Question about Marantz SR-5000
Pioneer VXS-D1S No output (sound)
Everything seems to be working on it. You can see the stations tuned in and the led meters bouncing to the music but no output anywhere? I looked inside, all fuses good and nothing looks burned or melted? Any suggestions? Thanks, Travis
0 characters
1 Points
Hello I need help with my Pioneer vxs-920 led keeps blinking but can't turn on what's the course and solution
try holding the advanced surround and power buttons. If it turns on then turns off again, there is a problem in the amp.
Jul 24, 2013 | Audio & Video Receivers
My pioneer vsx-d1s muting button and speaker B button not working. no sound in speaker. how i fix that probs???
Dear devan,
Make sure that your speaker buttons are having problem, by connecting new speaker with your system.Let me know the result.
Best regards Chandrashekhar Bhat
Dec 29, 2010 | Pioneer Audio & Video Receivers
Auto muting on when on am/fm and no sounds come out. everything else is fine.
That's normal.
The Auto Muting mode mutes the audio output of the tuner if the station is not sufficciently strong to be accurately tuned. Otherwise you would hear all that interstation hash noise.
Press the FM Mode button to change it to Mono if you want to manually tune a hard-to-reach station. It will be in Mono.
Page 26:
Normally select this.
When a program is broadcast in stereo, you will hear stereo sound; when in monaural, you will hear monaural sound.
This mode is also useful to suppress static noise between stations. The AUTO MUTING indicator lights up on the display.
Mar 31, 2010 | JVC RX-D205 7.1 Channels Receiver
My Pioneer VSX-D1S A/V receiver will not power on; this began yesterday. Pressing the power button results in only a clicking sound along with the standby LED turning on. The owner's manual states to press...
Unit is pretty old I had one of these back in 98-99.
Time to upgrade a service tech is going to cost you $150 just to open it up and figure out whats bad.
Pioneer ok but check out Denon's line of receivers Onkyo is good too but they have a high rate of repairs
Pioneer doesn't make them like they used to that D1S was a tank, had tons of audio / video inputs was one of the first with video upconverting had lots of power and a great front display panel. BUT technology has come along way and pioneer hasn't kept up. They even stopped making high end TV's a few years ago even though they were regarded as the best sets out there.
check this out
Denon AVR-4310CIgoogle it they sell for ALOT less than sticker I bought one for $1299 with a 5 year warranty
Hope that helps
Feb 17, 2010 | Pioneer VSX-D307 Receiver
My pioneer receiver vxs-918v standby/on button is blinking and will not work. We were watching a movie last night and it just went off. It will not do anything except blink. The manual just says call a...
With the power off try holding Tune + and Auto surround/stream direct buttons for a few seconds to reset the protection circuits. Also, check the back panel for any loose wires. If a speaker wire is touching the metal it can overload the unit.
Make sure to keep 8" of empty space above the unit for air, as overheating can cause this problem. If it fails again, there could be bigger problems, so get it checked
Dec 28, 2009 | Pioneer VSX-918V Receiver
Will not tune any radio station, fm or am. everything else works fine. May be damage resulting from lightning, through the antena input.
It is very possible the fm tuner pack is damaged from lighting,if you have voltage going to the fm tuner pack im sure your tuner is bad pioneer part number for your tuner is AXQ7231
Sep 26, 2009 | Pioneer VSX-D811S Receiver
Pioneer VSC-D1S A/V receiver
Did you solve the problem? Mine is doing the same.
Sep 04, 2009 | Pioneer VSX-D3S Receiver
Center Channel not working on pioneer vsx-d608
Be sure the sound source has a center channel output ie. not a 2 channel source only, try the test tone setup for 5 or 6 channel balance, if no sound from the center channel still then it is looking like maybe the center channel is blown.
Jan 28, 2009 | Pioneer VSX-D608 Receiver
Why wont it play???
Hi Jacqui h,
I assume this is a RF system that inputs through the FM aerial.
The instructions should give you a specific frequency.
You will have to tune the radio manually to this frequency and select a pre-set number.
John w
Mar 17, 2008 | Audio & Video Receivers
Marantz SR-5000 Logo
37 people viewed this question
Top Marantz Audio & Video Receivers Experts
Pieter Vleeshouwers
Are you a Marantz Audio and Video Receiver Expert? Answer questions, earn points and help others
