gas bottle fitting will it be ok what is the use age and how many watts of power to run the electronics etc
You need to convert the unit if you are changing from Natural gas to LPG. This involves getting a full conversion kit for your model and changing burner , gas pressures and electronic settings.
Power draw on high remains at 22Watts. Input is almost identical for either natural or LPG gas as you would expect but running costs depends on how much you pay for your LPG. For example in Australia we use 45kg bottles of LPG, they retails at about A$110 delivered. One of these would last about 170 hours running a 329 on high.About 2 litres of LPG per hour
Aug 26, 2010 | Heating & Cooling
What part do i change when convertin a ranni propane gas to natural gas
I think the part numbers listed in the solution are LPG injectors.The orifices (injectors) needed to change over from Propane (LPG) to Gas (NAT.) would be 2 High Injectors 100F-2031-B-1.80 and one Low Injector 1004F-2036-B-1.95.
Feb 17, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I want to switch my 5 burner kleenmaid CH80x8 natural gas cooking top over to LPG what size jets or injectors do I need. Regards James. Centre burner is for a wok current jets are 50. 78. 85. 62. 95
LPG to natural, natural is bigger than LPG injector exmaple LPG 50=natural 69-
LPG 78=natural 91
LPG 85=natural 115
LPG95=natural 130
PLG 62=natural 85
Sep 09, 2009 | Cooktops
What are the conversion rates from gas to lpg for our Prima LPR851 Hob? so we can fit our kit
wat gas?natural to LPG call the service center of the unit to buy an injectors nozzle want u want(LPG to natural or Natural to LPG)tell the model of ur unit.
Sep 08, 2009 | Cooktops
Injectors for hobs convert from LPG to natural gas
Nov 21, 2008 | Cooktops
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
