Hi, My Ignis FLAMAX7HD A+ washer starts washing and few minutes later stops with whatever setting,beeps a symbol for water cut-off/low mains water pressure but the tap attached to the pipes is running
  • Washing Mach... Master
  • 5,323 Answers
No agitation?
first use a multi meter and check ur water pressure switch? that is what sends the machine the message to start wash cycle?
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( If No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED) another test u can do is Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well.
Or take the original hose tube and plug one end and blow into it AT the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ?
Sometimes they get busted open or a pin hole and release air causing the water switch diaphragm to not open.
Another test u can make with a multi meter is by testing the prongs individually.
# 15,16,17 (don't worry to much bout the numbers IF U GET THEM WRONG) place ur meter prongs on both out side prongs or connectors of the switch.
(where the wire plugs into) take note of wether it shows OHMS or infinity ( open or close circuit) ? Now place the meter on the left outside and the middle prong, take note agin what it shows. Now place meter prong on the right outside and the middle prong. Agin take note what reading u get. ( you should actually get a reading of infinity in 1 and a reading of continuity or ohms in the other 2? Now the tricky part. Agin place a small tube or hose into the switch and blow into it, using the meter do the same test agin on all prongs. But now keep the pressure on the switch when u blow into it, in other words use ur tongue on one end of tube to not allow air to escape. When u test it agin now one of the prongs that once read infinity should now show continuity or ohms, and 1 of the other prongs that read ohms should now read infinity or open.
If both check ok then next CHECK the motor coupler (a bad couplercan be checked by looking under the machine and taking note if there is a black residue on floor, look at coupler located between the motor and tranny, and see if it is broken up or missing any parts? Try to turn shaft by hand and notice if it does not engage tub? )
or belt if belt driven. Check for loose, broken or worn belt .
Then check the door switch with a multi meter for continuity OHMS when door closed and infinity when door is opened , and if there is a little movement on wash cycle in 1 direction only then check the cam dogs in agitator.
Also check THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS. However in G.E models the cam dogs are replaced with what is called an agitator coupler. (located at bottom of tub)
Remember to check the agitator spline as well. for worn broken teeth
By the way my advice is free cuz God is good!
Posted on Jan 13, 2017
Whirlpool WFW9050XW Washer Front Load
Disconnect your mains from the wall and clean out your filter.
Pl click if helped.
Apr 28, 2013 | Whirlpool Washing Machines
Frigidaire FDB126RBS2
Be very careful, it sounds like an electrical failure, were the machine has cut out to protect you and itself. You need an expert there and quickly. Water and electric are a bad mix and more house fires are caused by washers than most other appliances.
Sep 23, 2012 | Dishwashers
Washer fills and empties but won't wash or spin
hello,
If the motor is spinning very rapidly when it should just be tumbling then it sounds like the tacho has gone or come loose on the motor.It may well need a new motor or there could even be a fault with the main programmer
Apr 17, 2010 | Tricity Bendix AW1000W Front Load Washer
Ignis dishwasher beeps and flashes constantly
salt container is full of water
Mar 10, 2010 | Dishwashers
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
CALYSPO WASHER DIGITAL DISPLAY+ALERT BEEP
THe timer/ECU is failed. Replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 16, 2009 | Washing Machines
Kenmore Elite HE5t Washer Door is locked, Cycle didn't run, Won't power down
Click on the following link for advice on how to unlock the washer door by using the manual release.
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
Even though your washer probably isn't diaplaying any error codes (according to the symptoms you've provided), the condition still exists where you have a door lock issue. You can try unplugging the washer for about 30 minutes to see if the computer will reset. Sometimes the door lock jams for whatever reason and a manual release and/or power cut off will clear it. If for some reason, the washer still exhibits the same problem after following the advice in the link, any further repairs would be covered depending on the PURCHASE date of your washer. If you do not have a receipt, Sears will determine the date based upon the washer serial number. The serial number indicates the month and year the washer was manufactured. If you provide me with your COMPLETE model number, I can tell you if your washer would still be covered under the manufacturers warranty. I hope you find this information helpful.
Jun 16, 2008 | Washing Machines
Fisher and Paykel 6.5 smart drive washer
My F & Paykel washer did this. There was a baby sock under the wash basin. I called for repairman and he found the problem.
Jan 05, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Neptune MAH3000AWW will start to fill when start is pressed, but stops seconds later
either a faulty pressure switch / pot or faulty controller - either way you will need to call someone in.
Jul 24, 2007 | Maytag Neptune Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
