Question about Sharp Televison & Video
Why don't I have a video signal on my Sharp LC-49D68UT ?
  • Sharp Master
  • 6,694 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on Dec 31, 2016
The screen shows the lock mark and has changed color and can not change any sitting and we don’t have remote control
HCDZ Replacement Remote Control For Sharp LC-70LE732U LC ...
https://www.amazon.ca/HCDZ-Replacement-LC-70LE732U-LC...LC.../B00F3ZFA6QHCDZ Replacement Remote Control For Sharp LC-70LE732U LC-46LE830U LC-70LE733U LC-80LE632U Smart AQUOS PLASMA LCD LED HDTV TV: Amazon.ca: Electronics.
You need a remote, but just try disconnecting it from the mains. That might get rid of the lock symbol. The blue hue is a fault and you need a television engineer or a new television.
Mar 18, 2018 | Televison & Video
Sharp TV problem LC-40E77UN Sharp Blu Ray
PLEASE place your question in the appropriate forum/section under TELEVISIONS, because this is the VACUUM section. That way, someone knowledgeable about your problem can help you.
Oct 19, 2013 | Televison & Video
Input 2 without image, just sound. It says S-terminal, how to swich to S-Video?
TV should auto sense S-video connection if signal is present. try removing any other wires on that video input to insure that Tv is seeing signal from that source
Mar 01, 2011 | Sharp Aquos LC-37D90U Television
My Sharp LC-32SB24U says An incompatiable video signal has been recieved. Check the output device settings?
It sounds like an HDMI lead has standard video on it or the output from a digital unit is not the correct specification for your TV.
Check the instruction booklet for recomended signal sources and then check your DVD, Video, Computer for the right type of signals to be outputed to your TV.
Hope this helps.
Oct 29, 2010 | Sharp LC-32SB24U 32 in. LCD TV
No picture
It sounds like the Bluray player may be outputting the signal at a higher resolution than the TV supports. If the Bluray player has a scart or composite connection, connect with those first, and adjust its settings to output a lower resolution. Then reconnect the HDMI. Hope this works for you.
Jul 17, 2010 | Sharp LC-32SB23U 32 in. LCD TV
Error Code E202, no picture, Sharp Aquos LC-45GD1E
Ur tv is not getting a broadcast signal,or ur tv cable or free air signal not getting from air antena,cables or dishes signals,or strong enough comming through.Get a better antena,like a digital antena,or a roof antena for better free air signal,cables or telicoms signals check ur boxes,push the power button OFF/ON to reboot it,to get signal back.
Apr 05, 2010 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
My tv shuts off by its self then wont restart until it is unpluged for a while then it shuts off again.
these sets are notorious for bad inverter boards and bad video processor boards.Sharp is well aware of the problem,and will fix the units if you push the issue.
Dec 26, 2007 | Sharp LC-42D64U 42 in. LCD HDTV
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
