Question about Sanyo Car Audio & Video
I have replaced stk412 150 two times but burn out at 90% sound i am disappointed and suggestion please
Reheating
My good friend Rafael, the first thing you have to have in mind is that your scooter, with only 90 miles on it, is still under warranty and you should take it to the dealer responsible for such problem. If not you should check if the cooling fan is running at a reasonable high temperature, if not check the thermal switch that activates the fan and replace it if necessary. Also you should check if the water pump is working, see if there is water running inside the radiator while the engine is running when the engine is cold to avoid hot water burns. If you can't solve the problem with this you need to tune in your engine. I hope this suggestions help you solve the overheating problem on your Outlook
Apr 19, 2014 | 2010 Keeway Outlook 150
I have acer 4530, and it's going mad, my laptop temperature reach 90 -100 degree. it's going burn, please help...thx
Hi neo nietzsch...
Sounds like your cooling fan is faulty...
You need to try and blow the dust out of it using compressed air, by blowing air into the exaust of the laptop and hopefully this will clear your fan of dust and make your laptop run cooler.
If that does not solve the problem then your going to have to take your laptop apart and replace the cooling fan as it is defective.
Please take time to rate me
Aug 30, 2011 | Acer Aspire 4530-5889 Notebook PC
Oven does not heat up
Hello and sorry to hear about your problem.
It sounds like your oven heat element is burned out or your oven control knob is defective. these are the only 2 issues that can happen 90% of the time, or a broken or worn wire someplace.
I suggest you can in a service person. If you live in the Denver Co area, I can help you.
I have tried to help you. Please help me by Vote/Rate this response. Thanks and good luck.
Dec 21, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I got a Kenmore 90 series model#11078932792,all sensors looks oK continity,the ignater lights up but it doesn't open the gas to fire it up,I replaced the gas coils and still the same, this is the third...
hi sounds to me like we have a problem with the flame sensor. This is mounted to the side of the burn tube. With an ohms meter check it for condinuity, It should read infinate. If as i suspect it shows open you should replace it. If you have any other questions please fell free to comment again. Mike
Dec 09, 2009 | Kenmore Dryers
The pot does not heat the water
sounds like the heater coil is burned out. Might be time to replace the coffee maker.
Nov 14, 2009 | Bodum Santos 3000 Coffee Maker
My smartset clock/radio justed stopped working shortly after the 90 day warranty. I don't know if replacing the CR 2430 lithium battery will resolve the problem, but I no longer see the time. The...
I just experienced the same problem this week.  Don't waste the money on the battery as it did not help...still no lights.  I'm very disappointed as I'm, also, out of warranty and I really liked this clock.
Aug 07, 2009 | Emerson Smartset Clock Radio
Good evening. i have a jvc gz-mg77aa/ag/ah/as GZ-MG67AA/AG/AH HARD DISK CAMCORDER. I HAVE HAD IT APPROXIAMATELY 3 YEARS. I STARTED VERY WELL WITH IT. VIDEOING AND BURNING TO A DVD AFTER EDITING. ALL OF A...
can you copy your images to your hard drive. if you can then you should be able to burn a disc.it sounds like the software for the camera isn't working try to reload software and make sure the battery is full charged . sound like the dvd burning in the camera went south.
Jan 03, 2009 | Cameras
Welbuilt bread machine ABM3900
I have the same problem with a B1650 Burned all the time
Dec 17, 2007 | Welbilt ABMIL2P Bread Maker
Car Audio & Video Logo
Top Sanyo Car Audio & Video Experts
Colin Stickland
Colin Stickland
xxxxxx xxx
Are you a Sanyo Car Audio and Video Expert? Answer questions, earn points and help others
