Question about Home
My Siemens JSJS-102 door chime no longer works. Battery new, can change chime sound but will not chime when button pressed
  • 5 Answers
SOURCE: fujitsu siemens wireless mouse not
check the range at which it can support.........
don keep any additional electronic device near by to it.........
check the wireless connection is enabled on the device........
40% times it works.... try!!!!!!!!!!!!
ny more q: mail me at --dashvrista@gmail.com
Posted on Sep 25, 2008
  • 82 Answers
SOURCE: "Headlights on" warning chime not sounding when I open car door.
I had the same problem as this...
When you open or close your door there is lever that sits just below the the door latch that is attached to the frame of your car by a single screw.
It is a black plastic L shaped bit of plastics that slides on its own guide. It has obviously started to malfunction over time.
To double check this:
Turn the car lights on
Open your door
Locate the black L shaped plastic level.
Wriggle it around sliding back and forth - if it starts to work when you are applying pressure onto it it looks like it has broken.
Go to your local wreckers and ask them for a replacement part (it cost me $2.00 AUD to get mine)
To take the part off all you need to do is push the level back as far as it will go and you will see a phillips heads screw holding it in place.
Undo the screw and detach the part (there will be a wire attached to the back of the metal guide)
Unplug the wire and throw the part into the bin.
Attach the wire to the back of the new part and screw the new one into place.
All should be working fine now.
Good Luck
Posted on Mar 09, 2010
Testimonial: "Thank you for helping. That did it!"
  • 3 Answers
SOURCE: harmony 890 will no longer operate the tv, dvr,or sound
I had a similar issue and only needed to "re-configue" the remote... Basically, just try plugging it back into a USB cord ( connected to your computer) and go to the original programming home page and click the "Update button." It will re-program your remote as if it was new.. Over time your Harmony may lose or forget the frequency of your various components. This happened to me. Also, make sure the remote has a full charge while you're programming it. Give it a try !
Posted on Mar 13, 2010
  • 4736 Answers
SOURCE: I have a desa
Sandra, the contacts in bell push may need cleaning, as well as some minor readjustment of the contacts. Insects love to get into the bell push and can clogged it up. If you find that this doesn't solve the problem, Contact the Zenith Company 800-858-8501 to purchase a replacement.
Posted on Mar 09, 2011
vko007us
  • 254 Answers
SOURCE: I am trying to locate
Hi gareth,
Plz try this link .. hope it works for you if not kindly revert:
http://www.manualsnguides.com/search.php?cmarque=SIEMENS&modele=WIRELESS%20DOOR%20CHIME%20MODEL%20JSJS-217
Thanx
Posted on Aug 24, 2011
Id like to change song on my doorbell Dimango model 4330 r cd chime reciever
The webpage http://www.dimango.com/dc-cd-quality-doorbells.htm
shows:
Wireless Doorbell CD Quality Door Chime
Model RC4300
No longer do you need a wired door chime or traditional doorbell with brass tubing to get amazing, rich sound. Our Battery Operated Door Chime from Dimango has CD quality sound while remaining completely wireless...
  • Plays three selectable sounds
    1. Ding Dong
    2. Dong
    3. Westminster Chime Click To Hear Sound!
  • Set sound conveniently at button
It seems that there is a button on the receiver/speaker. Try press once and see if the sound changes.
Nov 27, 2013 | Desa International White Wireless Plug In...
Siemens model jsjs-210 door bell manual to chnge radio band
Siemens door chime jsjs-210
Without doubt the worst piece of design I've ever encountered.
The battery housing on the chimer is so large that on closing the lid with the batteries fitted they pop out, nothing holds them in place other than the contact elements - the case snaps shut with quite a jolt and the batteries just pop out...had to use a padded envelope cut to size to keep them in place.
Also the button unit is dreadful - the button isn't actually a button - it's a light, pushing the button just flexes the circuit board and activates a small push sensor on the reverse of the circuit board!?! WHY? A button that isn't a button? The sensor is also too short to touch the rear of the casing and thereby close the circuit - had to pad this out with 2 bits of cardboard...too much it will ring all the time, too little it won't connect.
Please do not buy this product - if you have return it, it is dreadful - and from Siemens it's not even funny.
Apologies for not answering the question directly - I was also searching for a manual for this, to maybe figure out why this device is so badly constructed.
Sep 28, 2013 | Bell Sports Wireless Door Bell with...
Siemens jsjs-208 door bell
Mine keeps doing it. Taking a battery out to force reset on the ringer but mine seems to need this every few weeks. Tried new batteries but still problems.
Mar 19, 2013 | Bell Sports Wireless Door Bell with...
I have a JSJS 203 wireless siemens door bell how do I change the tune?
On my JSJS315 there is a small button (hole) on the back mine is marked S to switch the tunes. When you press it will play the next tune and so on. Hope this helps
Jul 04, 2012 | AT&T Home Security
Phantom bell rings on Siemens wirreless door bell chime jsjs-204, I do not have instructions
You may need to change the frequency of the chime. In this model, you need to remove the batteries from the receiver unit and wait for a while. Then replace the batteries. The doorbell unit should automatically set itself to a different frequency once you press the button, which will(hopefully) solve the problem.
It seems impossible to find the instruction manual for the doorbell. But see http://oddsnsods.net/blog/?p=68 who had a similar problem with a different Siemens model, which works on the same principles. (I can't seem to be able to remove the battery from the door bell unit on the jsjs204, but it reset itself after changing the batteries in the receiver).
Nov 01, 2011 | Desa International White Wireless Plug In...
I have a byron SX85R plug in wireless door bell, i need to change the frequency/ or code, keep false alarming, cant find the instructions , also with the alarm, is a batterie alarm no. SX81R, which came...
From User Guide: Interference from a similar unit operating nearby: a) simply remove the batteries from the push button and door chime units and rest for 10 seconds, this will erase memory b) Insert the batteries into the push button and door chime units, the door chime unit will give 2-beeps to indicate that it is ready for the new registration code. Press the Push Button once, it will generate a new operation code randomly and send a wireless ignal to the door chime unit and it will sound to indicate that new operation code is registered and memorised.
(Note with this unit SX85R the door chime is mains powered, not battery powered, but above instructions are the same)
Oct 10, 2009 | Bell Cocoon Child Carrier
Need programming instructions for RKE for 2000 Mazda 626
2000 Mazda 626
Note: Make SURE the battery is new.
Instructions for programming ONE keyless remote fob.
1. Open the driver’s door & leave open.
2. Insert the key in the ignition.
3. Turn the key to the on and off position 3 times.
4. Remove the key from the ignition.
5. After door open chime stops, press the door open button 3 times.
6. After chime, press any fob key twice.
7. After second chime, press any fob key twice again.
8. After third chime, press any fob key twice again.
9. Press the door open button once.
10. The car should give another acknowledgement chime.
11. Test key fob.
This DOES work. I just programmed mine successfully today, three hours ago.
Sep 03, 2008 | 2000 Mazda 626
Disarm door chime
According to my manual.
>Turn Chime Doors on:
1. System must be disarmed. Press Chime Doors button.
panel will announce,"Chimes On". Chime Doors button will be lit.
> Turn Chime Doors off:
1. Press Chime Doors button.
panel will announce, "Chime off". Chime Doors button no longer lit.
Sep 02, 2008 | GE Security Simon 3 Wireless Home Security...
Home Logo
160 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
