Question about Garden
How do i release the cutting blade from the driver.
My Cricut Explore Air wont cut
If your Cricut machine is not cutting all the way through your material, or is only scoring the material, choose a machine below for specific troubleshooting tips. Fortunately this issue can usually be resolved with basic troubleshooting.
correct cut settings.
  • Remove the blade housing, then remove the blade and ensure that there are not any bits of paper stuck to the blade or lodged inside the blade housing. Ensure that you replace the blade housing correctly into the machine. Once clean, test your cuts again. If the blade and housing are already free from debris, or cleaning it did not help, proceed to 3.
  • Try an arm buoyancy test: gently press down on the black arms that surround the blade housing and then release them. Do they bounce right back up, or do they stick or rub in any way? If they stick or rub, please contact Customer Care through one of the options below for further assistance. If they bounce right back up when released, proceed to 4.
  • Increase the machine pressure settings and try your cuts again. If this does not change the cut result, proceed to 5.
  • Increase blade depth by turning the dial at the top of the blade housing. If this does not change the cut result, proceed to 6.
  • Perform a Hard Reset on the machine. If this does not help, proceed to 7.
  • Check your machine's firmware version. If the firmware is not up to date, perform a Firmware Update using Cricut Craft Room, a Gypsy device, or Cricut Design Studio.
  • Retry your cuts with a new blade housing.
  • If the machine is still not cutting through materials, or is only scoring the paper, please contact Customer Care through one of the options below for further assistance.
  • Forced Firmware Update on the machine through Cricut Sync.
  • Retry your cuts with a new blade housing. If the issue persists, proceed to 8.
  • Attempt a Format and Restore on the machine through Cricut Sync. Please note that this step should only be taken if all other steps have failed to resolve the issue.
  • If this does not resolve the issue, please contact Customer Care through one of the options below for assistance.
  • new blade. If this does not help, proceed to 5.
  • Adjust/increase the Multi-Cut setting in the Cricut Craft Room cut preview screen and retry your cuts. If this does not change the cut result, proceed to 6.
  • Retry a cut using a new blade housing.
  • If the machine is still only scoring or not cutting through the material, please contact Customer Care through one of the options below for assistance.
  • Jan 16, 2017 | Crafts & Hobbies
    Rger Elna 614de the button on the side w ill not bring up the upper blade from down position?
    it's possible that there need to be a adjustment to the serger or there could be a damaged or broken part in it, having it checked would be a good idea
    Mar 27, 2015 | Elna Sewing Machines
    How can I do adjustment of cutting width elna overlock machine
    to change how much fabric is cut you need to move the cutting blade either left or right, this overlocker is one of the first so I think this process was pretty manual, ie using a screw driver to release and reposition the right hand blade.
    it may be worthwhile buying a manual for this while you still can get them, this model was released back in 1987 in UK. Instruction Manual Elna L1 Serger
    Feb 27, 2015 | Elna Sewing Machines
    Band saw cutting problems
    Make sure that the blade is properly tracked and tensioned, installed. Hope this blog will help you too. http://bandsawblog.com/variable-pitch-band-saw-blades-when-is-it-used/ . Variable pitch blade is a tooth design that combines more than one tooth pitch to reduce chatter and vibration .
    Feb 15, 2013 | Saws
    Milwaukee sawzall blade
    Cut or snap the blade off at the end so you can get the holder apart. I have had to do this before. Usually you can just use a set of pliers and work the blade back and forth until it snaps off but I just use an air powered cut-off tool and cut them.
    Aug 05, 2012 | Milwaukee tools Milwaukee 6509-22...
    Changed cutting blade now blade will not stay stable in position to cut
    did you get the cutter release knob back in the right place or position?
    is the horseshaped bracket damaged in any way?
    Mar 07, 2012 | White Sewing Superlock 1934D Mechanical...
    Will not cut 45 miter cuts perfect
    Possible but I would think not likely
    Try this
    Put a new blade on
    Set a magnet on the table or fence with phillips screw driver stuck to it
    Slide the point of the screw driver up to within 1/16" from the blade just above the teeth
    Run the unplugged saw by hand and watch for any side to side movement of the blade
    Can you move the blade up and down or side to side?
    If everything seems normal the plug the saw in and run it again watching the screwdriver
    Please be careful don't allow the screw driver to contact the blade at high speed you will create a bullet
    Mar 10, 2010 | Porter Cable Cable 12" Compound Laser...
    Trimer buing Question
    Double position trimmers For extended reach while on the ground, a double position trimmer avoids you having to climb up high by allowing you to adjust the handle into a right angle to the blades for a level cut across the top of the hedge. Clippings collector As you trim your hedge, collect those stray cuttings in a clippings collector for a neater finish. Automatic cut out An important safety feature, this automatically switches off the hedge trimmer once the trigger is released. Hand guard For reassuring safety, a hand guard will protect you from the moving blades and from falling cuttings as you work.
    Aug 27, 2008 | Corona Hedge Shear 10 1/2" Blade Aluminum...
    Grinder question
    Use a pencil and straight edge to mark the cutting line on the wood. Place the wood on the saw table and line the mark up with the saw. Place the mark on the right side of the blade to ensure proper cutting. Plug the saw in and put on your safety goggles. Support the wood on the work surface with your left hand, placing it far from the saw blade. Place your right hand on the handle, and push the trigger to start the saw. Move the saw blade down onto the wood. Put constant pressure on the handle to slowly move the blade through the wood. Release the trigger and raise the blade once the cut is complete. Make diagonal cuts in the same manner, by marking the wood and lining the mark up just to the right of the saw blade. Continue as you would for a straight cut. Remove the wood from the saw. Unplug the chop saw and dust the sawdust off. Remove the dust bag from the back and empty it. Vacuum any remaining dust off of the saw.
    Aug 27, 2008 | Dremel 10 Diamond Cut-Off Wheels Saw Disc...
    Garden Logo
    26 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
