Question about Saeco Royal Cappuccino Espresso Machine
Saeco Royal Capuccino Ventilate message appears No water pumps out the spout as per all advise I can hear the pump working but no water comes out. This machine was serviced months ago but has not been used since.
    President:
  • 1,618 Answers
Press the steam knob in, if that works take it back and tell them to replace the tap rod assembly.
Posted on Jul 22, 2009
The display on my Saeco Royal Exclusive says ventilate and the machine won't do anything, what do I do?
Hi
That means the pump needs to be primed by running water through the wand. Push the water button( the one with the drop or drops). You will hear the pump change tone when it primes and the light or message will disappear. If you have a restriction in the intake line the message will not go away. There is a flow meter inside the machine that measures water flow. If the flow meter does not spin when the pump is running, the computer thinks that the pump is not primed.
Aug 21, 2010 | Saeco Royal Professional Espresso Machine
My saeco royal has ventilate on the screen and is not working. what does this mean?
Hi That means the pump needs to be primed by running water through the wand. Push the water. You will hear the pump change tone when it primes and the light or message will disappear. If you have a restriction in the intake line the message will not go away. There is a flow meter inside the machine that measures water flow. If the flow meter does not spin when the pump is running, the computer thinks that the pump is not primed. Coffee grounds will get into the intake and restrict the flow meter. If you get a restriction in the water intake (below the water tank, on the machine) the pump may run and water comes out, but the flow meter does not create the jet of water to spin the turbine wheel to send impulses to the computer. You get the ventilate message. One thing to remember is when you are working on the water system (have the water tank off) do not fill the bean hopper and visa versa. Keep them covered when working on the other. Cross contamination will damage a machine fast
Feb 08, 2010 | Saeco Royal Professional Espresso Machine
Ventilate
HI
Hi
That means the pump needs to be primed by running water through the wand. Push the water button. You will hear the pump change tone when it primes and the light or message will disappear. If you have a restriction in the steam tip the message will not go away.
Oct 24, 2009 | Saeco Royal Professional Espresso Machine
No water coming from Saeco Royal Professional Coffee Machine
Check the end of the steam spout using a paperclip make sure it is not blocked.
Oct 06, 2009 | Coffee Makers & Espresso Machines
Royal machine ventilate
Open the hot water valve to allow the pump to prime.
Sep 15, 2009 | Saeco Royal Digital Plus Coffee...
New Royal espresso machine
Run hot water cycle to ventilate machine.
Mar 09, 2009 | Saeco Magic Comfort Plus Espresso Machine
No steam and ventilate
When you try to get out water, can you get a full cup of water or just a half cup?
How often do you descale your machine?
/Mirran
Aug 17, 2008 | Saeco Royal Professional Espresso Machine
Ventilate!
Can you get water out of the machine by pushing the hot water button?
This is how you would remove the ventilate message in the first place, but if no water comes out then the machines electro-valve is not opening and you will not be able to remove the ventilate message. You will have to get the machine serviced.
I would also give descaling the machine a try before servicing the machine.
You can also find the user manual for the royal professional on our website: http://www.cerinicoffee.com/Saeco_User_manuals_free.asp
We are a Authorized Saeco Service Center based out of New York.
For Saeco Parts and Cleaning supplies visit www.CeriniCoffee.com
May 29, 2008 | Saeco Royal Professional Espresso Machine
V entilate?
the machine come with a little pump put water in the pump and insert the pump inthe water hole and press the water in the machine try to ventilate fill the water tank cheers
Jan 16, 2008 | Saeco Classico Espresso Machine
I am getting an error message that says VENTILATE
Try draining the machine. Page 37 of the user manual, Drainage. Place cup under the steam/hot water tube, turn knob clockwise around to 9. If the pump is ok, it will start automatically and start filling the cup. Drain about 1/2 cup of hot water and return knob counterclockwise to start position. If the flow meter is not damaged, the Ventilate message should be gone.
Nov 07, 2007 | Saeco Royal Exclusive 30153 Espresso...
Saeco Royal Cappuccino Espresso Machine Logo
506 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
