Question about Vizio Televison & Video
I have a vizio pdp50x4 p50hdtv10a model plasma tv that went black picture. Opened it up and there were a bunch of bad capacitors on the power board. Replaced those and the tv would turn on then off.
Plugged up in rgb input and stays on but no picture. Tested fuses and voltage is within 1 volt of the published vs and va voltage levels. I notice on the logic board 4 green leds that LLC got up differently but still no light. The boards on either side has a very slight buz. Before it went dead sometimes when you hit the power button it would turn off but then turn back on about 10 seconds later. Also sometimes the power button on the tv wouldn't work. Remote would always work. Which board does this sound like? Even though voltage is reading correct can the power supply still be a problem?
    Top Expert:
  • Vizio Master
  • 74,459 Answers
Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Dec 31, 2016
My Vizio p50hdtv herd spark, and TV went black, no picture no sound
Check and replace the main power regulator board as card basis. It has damaged.
Oct 11, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio tv - remote does not work at all
Good day!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 25, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
I have a 50" vizio
inverter board is not working, check dry soldering, bad capacitor or fuse
Aug 24, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
I have a Vizio 50"
Good day!!!
That problem is usually cause of bad inverter board or T-con board also there is the possibility that you have failing capacitors....
If your TV is totally black even back-light the problem is inverter board..please try to replace it to fix your TV.
If your have back-light but no image comes out...The problem could be on the T-con board..if that so please replace it...
This is for bad capacitors...
5. Some of the capacitors not bulged so its better if have a capacitance meter..
Look at the label capacitors...That is the sample image..
I hope this solution will be helpful...Thanks for using fixya...
Aug 17, 2011 | Vizio VX42L 42 in. LCD TV
Vizio P50HDTV10A 50 in. HDTV Plasma Television The picture started flashing in and out and then the picture went black. The power light is on, has sound no picture. only 2 yrs old
I repair a tv just like yours with same problem. I replace the x and y sustains boards. If you do replace them, please make sure it is disconnected from power outlet.
Aug 26, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio P50HDTV10A TV went pop now has a black picture
Don't know which boards Z or Y have dead capacitors pop open,take ur tv aparts check boards that have pop opens parts or burn marks on them.Replaced that board will solved ur problems.Tries Shopjimmy.com,Ebay.com to buy refurbish boards for the replacement.
Mar 22, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
My vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
Jan 08, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio plasma. screen went black, and the power light went out.
Sounds like the power suply went. I don't know that model off the top of my head, but you might find a replacement here http://www.electronica-usa.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=EU&Category_Code=PLA
-=/ Daft Tech /=-
Oct 26, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio P50HDM No Picture/No Sound
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Televison & Video Logo
47 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
