Hello I have a washing machine AR7L125 I don't know how to make it work with time less than 3 hr please help me with pictures Thank u
  • 108 Answers
SOURCE: Washing machine fill but won't go through cycle.
Too empty your machine reset the programmer to Final spin. the machine should empty normally.
If you have a fast flashing light its most likely to be 1 of 2 things.
1. The belt from the motor has broken. (price for belt is less than 20 pounds.)
2. The brushes in the motor have worn down too much to make the drum turn. Look underneath the washing machine to see if black power (Carbon) is deposited under the motor.
(Price for set of brushes is less than 20 pounds)
Labour should be no more than half an hour by anyone decent.
Regards
Posted on Feb 22, 2008
  • 299 Answers
SOURCE: Washing machine isnt' draining nor spinning.
1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check the electrical connections at the pump and make sure the pump is running. 4. Check the drain pump filter for foreign objects. 5. Plug in washer or reconnect power. 6. If the above does not correct the problem, go to step 7. 7. Unplug washer or disconnect power. 8. Replace the pump.
Posted on May 02, 2010
  • 177 Answers
SOURCE: Hello, i bought an LG front
you may have a kinked drain hose so the water cannot drain out properly. or if you have the drain hose plumbed into your sink u bend the hole in the spigot may not be opened up large enough.
Posted on Aug 23, 2010
rickead1
  • 1998 Answers
SOURCE: hello i am repair man
when it stops do you still have power to the front panel if there is no power to the panel then you would have a bad connection to one of the control boards. are there any error codes showing when the unit does stop such as flashing lights or an exact er code have you checked the door switch? if the door switch does not work the unit will start then stop immediatley message me back with your finds thanks Rick
Posted on Apr 24, 2011
  • 6277 Answers
SOURCE: Hi,i need a manual for
So sorry but FixYa cannot do that direct - members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Sep 04, 2011
Do you know where the serial number is located on frigidaire washing machines?
Hello, Thank You for using FixYa. I will be helping you today. It is on the insde part of the door frame or on the door itself.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 07, 2011 | Frigidaire Washing Machines
Cold water input down to a trickle
Hello, Thank You for using FixYa. I will be helping you today. First unhook the fill hoses and clean the screens where the hoses hook up and flush the hoses in a bucket. If that don't help replace the fill valve.
Thank You and please rate my answer if it was helpful..
Jun 19, 2011 | Washing Machines
I have a neptune front loader, after the wash cycle is complete the clothes smell like they have not even been wash with a **** moldy smell. I use Tide HE as directed but they still smell like i...
Hello, Thank You for using FixYa. I will be helping you today.Try 2 cups of white vinegar on a heavy duty cycle with hot water.Pour it in the detergent dispenser after it starts to fill. Also the affresh tablets work good i would use 3 tablets at one time if your unit is as bad as you say.
Jun 17, 2011 | Maytag Neptune MAH5500B Front Load Washer
I'm getting an 5ud and don't know what that means?
Hello, Thank You for using FixYa. I will be helping you today.SUD means suds as in soap suds. Are you using too much soap? Are you using high efficiency detergent? If your using the correct detergent and not using too much,Only fill to bottom line on cap and still getting sud error then you may have a failed pressure switch.
Jun 16, 2011 | Kenmore Front Load Washer
Not really a problem. I have a 7 cycle large capacity washer. I don't have a model #. is there a filter that needs to be checked periodicaly .It is a top loader.
Hello, Thank You for using FixYa. I will be helping you today. There is no filter for you to clean.
Thank You and please rate my answer if it was helpful..:)
Jun 09, 2011 | Roper Washing Machines
Hi, i have front loading samsung washing machine,capacity 5.5 kgs. Its showing 3E error. could i know what it is and how can i get my machine working again???? thank you, Vaidehi
front loading samsung washing machine,capacity 5.5 kgs.This video will help you diagnose the fault on 3e error codes and the video will help you solve the problem
Sep 04, 2010 | Washing Machines
Regards
Feb 22, 2008 | Hotpoint WMA46 Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
