Question about Watches
My m8s box will not let me onto sport etc, keeps telling me to reset date but date is correct?
  • Watches Master
  • 18,411 Answers
Unplug from mains power for 10 secs then plug back in and let it reboot
I cant set the right date on my timex 1440 sports watch
Hi travislietha,
To set the right date on your timex, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Jun 28, 2010 | Timex 1440 Nylon watch
How do I set the time on my Armitron All-Sport wristwatch
For the Amritron 45/6975:
From the "Time Telling Mode" (date/time displayed): to set the date and time: Press "reset" unit the date disappears--release; press "mode", the "hour" will flash, press "st/stp" to adjust hour; press "mode", the "minute" will flash, press "st/stp" to adjust minute; continue same sequence to adjust date; when done, press "reset"---compliments of Gene Lawson
Jan 21, 2010 | Armitron Two Tone Sports Watch
Configuring time, date etc for my O.T.S watch
http://www.worldofsportwatch.com/en/product-3315.html
This is a link to a website that has OTS watches on it. Click on the OTS watch you have and there is a manual selection. The instructions are a bit hazy but basically you have to press the mode button 3 times, the reset button to get to what you want to change, and then the start button as many times as needed to change it to what you want. I finally corrected my watch time and date using it. Thankfully!
Jan 01, 2010 | JCPenney Armitron Sport Watch
How do I set the time on the watch? It won't let me go to each function to set the time. It also won't let me get out of the military time mode...
From the "Time Telling Mode" (date/time displayed): to set the date and time: Press "reset" unit the date disappears--release; press "mode", the "hour" will flash2_bing.gif, press "st/stp" to adjust hour; press "mode", the "minute" will flash, press "st/stp" to adjust minute; continue same sequence to adjust date; when done, press "reset"
Dec 30, 2009 | Armitron Digital Sport #45/6975RED Watch...
I have a timex 144 sports watch but do not know how to change the time. Could you tell me how or direct me to a website where I can download directions?
Hi bsklar,
To set the digital time and date on your Timex, please follow the steps below.
Hope it helps.
Nov 16, 2009 | Timex 1440 Nylon watch
Sunrise/Sunset Time and Moon Phase wrong on watch!
Just in case you're still interested in a solution. Your watch uses a geographical location and the current date to estimate the sunrise and sunset times. While the date (and time) information is, most likely, set on your watch correctly, you, probably didn't specify the geographical location (latitude and longitude, as well as the GMT correction for your time zone). Having setup correctly these parameters you'll enjoy the precise sunrise and sunset time. Good luck!
May 29, 2009 | Casio Watches
Changing the time on my wristwatch
Mar 08, 2009 | Armitron Two Tone Sports Watch
Setting time/date on Ironman Triathlon 8 lap
Press & hold set button the seconds will flash.
Press split/reset to set seconds to zero
Press mode to select hours
Press split reset to advance hour digits go through 12 hours to get to AM/PM
Press mode to select minutes
Press split reset to advance minutes
Keep repeatin the above steps to set month date day and 12/24 hour diplay
Press set when done.
Mar 09, 2008 | Timex Sports Ironman Triathlon 50-Lap...
Setting Bench Watch
Reset Instructions Bench. (BC0013BR)
Time and Location
If you hold in the light, start and the reset button for a few seconds a screen will appear with the 12h or 24 h clock setting and also the date and country.
Once you have that screen if you press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time.
Once you have changed the date and time to the correct date press the light button, start button and reset button and it will save the settings.
Alarm
Hold in the light, start and the reset button for a few seconds a screen will appear
press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time. Use the light button to set the screen.
Feb 27, 2008 | Watches
Stting the time
http://assets.timex.com/instructions/w3Instr.pdf
Try the link above for a manual.  It is NOT the same watch, but does have some buttons named similarly to the 1440.  Go to the Time and Date section.  The key was to hold down the SET button till the seconds flashes, then use START/SPLIT to adjust the value and MODE to toggle to the next field etc.
Best of luck
May 29, 2007 | Timex 1440 Sports Quotient¿ 53612...
Watches Logo
2,415 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
