Question about Cell Phones
My eclipse10 by Verizon has scrolling problems.It studders.
2008 Dodge Caliber studders when trying to take off.
The cap problem is the least of the causes for the code
Check the EVAP system venting , valves and solenoid
Aug 06, 2017 | Dodge Cars & Trucks
My 1999 4x4 4.3L blazer studders in gear after warm a few mins on city streets and highway, it comes and goes? i have done complete tune up and fuel filter and fuel pump. it studdered less i think af
Check owners manual or manually check to see if there is another fuel filter. Sometimes vehicles have more than one fuel filters which are overlooked until they have problems with them. Most have a filter right along the frame.
Aug 23, 2012 | Chevrolet Cars & Trucks
My 97 Legacy started to studder when stepping on the gas from a dead stop. It does not seem to studder at higher speeds. Do you thing the Fuel filter may need to be changed?
May 10, 2010 | 1997 Subaru Legacy
2007 Chevrolet Cobalt Has a studdering problem.
Sounds like your fuel Injector's. Go to the dealer and let them listen to they sympton. More than likely they will tell you that it's your injectors that need replacing.
Jun 01, 2009 | 2007 Chevrolet Cobalt Coupe
Santa fe studdering and won't accelerate right? RPM's jump and then steady with continuing studdering?
Engine performance problem causes are many. Try this first.
1. Disconnect the battery cables (both of them)
2. Touch/connect the postive and negative battery cables together for 30 seconds.
3. Reconnect the cables to the battery.
4. Drive vehicle to see if this solved the problem. Let me know what happens.
Apr 25, 2009 | 2003 Hyundai Santa Fe
New motorola v3m razr phone will not find any bluetooth devices
Is this a repair store,some stores have a tec that can reload the firmware and any new updates for the phone. The warranty is probably over and moto would charge you to repair the phone. See how far away that there is a Verizon that can reload the firmware.
Also,thanks to verizon for being thieves that you can not transfer
anything with bluetooth, so if you want bluetooth for your pc, or to transfer anything your out of luck. verizon has disabled
Obex in the firmware of the phone. You can bluetooth a headset,but thats all.
  1. Press Start.
  2. Scroll to and Select Bluetooth.
  3. Scroll to and Select Bluetooth Manager.
  4. Scroll to and Select Hands-free.
  5. Press Add to configure a new Hands-free device.
  6. Press Search to search for devices. Your phone will begin to search for the device (consult your device user guide for instructions on placing your device in pairing mode).
  7. Select the device.
  8. When prompted, press Yes to pair with the device.
  9. Enter the device passkey (normally 0000).
  10. Press Done. When your phone is paired, the Bluetooth indicator will be displayed on the home screen.
Just checking to see if this is the way you connect,or tried to connect.
Apr 04, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Change ring tone on Verizon Blackberry Curve
Go to the "profiles" icon, select it and then scroll to the bottom to advanced. Scroll to where you keep your phone ringer volume to...loud or normal and hit the menu button to the left of trackball and select "edit", scroll down to phone, hit menu again and select edit. Scroll down to "Tune" then menu and select "Change Option"
Mar 06, 2009 | RIM BlackBerry Curve 8310 Smartphone
Smooth scrolling
Do you mean like a slow "ripple" as it scrolls? Sounds like you need to update your video driver.
Nov 09, 2017 | Logitech MediaPlay Cordless Mouse
How to reproduce problem with touch screen scrolling/dialing
the only way to reproduce this i have seen is by maxing out the sensitivity on the touch sensors. This may get it to do that for you? Its the only way i can think of.
Good Luck!
Mar 22, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Verizon wireless chocolate
best to buy a new phone...you can try and take it to a mobile service center and see if reflashing it would correct it
Dec 24, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
