Hi. Need some help with my Defy DDW174 dishwasher.
Machine does not start as it should, on start it should add water but only a noise is heard but no water. I have added water manually and then it seems to run the full cycle adding water later by itself as it should. It however starts leaking water almost three quarters of the cycle further from the bottom somewhere. Some assistance will be appreciated.
  • 833 Answers
SOURCE: dishwasher not starting cycle
aslav...Does it do anything at all and how do you know it has power? Find and turn the breaker fully off and then on to reset it.
You don't say how old the unit is. If it has a mechanical timer, is it one you can turn? If so, turn it. If it starts to do something...this gives you an idea what's happening. Try a different cycle.
The first things a timer 'authorizes' in a dishwasher are: water in and start of pump motor. If neither is happening and power is on to the connection under the unit (use a voltage tester you get from the hardware store), then replace the timer. My bet: no power.
Posted on Dec 09, 2007
  • 116 Answers
SOURCE: siemens hydrosensor dishwasher SE25A091GB/22
If you are still trying to sort out this issue try the following.
From what you say then it is most likely the aqua sensor on the side of the dishwasher. The gurgling sounds that you hear are likely the drain pump running and the un-drainable water sloshing in the sump.
Verify that there is actually water going to the dishwasher( Basic step but often overlooked)
Next the inlet valve will have to be checked. This is the part where the water line from the house connects to the dishwasher, under the toe/kick panel. Remove power from the dishwasher. Disconnect the dishwasher electrical connections (2 wires) to the inlet valve and connect it (carefully to 110 V power) using a jumper wire. With 110V power the valve should open and water will flow into the dishwasher, if not then the fault is in the inlet valve.
If this checks fine then the fault is likely in the aqua sensor...
On the outer left side (viewed from front) there is a panel, Behind this panel there is a small clear(of light blue) plastic mechanism with hoses and wires attached( There is usually a yellow disk at the top about 6cm in diameter) this is a float and sensor assembly there is tells the control the water level and works as an emergency drain if there is an issue. There will be a red stick protruding downward to the base and a Styrofoam float on which the stick rests. This is a pan overflow sensor if the stick is too high the unit will go into drain and cut off the fill valve power. The yellow disk is a diaphragm which senses water height. This unit can become stuck with wear and hard water.
Posted on Jul 28, 2008
  • 6 Answers
Draing Problems:
To fix your draining problem you need to check the air gap(if you have one) , check if there is voltage going to your drain pump during the draining cycle. If there is voltage coming to your water pump and the dishwasher is still not draining then the problem could be a clogged drain hose, a clogged air gap or a bad drain pump. if there is no voltage detedcted on the drain pump during the drain cycle, then it could be a water level-switch/solonioed , wiring, or a control board problem.
Good luck.
Mr Engineer
Posted on Aug 11, 2008
SOURCE: leaking from the bottom a lot, immediately when I start the cycle
I found this post on another website. Hope it helps:
"Six torx screws securing the fine mesh filter just below the lower spray arm. Make sure they're all tight. Bit size is T 20 also, check for damage to the mesh screen. What happens when those screws are loose is water pressure seeps under and creates a tidal wave sort of effect by spraying water forward instead of thru spray arm...long shot, but I've seen it 50 times."
Posted on Oct 30, 2008
  • 734 Answers
SOURCE: Dishwasher leaks water
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you.
But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly.
You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues
to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
dishwasher, and replace the valve.
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Posted on Dec 12, 2008
I was low on water in my 2006 Cadillac DTS added water started the car and and heard a clicking noise and a pop and all of the oil start leaking out what could it be
You popped something when car overheated. Sure it is not water(coolant) that is leaking? If so check your water hoses and connectors.
Sep 01, 2017 | Cadillac Cars & Trucks
Why doesn't it work?
is the blue light a loading light ???(light that shines inside too allow you too see ) next all washers mfg after 2010 have a drain cycle after there first started , some of these can be mighty quiet almost imperceptible to hear , if you allow it to continue it will next add water and start to wash (if working properly) , the drain cycle was added because it was found out that everyone was prewashing dishes (silly I know) and then adding them to machine, this ,made for a lot of water runoff and then machine wasn't adding enough water for a total wash cycle , so mfg all figured it best to add a drain cycle first to all there washers
Sep 03, 2015 | Dishwashers
What would cause the washing machine to start running when water was added to it ? Now it won't run a cycle
why are you putting water from a dehumidifier into a washing machine??? you might need to talk to a professional
Apr 25, 2015 | Maytag Washing Machines
The dishwasher did a full cycle three days ago yet today it is just beeping and making gurgling noises now and will not start Any ideas as to what the problem might be
Check whether the water flow to the machine is OK. Try adding water
to the wash chamber manually and run the cycle. If the noise stops
it must be air trap. The machine should complete the wash also after this.
Still the problem continues the water pump to be checked.
Oct 04, 2010 | Dishwashers
I have an itex easy set 16' by 36" pool with an automatic salt water system and I lost the owners manual so I do not know how much salt to add. I also live out of town and use well water and I've heard I...
with well water you need to ad a metal reducer whatever your local pool shop carries and initially shock your pool before you try starting up your system be sure to filter for at least 24 hours after adding your salt and trying to generate chlorine
Also here is a link to find your recommended amount of salt 16x36 will have different amounts of water if it is a blow up ring pool and a straight up wall look at the manuals in this link
Jun 08, 2010 | Intex Automatic Salt Water System for ...
KUDK01ILBS5), SN: FR2702809. Have used this machine 6 years and just recently experienced noise that I eventually traced down to a bad recirculation pump bearing that failed due to a small leak in the...
The water level in the machine should be slightly under the heat element. The float you refer to is only for overfill and should not be activated if the machine is filling properly (the water level should be lower than the float switch activation point).
The resistance range on the inlet valve is 890 - 1080 ohms
The machine fills on time and there is flow restrictive washer in the valve, if it becomes contaminated the water level will be insufficient.
Let me know if you have questions.
May 22, 2010 | Dishwashers
Hi, we have a Electrolux DX302WB/03. It has worked ok for a few years. The problem now is when we turn it on it make a noise like it is starting then a small amount of water noise is heard then nothing....
Check the water inlet flow. Clean the strainer attached to the machine end of inlet hose.
Add water from the front to the wash chamber 10 liters and run the m/c. It should become alright if any air lock inside water pump.
Apr 12, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
Maytag a112 manual on how to add bleach AND fabric softener
Choosing Your Detergent, Bleach, and Fabric Softener..
Learn what the different items you need to wash your laundry.
Liquid Laundry Detergent and Fabric Softeners
When using liquid laundry detergent, you do not want to poor it directly on your laundry. The dyes in the liquid laundry soap could stain your clothing. You will want to start your washing machine and add the liquid laundry soap while the water is filling the washing machine.
You then can add your laundry once you have about and eighth of the washing machine tub filled. This will ensure your laundry doesn't become stained by the detergent. You should only add the amount that is poured into the cup to the fill line. When you add more, you could find yourself wading through mounds of bubbles overflowing from your washing machine.
The same reasoning applies to liquid fabric softeners. However, liquid fabric softeners are added to the washing cycle after the initial washing cycle is finished. You will want to add the fabric softener once the washing machine has filled with water and started to agitate. This keeps the fabric softener from touching the laundry and will work it into your clothing better.
Powdered Laundry Detergent
You will want to add one cup of loose laundry detergent to your washing machine in the same manner you would do the liquid laundry detergent. By doing this, the powdered laundry detergent will dissolve easier.
When adding bleach to your laundry, there is a small triangular cup in the corner of your washing machine. By adding one cup of bleach into that dispenser, the bleach will be added to the laundry at a precise time during the wash cycle.
Setting Your Washing Machine
Most washing machines have three or four cycles. For instance, the Maytag Washer I have has four cycles, regular, permanent press, delicate, and soak.
Regular Washing Cycle
The regular cycle is used for the following types of clothes and other apparel:
• Jeans
• Towels
• Blankets
• Sheets
• Quilts
• Bedspreads
The soil types for this cycle are heavy, normal, and light. This means clothes or other articles that are lightly too heavily soiled should be washed in this cycle. This is due to the washing cycles can be set from a minimum of eight to fourteen minutes maximum. You can use all three of the water temperatures in this cycle.
1Permanent Press Washing Cycle
The permanent press washing cycle is used on the clothes that may or may not need to be ironed.
Such as:
• Blouses
• Shirts
• T-shirts
• Under garments. This would be your unmentionables and socks.
• Jackets
• Sheets
• Baby Clothing
The soil types for this wash cycle are normal and light. The washing times for the permanent press cycle are six minutes to ten minutes. You can use all three washing temperature modes for this cycle as well.
Delicate Washing Cycle
The delicate washing cycle is normally used for sweaters, cotton, silks, and other fabrics that need to be washed with care.
The soil types for the delicate cycle are normal and light. The washing times for the delicate cycle are four and six minutes. It is best to wash your delicate clothes in warm or cold water. Always wash clothing that is more than forty percent cotton in cold water to prevent shrinking.
Soak Washing Cycle
The soak cycle would be used for heavily soiled clothing, such as, football and baseball uniforms. This will help rid the uniforms of caked on mud and grass stains.
You can also use this cycle if you wish to only bleach your white's once a week or once a month with bleach.
Washing Your Laundry
Choose the cycle you need for your laundry. Add the laundry detergent, fabric softener, and bleach (remember regular liquid bleach is for white clothes only.) Start the washing machine and let fill to dissolve the dry detergent or to mix in the liquid detergent.
Now add your clothes to the washing machine. Clothes the lid so the washing machine will continue to wash your clothes.
If you are using a Laundromat, put your clothes in the washing area and shut the lid or door. Add your detergent and other cleaning items in the correct compartments. Put in the correct amount of change so the washer will start.
Thanks for contacting
Nov 13, 2009 | Maytag Washing Machines
Started a load of laundry water filled fine started washing and agitating and then heard a weird noise like something got stuck and went and it sounds like motor is running but will not agitate or spin and...
Please give a make and model of washing machine. I suspect that something has stripped out between the motor and the transmission, which is the noise you heard.
Jan 24, 2009 | Washing Machines
Washing Machines Logo
159 people viewed this question
Top Washing Machines Experts
