Question about Coffeemaker Coffee Makers & Espresso Machines
My coffeemaker won't turn on. It's about a month old. The lights are on but won't brew.
Plugged in, lights are on, but won't brew coffee
SOURCE: Is their anyway to turn the beeps off when the pot of coffee is done?
Disconnect the beeper.
Posted on Jul 25, 2007
  • 13 Answers
SOURCE: The "Brew Pause" feature doesn't work
It's the spring part on the bottom of that black basket. Now that it's broken there's really no fixing it. The only thing to do is call the manufacturer (800-726-0190) to get a new brew basket. They are open on weekends, so you could call them today and see what they can do (brew baskets are covered under the 3 year warranty, btw). Just have your model and serial number and you can probably have a new one ordered in less than 5 minutes. :)
Posted on Aug 29, 2009
Testimonial: "Very helpful suggestion to call the manufacturer. I was told to try the self-cleaning, as calcium deposits could be the problem. worked like a charm."
SOURCE: Brew shuts off before brewing has ended or warming
I called the company about the "shutting off after a brewing cycle" problem and they had me turn the dial to "auto off" and set the time to two hours. You do this by holding down the "hour" button until it blinks, and then press it again until you get the desired hours that the warming plate will be on. Hope this helps.
Posted on Dec 16, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Our office has a Gevalia Deluxe coffeemaker. It
Most likely the cycle thermostat that turns off the heating element has failed. It is supposed to reset after the it senses the water temp below 130 deg. If it did not reset or has failed it will not turn on the heating element but the clock will work fine.
By the time you ship the unit to a repair center with parts and labor and get it returned to you the cost would be as much as a new unit.
Thanks for using FixYa.
Kelly
Posted on May 13, 2010
Testimonial: "Thank you."
SOURCE: A couple of days ago, coffee maker turned it self
spoke w/ Cuisinart. Unplug unit for 1 hr, then plug back in, reset clock & Auto Off setting. This resets the unit back to the factory settings.
Posted on Sep 14, 2010
Testimonial: "great it works!!! thank you so much!!!!!"
My mr. coffeemaker beeps 5 times and doesn't brew the coffee I just purchased this coffee pot last month aug 2014. what could be the problem
I see two problems that you've described.
First, you have a bad empty-reservoir sensor. Mine went out on my first Mr. Coffee within the first month also. The purpose of the sensor is to trigger the beeping to simply let you know when the coffee is done. The coffeemaker would normally work fine otherwise.
Second, you have a bad heating element. This is the core function of your coffeemaker and renders it useless for anything but a nice warming plate.
I recommend replacing the coffeemaker.
In the future, make sure you do not add water to the reservoir unless the coffeemaker has been turned of for at least five minutes. This will help prolong the life of the heating element.
The heating element will naturally degrade over time. But, it can incur sudden damage when the reservoir is refilled with water too soon - while the element is still hot. Because of the simple design, if the coffeemaker is on, then both the warming plate's heating element and the reservoir's heating element are on. So, after a brewing cycle is complete, the reservoir's heating element stays on. Without any in the reservoir to keep it cool, the heating element superheats. So, if water is put in the reservoir while the coffeemaker is on or before the element has adequately cooled, the sudden burst of steam from the water contacting the element can be quite violent.
Sep 21, 2014 | Mr. Coffee Coffee Makers & Espresso...
Coffeemaker shuts off in the auto brew cycle
Your Cuisinart coffee maker probably is defective, though new.
Jan 10, 2018 | Cuisinart Chw-12 Coffee Plus 12-cup...
Dcc-1200 coffeemaker self clean light blinks
There is no self clean button on mine, and I have done the above with vinegar and water......what next?
Nov 11, 2011 | Cuisinart DCC-1200 Coffee Maker
Why is my coffeemaker taking more than 4 minutes to brew a pot of coffee
  1. Be sure that your SPEEDBREW® Coffeemaker brew control dial is set to 'Brew Regular' when brewing regular coffee. Please note that using the 'Brew Decaf' setting will slow the brewing process. It is recommended that the 'Brew Decaf' setting be used when brewing decaffeinated coffee.
  2. Your SPEEDBREW® Coffeemaker may need to be cleaned.
Sep 02, 2011 | Keurig B50 Coffee Maker
Why isn't my coffeemaker brewing coffee?
Plz try the following steps ..hope it serves ur purpose:
  1. Make sure the coffeemaker is plugged into a working 120V electrical outlet.
  2. Make sure the power switch is turned on.
  3. Make sure the water reservoir has water in it.
  4. The unit may require cleaning to remove mineral deposits that build up over time.
  5. If the coffeemaker is equipped with a clock and the clock is working properly but the unit will not brew, please contact the nearest Authorized Service Center.
Thanx
Aug 27, 2011 | Gaggia Titanium Espresso Machine
This morning when my wife went to make coffee. The clean light came on. we couldn't get it to shut off. She went through the clean cycle.The light came back on again. What should we do ?? Mr. Coffee...
I know this sounds like a pain but it takes a while to get that silly light to stop.
If you have problems call the 1-800 number below.
Decalcifying your MR. COFFEE® Coffeemaker Minerals (calcium/limestone) found
in water will leave deposits in your coffeemaker and affect its performance. It's
recommended that you regularly remove these deposits using MR. COFFEE® Cleaner
or vinegar. MR. COFFEE® Cleaner is available at many retail stores or by calling the MR.
COFFEE® Consumer Service Department at 1-800-MR COFFEE (1-800-672-6333).
1. Follow package instructions to prepare one batch of MR. COFFEE® Cleaner. Pour the
mixture into the water reservoir. Before decalcifying, remove the water filtration disk
from the machine.
NOTE: 4 cups or 20 fl. oz. of undiluted, white household vinegar may be used as a
substitute for the cleaner.
2. Place an empty MR. COFFEE® 10-12 cup basket-style paper filter
or MR. COFFEE® permanent filter into the filter basket and slide
the brew basket in place.
3. Place the empty decanter back in the unit.
4. Press the CLEAN button until the CLEAN indicator light turns on
(Figure 9). For your convenience the cleaning cycle is automatic.
The entire cycle will take 45-60 minutes to complete.
During the cleaning your coffeemaker will:
a. Slow brew approx. 3 cups of cleaning solution.
b. Pause for 30 minutes (the CLEAN light will remain on to alert
you that the process is active).
c. After 30 minutes, your coffeemaker will brew the remainder of the cleaning
solution.
d. When complete, the CLEAN light will turn off and your coffeemaker will turn off.
5. Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean, fresh water.
7. Place the empty decanter back on the coffeemaker.
8. Remove and discard the paper filter used during the cleaning cycle. If a Mr. Coffee®
permanent filter was used during cleaning, remove it and rinse it thoroughly before
replacing it in the filter basket.
9. Begin brewing and allow the full brew cycle to complete.
10. Repeat steps 5 through 9 one more time.
Mar 27, 2011 | Microwave Ovens
The ''clean'' light is on my cusinart coffee maker
Let a half caraffe worth of distilled white vinegar sit in the water reservoir for about an hour. After the hour, turn the coffeemaker on and let it brew the vinegar until a small amount of vinegar appears in the caraffe. turn the coffeemaker off and let it sit for an additional 20 minutes. Then turn the coffeemaker back on and let it brew the rest of the vinegar. Then run a full caraffe of plain water to flush the vinegar out. If the self-clean light remians on - unplug the coffeemaker for 20 minutes or longer - if you unplug it for any less than 15 minutes, the coffeemaker will not reset itself. You should be good after that - as long as you do some sort of vinegar/water cleaning once a month henceforth.
-Tha Mp3 Doctor
Mar 13, 2009 | Cuisinart Coffeemakers
Incomplete brew
Sometimes you have to do the decalcification two or three times. Then, monthly after that.
Cuisinart Coffeemaker Decalcification Process
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Jan 01, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Kenmore Coffee Maker
If it's only 2 months old, I would suggest taking it back to Sears and getting it replaced under warranty.
Geno
Mar 10, 2008 | Kenmore KBC12 Coffee Maker
How do I use the self-cleaning option
According to the manual for IS series Mr. Coffee for programmable models:
1. Prepare one batch of Mr. Coffee coffeemaker cleaner. Pour the mixture into the water reservoir. Remove the water filtration disk from the machine.
4 cups or 20 oz. of undiluted, white household vinegar may be used as a substitute for the cleaner.
2. Place an empty paper filter or permanent filter into the filter basket and close.
3. Place the empty decanter back in the unit, centered on the warmer plate.
4. Press SELECT button until the red CLEAN indicator light is illuminated. For your convenience the cleaning cycle is automatic. The entire cycle will take 45-60 min to complete. During the cleaning your coffeemaker will:
  • Slow brew approx. 3 cups of cleaning solution.
  • Pause for 30 min (the CLEAN light will remain on to alert you that the process is active). At the end of the pause period your coffeemaker will beep.
  • After 30 mins your coffeemaker will brew the remainder of the cleaning solution.
  • When complete, the CLEAN light will turn off and your coffeemaker will automatically beep and shut off.
5.Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean fresh water.
7. Place the empty decanter back on the coffeemaker, centered on the warmer plate.
8. Remove and discard the filter used during the cleaning cycle and replace it with a fresh paper filter. If a permanent filter was used during cleaning, remove it and rinse it thoroughly before replacing it in the filter basket.
9.Begin brewing and allow the full brew cycle to complete.
Repeat steps 6-9 one more time.
Nov 23, 2007 | Mr. Coffee FTXSS23GTF Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Coffeemaker Coffee Makers & Espresso Machines Experts
gbob59
pawnpower
Are you a Coffeemaker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
