Question about Dirt Devil Vacuums
Dirt Devil not picking up floor debris. Says to make sure the roller is turned on. What does that mean. Can't find anything online re that. Thank you and Happy New Year!
  • Dirt Devil Master
  • 1,420 Answers
It means make sure brush roll is spinning. Replace the belt if it's over 6 months old.
Posted on Jan 03, 2017
Brush roller won't turn
Hey, this is Jeremy with Crucial Vacuum,
There are 2 potential reasons as to why your Dirt Devil AccuCharge roller brush is not working:
1) The roller brush may be blocked by debris that was picked up by the vacuum. To remove the blockage, switch your vacuum 'OFF' and unplug before proceeding. Then, lay the vacuum down and try to remove anything that is lodged in the roller brush.
2) If the vacuum cleaner brush is not spinning the belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace if needed.
You can purchase replacement parts for Dirt Devil direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for readers, use code: FIXYA10
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jun 26, 2015 | Dirt Devil AccuCharge 15.6-Volt Cordless...
My Dirt Devil Reaction will work with the hose attachment but will not pick up from the floor. What could be wrong?
With all upright vacuums the problem could be one of two things on it in this situation.
1) the belt may be broken or slipping and is needing to be changed.
2) the lower area below the hose attchment and the rotating brush may be blocked up.
It is also possible that both could be giving you a problem too, however if it is blocked up down below then you will most likely see some dirt and debris spitting back out as you vacuum.
Nov 04, 2010 | Dirt Devil Reaction Twin Cyclone Upright...
I placed the new belt on the brush roller like i was suppose to, but brush roller will not turn forward or backward. What am I doing wrong?
Most likely the roller is frozen due to dirt and debris. Follow the instructions to remove the belt and roller. Clean the roller as best you can and at each end where the hard rubber holders are located. Add some WD40 between the brush and these holders and turn by hand until the holders move freely around the brush. Reassemble making sure the belt is on in the correct manner so the brush rotates in the proper direction.
Oct 04, 2010 | Dirt Devil Featherlite Bagless Vacuum...
When machine is running the brush does not turn
You need a new belt. In order to change it, turn the machine compleatly upside down and place the head on a counter, handle on the floor.
There is a L shaped base plate to remove that has 5 screws in. Once the base plate is off, you see the brush roller and a silver shaft directly back from where the belt would ride. Remove the brush roller, place the new belt, Dirt Devil Style 5 ( see link below ) on to the shaft. Then insert the brush roller, so the belt is on the raised carved out section of the brush roller. Grab the brush roller at each end and stretch it till you are able to put the brush roller back into the base. Turn the brush roller backwards 3 compleat turns and the same forward to seat the belt.
Replace the base plate and you're done.
Dirt Devil Style 4/5 Belt - 2 Pack. Part # 3720310001 - Free Shipping Dirt Devil Style 4/5 Belt - 2 Pack. Part # 3720310001
Cost $ 8.00
Apr 28, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Dirt Devil Vision bagless not working
Check the dirt cup filter. remove the dirt cup and check for proper suction. if you have good suction, check your belt
Jan 24, 2009 | Dirt Devil Featherlight Bagless Upright...
Dirt Devil Swivel Glide
look on the underside where the brush roller is and unplug it first then try to turn the brush roller by hand,if it turns real freely the belt is might have a clog at your intake hose at the bottom its the clear looking hose that goes from the bottom and comes up the back.if the belt is broke before you put a new one on clean the motor shaft there might be some old belt rubber on it ,otherwise the new belt won't last
Jan 03, 2009 | Dirt Devil Featherlight Bagless Upright...
No suction
I'm not sure what model you have, but the most common problems I've seen with these are that the hose gets clogged. Usually the hose is removable. If you can get it off, you may be able to push the clog out with slender rod or yardstick. If you are fortunate enough to have another vacuum with a hose, you can also **** or blow the clog out of the dirt devil hose with the other vacuum. Good Luck!!
Jan 02, 2009 | Dirt Devil Vacuums
Dirt Devil M084600 Dynamite
Your roller won't turn. The belt is designed to break if anything threatens to keep the motor from turning. When you have the roller out, check the end caps to see if they rotate easily. If they do, then install a new belt being very careful that the belt is not pinched on the channel that it sits in. Once you have the belt installed, turn the roller by hand to make sure that there is no jamming or catching of anything. Install the plate and check the rotation again. Once you are satisfied that the roller turns easily, try the machine.
If the caps on the roller are jammed, as they will get from debris, hair and thread, etc., then you may have to replace the roller. The end caps on most of the Dirt Devils are carbon fibre and will break when you try to remove them.
Jan 30, 2008 | Dirt Devil M084600 Dynamite Bagless...
Yep check the hose at the back as it may well be clogged. Also undo the soleplate/floorhead and have a look up the dirt channel behind the floor brush. Either that take off the main bin and check the dust channel leading down to the hose.
Jul 14, 2007 | Dirt Devil M084600 Dynamite Bagless...
Vacuums Logo
41 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
