Question about Keurig Coffee Makers & Espresso Machines
I cannot get my Keurig 545 plus to read the carafe
Keurig is blowing grounds all over
You are likely overfilling your pod with coffee. I had the same issue until I realized that to get a good cup of coffee without the mess I should only use 1/2 full pods. If you are having this mess with factory sealed K-cups then I don't know what your issue could be.
Sep 06, 2016 | Keurig Black K-Cup Storage Dispenser Set...
Power button shows on screen but doesn't turn on
perhaps a check with Keurig tech support will solve this problem
Jul 22, 2015 | Keurig 2.0 K400 Coffee Brewing System with...
Why is my keurig 2.0 K400 (only 1 week old) suddenly stopped brewing? droplets of H2O come out - why?
If you read other questions people have about their Keurig machines you will see that many answers suggest you contact Keurig Customer Service. This is actually the best course to take since they are known to offer machine if the problem can't be fixed.
Feb 15, 2015 | Keurig 2.0 K400 Coffee Brewing System with...
We have a keurig 2.0 carafe 550 new. it will brew the 1 cup but when we try to brew the carafe it says to add water even when it is full of water.
I think you guys are missing the point of the question. We too have the same problem and the unit is brand new. 1 cup it works awesome, 1 karafe it says it doesnt have enough water, even though there is enough. I would think if it was a scaling issue, the 1 cup would not work either. From what I have read so far, a kinked hose sounds more logical.
Dec 26, 2014 | Coffee Makers & Espresso Machines
The plastic side carafe is cracked and leaking...where can i purchase a new one?
Here is a tip that I wrote about how and where to get replacement parts foryour Keurig Coffee Brewer
Keurig CoffeeBrewer Replacement Parts
Sep 12, 2011 | Keurig B60 Coffee Maker
I have to remove the water reservoir several times before getting one cup to brew. The word PRIME appears, and the water reserve must be removed, replaced, removed, and replaced (sometime 2 to 6 times)...
Hi, Give it a few good slaps on the needs to be burped..
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
Aug 29, 2011 | Keurig B60 Coffee Maker
Cuisinart DGB-600BC - water inside the carafe shell
First off, do not submerge the carafe in cold water when it is hot. The water will rush past the seals. This solution involves heating the carafe. Be careful to avoid steam burns
1. Place the carafe on a stove top. 2. Slowly heat the carafe. (make sure you are wearing oven mitts -- avoid steam burns) 3. As the carafe heats the water inside steam will escape the area where the seal allowed the water to get in there in the first place. Steam should appear very quickly, If it does not stop the process right away! Pressure can build up and cause the Carafe to explode! 4. Check the carafe from time to time taking care to avoid steam burns. 5. Once the water has been steamed away, remove the carafe from the stove and allow it to cool slowly. DO NOT place the carafe in water or on a very cold surface until it has cooled. The rapid cooling of the left over steam will cause the carafe to collapse on itself if it is placed in cold water while it is still hot from this procedure.
Apr 04, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Broken carafe
I called cuisinart customer service, they have a replacement (she said 3 models were compatible with the dcc490). It took me 2 minutes, will be shipped within a week, and cost $18 plus shipping ($26 total)
May 23, 2008 | Cuisinart DCC490SA Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
