Question about LG WM2487H Front Load Washer
I have an LG WM2487 washer and I'm having several
I have an LG WM2487H washer and I'm having several problems with it. First, the soap/bleach/softener dispenser cups are always filled with water after a cycle...they don't empty out. I have to empty the drawer of water before I can put the soap, etc. in. Second, I am also having the "stinky machine" problem...so we've been using bleach. But it doesn't all get washed out into the cycle, and it ruins clothes in the next cycle. I do not fill it all the way up...only 1/2 way at the most. Third, I now have an error code that I can only describe as being an upside-down F followed by an E. The book says to unplug the machine and call for service - no further explanation or help is offered or given. What is this code and its causes? Leaving it unplugged for 24 hours didn't help.
  • shaffere Jul 21, 2009
    Thanks for the response. The washer drains fine, except for the inherent design flaw which prevents ALL of the water from being pumped out in these machines. But why does the dispenser fills with water and what does the error code mean (upside-down F followed by an E)? Where do I find "AFFRESH" tabs? They aren't in my local stores. Who makes them?
    Problem Solver:
  • 6 Answers
Addressing your error code: We had the same problem with our washer and couldn't find anyone locally that wanted to even look at it. Hence, I had to find a solution myself. I stumbled onto a sight that had service manuals (not just owner manuals), and found that error code there. What looks like an upsidedown F is actually a lower case T, so the error code is really "tE". This indicates a Thermistor fault.
The Thermistor is located next to the heating element at the botom-front of the drum housing (you will probably have to lay the washer on its back to access it). It is in a soft rubber grommet that protrudes about a half inch out of the housing, just to the right of the heater.
In the case of our washer, when I pulled the Thermistor out of the grommet I noticed some rust on the metal part. I simply rubbed the rust off with my thumb, inspected it again, unplugged and re-connected the connector a couple of times, and tested the washer again.
Results: We have now been using the washer for a couple of days with zero errors, and this was a tenacious fault that interrupted every load before. We are finally happy again with our very expensive appliance. I sincerely hope that this helps you and anyone else with this problem.
Posted on Oct 10, 2009
    Problem Solver:
  • 18 Answers
I would check the filter prior to calling anyone. This is the one located on the bottom left when looking at the door. Ensure that is all clean. I also recommend using Affresh tabs to clean your tub. I use them and they are worth the cost. Once a month, just run the sanitary cycle with a tablet in there and it cleans the tub and smell nice. I'm not sure if there is a drain filter, but you should check that as well. Not draining usually means you have lint or hair or something clogging the drainage.
Posted on Jul 21, 2009
  • leifkennedy Jul 21, 2009
    Go tohttp://www.affresh.com/ and click where to buy. They are all over, Wal Mart has them but not sure where else. I buy them at a specialty appliance store that sells Miele brand appliances. Also, what I do when I'm done washing a load is leave the door open. After about a day or so I close it and have never had the problem. I only started using Affresh 6 months ago after someone recommended it to me and didn't have a problem before with the smelly washer syndrome. Affresh also has little cloths that you can wipe down the rubber gasket with and the tub window and it cleans them.
    Not sure what the error code is, haven't experienced it and can't find anything online. Sorry.
I have a LG front load washer WM2487 H My underware and socks don't seem to come out clean. Can't seem to figure it out
Posted on Aug 31, 2009
  • 4 Answers
Soap tray filling up with too much water...try closing your water supply valves a little. Front load machines are sensitive if you have a poorly setup regulator system (your water pressure may be too high). Most homeowners have never had their water pressure tested to see if it is within spec.
Posted on Aug 09, 2009
I have the LG wm2487h*ma front load washer.My washer is filling up with water when not in use. When I wash a load, the water does not go in the washer. Have opened the door thinking the wash cycle is done...
The problem would appear to be the water inlet solenoid valve.
The valve is not operating correctly for some reason allowing water into the machine even when switched off
Sep 02, 2017 | LG WM2487H Front Load Washer
Need to remove old Door Boot/Gasket & replace new one. How do I proceed?
Hi
Please check this service manual for your LG WM2487 washer if you want to do this yourself. Hope this helps...please post back for further assistance.
Daniel
Jul 21, 2011 | LG WM2487H Front Load Washer
Thermistor on wm2487h*m lg washer
usually on the front outer drum wall. front of machine will need to be removed.
Jul 02, 2010 | LG WM2487H Front Load Washer
My LG WM2487H has water in the detergent cup at the end of the wash. It has happened twice now.
This is normal.
All LG washers use a siphon system to dispense soap, bleach and fabric softner.
Some times water will remain in the cups depending on the cycle used.
Jan 20, 2010 | LG WM2487H Front Load Washer
LG Wash WM2487H*MA- how to turn the tub clean feature on?
I have had this problem since I bought my washer. Some days the tub clean cycle will work....most days it won't. They have replaced the main board twice and it's still broken. I've had nothing but bad luck with LG appliances. Also bought a lemon fridge that took 4 repairman visits to fix. I will not buy another LG anything!!
Jan 17, 2010 | LG WM2487H Front Load Washer
LG WM2487 will not fill with water. ie error code. have done all the checking of plumbing and filters as suggested in manual and on various websites. Could this have anything to do with a sensor?
Yes, its sounds like you might need to replace the cylinoid, that the part that the hot and cold lines hook to the back of the washmachine itself.
Sep 03, 2009 | LG WM2487H Front Load Washer
Moved washing machine and now it won't run
Sounds like a connection may have come loose in the move.
The top cover comes off fairly easily with the removal of some screws in the back. Once screws are removed, slide top cover toward back of washer and take a peek inside looking for loose/disconnected wires.
May 24, 2009 | LG WM2487H Front Load Washer
LG WM2487 front load washer spews suds out of port on rear.
You are likely using too much detergent or the detergent is not high-efficiency detergent. Change detergents and/or lower amount and this problem should go away.
The water port on the back allows air inside the tub to escape. However, if the wrong type or quantity of detergent are used, excess suds will flow from this port.
Mar 09, 2009 | LG WM2487H Front Load Washer
Not enough water
the timer motor is what is called a hysteresis synchronous motor. it runs off 120 volts and synchronizes itself with the frequency of 60 cycles which is what your power co is feeding to you. with your power going on and off and on and off, it created spikes on your house circuit which probably burnt out part of the timer motor. replacing just the timer motor should take care of the problem. the whole timer costs a lot of money like around $130. If yours is a solid state timer, there's no motor just a preprogrammed computer for fill, agitate, drain, rinse and spin. I have no idea what a new board costs but try parts select dot com. they have parts for major appliances.
Aug 26, 2007 | LG WM2487H Front Load Washer
LG WM2487H Front Load Washer Logo
1,516 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
