Hello my name's Mark I have a Browning B80 it will not load the first round when carrier button is released.it will if I push small button on bottom an run an cycle fine. Any idea ? Broken part?
SOURCE: Front Loading Duet Washer will not start
I've got same problem, with the door stuck shut, door lock NOT on, water trapped in the machine, and still no solution. 8 pages of messages and no solution.
Posted on Mar 14, 2008
Krazytech
  • 725 Answers
SOURCE: Frigidaire Front Load Washer FWFB9100ES1
Diagnostic Test:
The diagnostic test is performed by using the Program Knob. To START THE TEST:
• On non-digital display models, turn the Program Knob to start position, Drain/Spin.
• On digital display models, turn the Program Knob to start position, Touch Up. (NOTE: If the model has a timer dial that
can be rotated 360°, turn the Program Knob to start position, Drain/Spin.
• Press Pause Cancel to turn off LEDs.
• Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then
release buttons.
Posted on Apr 20, 2008
  • 14 Answers
SOURCE: ThickToasted Sandwiches not browning or cooking on the bottom
There are a number of possibilities. First clean the cavity with approved non-caustic oven cleaner. Do not overuse this chemical. You need to remove all the crumbs at the back of the cavity. Use a putty knife if you have to. Check error codes by turning oven off and pushing 4 & 6 on the keypad at the same time to check for errors. These ovens are not like any other oven. You can't just guess and change parts. Its about like telling someone how to fix their own plane and hoping it works.
Posted on Jul 31, 2008
SOURCE: washer runs when timer dial turned though ON button not pushed
Problem solved by ourselves! It was NOT in the circuit board (brain) of the machine. It was NOT in the door locking assembly as others would lead us to believe. It WAS the on/off switch on the control panel--part number 22002560 - a $22.00 problem fix.
Posted on Jan 11, 2009
  • 125 Answers
SOURCE: External Battery latch needs replacing. The small
try to order it in the closesed repair shop for camcorders.
Good luck
Posted on Sep 24, 2009
Troubles Sony ps-b80 1)When power sw is on,red
try getting itr cleaned by a reputable repair shop may just b dirty
Oct 02, 2013 | Audio Players & Recorders
Browning BAR fires a round reloads next round but will not fire it. no firing pin hits on primer of 2nd shot
Check that the bolt is completely closed/engaged. If you are using reloads run them through a checker to see if they are sized correctly.
Sep 15, 2013 | Warne Browning BAR Barii Mark II BLR...
Need to replace the cmos battery
Hello that`s easy.
Open the case, and look for a small round shinny battery.
Press the release button, and the battery will pop out.
If not, use a small screwdriver, but don`t use force:
Here is a picture, how it looks like:
The battery type is a CR 2032, 3 volts watch type.
Insert the new battery the same way.
When you remove the battery, the cmos/ bios will be cleared, and the bios needs to be setup: clock, date, boot settings, etc.
A pc repair shop, can help you with renewing the battery.
Good luck
Feb 04, 2013 | Computers & Internet
Trigger not releasing on browning buck mark
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to factory installed systems not add on aftermarket systems.
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
Oct 18, 2012 | Cars & Trucks
Russell Hobbs 18140 Toaster The bread carrier will not stay down during toasting. Insert two slices of bread into bread carrier and push down to lock. The right hand side carrier does not stay down. The...
Constant use can lead to crumbs clogging the path of the lever. Try opening up the bottom panel, by pulling on the metal tab to release the plate (and crumbs!) over a trash can. Also try flipping the toaster upside down and, very gently, shaking the crumbs out. if that doesn't work, you can try checking the toaster's browning dial. This might be too low to activate the heating coil. Try dialing it up, and pushing the lever down again. I hope this helps. You can check our post on Best ways to use a Toaster oven. Best ways to use toaster oven 2017 ultimate guide Kitchenutilitypro
Sep 28, 2017 | Kitchen Appliances - Others
My grand prix wont acknowledge the fact that its in park an at the same time wont release my key. What should i do?
Look underneath the steering wheel on the steering column. See if there is a small round plastic plug. If there is,, pop the plug out with a small screwdriver, there should be a button to push that will release the key. If you can't see a button. push a small phillips head screwdriver up into the hole and see if the button is further up. The neutral safety switch, or the transmission/ignition interlock is probably gone bad.
Jan 25, 2011 | 2002 Pontiac Grand Prix
How to load ink catritridge #4&5
plz follow the steps below:
Step 1 Locate the "On" button located on the top right side of the Lexmark 2600 Series Printer Scanner. Turn the unit on by pressing and releasing the "On" button one time.
  • Step 2 Raise the scanner unit until it locks into place. Allow the print cartridge carrier to move to the loading position. Wait for the print cartridge carrier to stop moving.
  • Step 3 Locate the color print cartridge in the carrier on the right. Release the empty color print cartridge by pressing down on the cartridge carrier latch. Raise the cartridge carrier lid. Remove the empty color cartridge by pulling it straight up. Place the empty cartridge in the plastic bag and set aside for recycling.
  • Step 4 Remove the new color cartridge from its packaging. Remove the protective tape from the nozzle and connector on the back and bottom of the color cartridge. Dispose of the protective tape.
  • Step 5 Install the new color cartridge into the right cartridge carrier slot. Close the cartridge carrier lid. Press down on the cartridge carrier lid until it clicks into place.
  • Step 6 Raise the scanning unit slightly. Release the scanning unit support. Close the scanning unit.
  • If u find this post helpful, then plz vote it.
    Thanks
    Apr 27, 2010 | Lexmark X2600 InkJet Printer
    Forgotten userid and password for netgear router
    At the back, or bottom of the unit there should be a small button,it is a round and quite small, you will need a pen or somthing with a small point to push it in, that should return all the setings to factory default. Therfore changing the the user settings to its original. The user name and passwor should be written on the bottom of the router.
    Jan 29, 2010 | NetGear DG834G Wireless Router
    Ink light of my tx101 keeps blinking
    Hello, Amit.
    From FixYa, give this a try:
    Lift up the scanner bed (top part) of the printer to expose the cartridges.
    Push the red triangle button once. Wait for the cartridge carrier to move to the middle. On the housing of the printer (the non-moving part), there is an arrow that will point to the empty cartridge.
    Push the red triangle button again to see if the next cartridge is empty. Repeat this step, noting which cartridges are empty, until the cartridge carrier moves to the right. Now you can replace each cartridge that is empty.
    After replacing the empty cartridges, push the red triangle button again, and the carrier will begin moving back and forth (cleaning itself). Once it stops, it should be positioned on the far right side.
    Lower the scanner bed to "close" the printer. The ink light should go off and you should be able to print.
    Hope this helps.
    Oct 04, 2009 | Epson Stylus Multifunction Inkjet Printer/...
    Washing Machines Logo
    Top Washing Machines Experts
