No remote, want to change dvd movie tracks? - Televison & Video
How do I change the DVD audio back to hearing the voices and not just background noices on the movie
Most voice tracks come through the center channel. If you don't have a center speaker hooked up, then turn off or change the surround mode so that the player will put the voice tracks back to the front speakers.
Nov 15, 2016 | Televison & Video
For some reason, I get audio for the visually impaired when i play a DVD. The original sound of the DVD plays but an additional narrative (describing each scene) plays as well. The DVD is a recent...
Generally, remote controls for DVD systems have a button labeled "Audio". This button changes which audio track you will hear during the movie. Common tracks include English, French, Spanish, Commentaries, and occasionally Audio for the Hearing Impaired.
It seems odd for the latter audio track to be default, but clicking the Audio button until you have the plain English track should work. I would consult the manual if you have it on hand to see if your system is capable of remembering which track to start on.
Hope this helps.
Jun 13, 2011 | Protron PDS-2315 Theater System
Try ebay for universal remotes or if you require the original type, you may have to track down an agent for your make of TV. Prices vary.
Hope that helps.
Mar 14, 2011 | Element Electronics FLX2211B 22 in. LCD TV
I just got a blu-ray player and when I play some of the movies it will not come through the speakers. I have a surrond sound system that plays well on some movies and also plays the bonus features,but not...
DVDs have more than 1 sound track on them. That is to say different sound codings. You may well have to select the correct sound track on the dvd to suit your surround sound sysyem, this will be found in the options screen of the dvd (thestart menu).
Failing that, you may need to change the sound coding on your surround system to suit a particular film.
Jan 15, 2010 | Televison & Video
My dvd/stereo won't play dvd's unless grounded to emergency brake
There are a few types of override procedures for Kenwood.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
"TRACK UP BUTTON" for 3 seconds.. and youre done.
Aug 24, 2009 | Jensen VM9510 Car DVD Player
Problem with voice sound on DVD player FX900 Sony. Can hear audio (music) fine but voices are muted.
you have probaly changed audio tracks on the dvd,just go to menu and audio,and pick another audio track,a lot of DVDs come with more than 1 audio track (im talking the actual DVD not the player
Aug 17, 2009 | Sony DVP-FX810 Portable DVD Player
The movie in the dvd player repeats itself after it has been finished once. How to stop?
Look on your remote for a button that looks like a loop with arrows in it. pressing this repeatedly will cycle repeat movie on or off, may also give the option to repeat chapter/track
Mar 25, 2008 | Televison & Video
Muffled voice track on JVC TH-C5
It's an audio setting you will need to change. some movies are decoded in dolby and some by dts. This means you will have to adjust accordingly depending upon the source of audio in the movie. a double d is dolby's trademark and dts is regesterted trademark for the company "digital theater sound." The icons are on the dvd usually. Anyways, find the set up button on the remote control and use the directional arrow keys on the remote; up, down, left, or right to adjust for best sound. the thc5 will have the most function on the surround settings, movie, music, and all st. try a sequence, than repeat until desired sound is heard... good luck
Dec 26, 2007 | JVC TH-C5 System
Televison & Video Logo
Top Televison & Video Experts
