These lights are flashing on the soak cycle - Washing Machines
Why is the SP light flashing when the machine has filled with water and is ready to go
sp is the code for stand by or pause
so if you have set a soak period then it will stay there until the soak period has finished
if it is sp and you have pressed pause/start extra time the machine is in pause mode until you press start again
Sep 29, 2016 | Simpson Washing Machines
The coffee grounds lihgt and the descale light flash after I push the brew button on my seaco odea giro.
The sensor inside the water container has either mineral build-up (scale) or a bit of coffee grounds stuck to it.
  1. Run a cycle with a retail coffee maker "cleaner solution" to clean the water reservoir, or let vinegar soak inside 5+ hrs.
  2. In both cases, turn unit upside down and power wash reservoir 2X to dislodge deposits that have loosened during the soak.
  3. Make sure to run a few cycles of plain water thru coffee maker before making the next batch of coffee.
Dec 06, 2015 | Saeco ODEA Coffee Makers & Espresso...
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
Why are the clothes still soaking wet after a wash cycle.
Hose could be clogged up.Take hose off and see,maybe run with hose off for a sec.
May 22, 2015 | Washing Machines
Door locked with flashing red light on model W10578789
This might work try unplugging it for about 45 -60 seconds and see if it clears the problem. The red light is some type of warning and I would be safe in saying it is a safety device gone bad. Sorry I couldn't be of more help.
Col. Dana Gillespie
Aug 14, 2014 | Whirlpool Duet Steam WFW9550WL 27"...
How to repair - no water is entering the dish waterr
Your dishwasher is equipped with a safety system which is able to detect any operating problems. These anomalies are reported by
one or two wash cycle indicator lights "E" will flash rapidly.
Any flashing combination of LED diodes (Intensive wash, Regular wash, Eco wash, Rapid wash, Soak and Crystal care) means different error code. Take a note of which lights are flashing?
If you have problem with fill water than following two LED should be flashing.24428775-0h3kxpflbez5mdeb5anq3st4-3-0.jpg
In this case could be:
  • Water valve disabled
  • Turbine disabled
  • Control board faulty
Dado
May 15, 2014 | Ariston Technologies LL65 Built-in...
MIELE W412 PREWASH INDICATOR FLASHING
If your PreWash is flashing then you have a pressure problem. You can dry using a washer machine cleaner or doing a hot cycle with white vinegar. If that doesn't help the electronic would have to be changed.
Jan 08, 2012 | Miele W412 Front Load Washer
Zanussi ZWC1300W Front Load w'Machine
is it spinning during spin cycle
your timer may have gone
Jan 18, 2009 | Zanussi ZWC1300W Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
