Question about Drills
How can i fix a Drill 3/8 111555600 - Drills
How to fix remove part of Brocken round file out of cylinder head What type drill bit to drill down the centre of round file 3.5mm x 112. The file is 5mm across
That file is incredibly hard, harder than your drill bits which will wander off and drill the cylinder head itself.
Can you remove it from the other side?
Aug 06, 2016 | Drills
18v battery for nutool cordless drill
How To fix: Zap a Dead Cordless Drill Battery (nicad repair ...
? 5:56
Apr 27, 2010 - Uploaded by froshmasta
Got an awesome cordless drill with dead nicad battery packs and don't want to throw it out? Maybe a welder ...
Nutool Cordless Drill Kit (18v) x2 BATTERIES - > ... > Drills > Drill Sets, Inc.
Rating: 3 - ‎1 review
Buy Nutool Cordless Drill Kit (18v) x2 BATTERIES at Amazon UK. Free delivery on eligible orders.
18v battery for nutool cordless drill - Fixya
Jan 14, 2016 | Drills
Makita hr1260 drill won't rotate. how can I fix it?
have an appliance centre check out the drill motor as it may be burnt out.
Apr 22, 2015 | Makita Drills
Ryobi 18v drill stuck chuck
easy to fix
with the drill not running
grab the bottom part of the spinning part of the drill nearest the drill's motor.
grab the spinning shaft bit nearest the drill bit
pull them apart slightly
when the two parts are pushed together thay lock the chuck
I own a ryobi hammer drill that does the same thing
Mar 13, 2015 | Ryobi 18v Cordless Drill - P206 18 Volt V
The bit wont lock in the drill, how do i fix this problem
This is a very easy fix - you have a quick change chuck on this tool. Turn the chuck counter-clockwise and pull it straight off - the new one goes on the same way. Quick Change Bit Chuck
May 23, 2014 | Bosch 11236VS Rotary Hammer
How to fix a hummer drill
HI!may i know the specific parts you want to fix?Because there are several parts of the drill that can be malfunction..Kindly post what is the parts that you want to fix.
Aug 14, 2011 | Electric 1/2" Hammer Drill Ul
Drill completely stopped working. Bad smell from battery. Charged up the second battery and plugged it in. In three seconds, it started smoking very badly. I removed it. The drill worked with second...
The only way to tell if you can fix it is to take the drill apart...
Look for two wires melted guess is that they got too hot and melted together inside the drill... separate and insulate and you should be fine...
May 21, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
How to fix drill that has no power?
Order the parts you need from Home Depo, they have what you need to fix this problem. check to see if you were using the right battery if it never worked you may need to buy another drill or go even further and open the drill up to see what the problem is inside. Check your brushes, trigger, all connections.
Apr 03, 2010 | Bosch 14.4V Brute Tough Drill Kit
Kawasaki 19.2 cordless drill
Hi Tim, Sounds like you got it figured out! The only question I see is if there is a quick fix, and it looks like you answered your own question. You can certainly pursue requesting that it be fixed as a manufacturing defect/ faulty part, or even a safety hazard as that is your right. While I can not suggest you take that route, the old metaphor of the sparking trigger that melted in my hand always seemed to get a lot of attention. Good Luck to you, hope this Fixsya!
Mar 13, 2009 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Drills Logo
60 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
