Question about Ovens
How do I connect the Defy 600s oven to the 220v main power supply? I gather that the hob get its supply via the oven unit since I don't see any possible power connector plugs?
2 Suggested Answers
SOURCE: I have a new Defy
I have the same predicament. Did you manage to connect your new hob to your old stove? If so, please let us know how to do it.
Posted on Aug 25, 2011
NEFF B4562 Oven LED display just stopped working during use yesterday. Oven still works but have to guess what programme I am using. any ideas on fixing it without the Neff 100pounds call out fee and...
Preparing the units - Fig. 1
? The safe operation of this appliance can only be guaranteed if
it has been installed to a professional standard in accordance
with these installation instructions. The installer is liable for
damage incurred as a result of incorrect installation.
? Fitted units must be heat-resistant up to 90 °C, and
neighbouring unit fronts up to 70 °C.
? Cut-out work on the units and worktop should be performed
before fitting the appliances. Remove any shavings or the
function of the electrical components may be impaired.
? Caution during installation. Parts that are accessible during
installation may have sharp edges. Wear protective gloves to
prevent cuts
? The power socket for the appliance must either be located in
the hatched area B or else away from the installation space.
? A gap of 5 mm is required between the appliance and
surrounding unit fronts.
? Secure freestanding units to the wall using a standard bracket
Appliance under the worktop - Fig. 1
There must be a ventilation cut-out made in the intermediate
floor of the surround unit.
Secure the worktop to the fitted units.
If a fitted oven is to be built in under a hob, pay attention to the
hob installation instructions.
Appliance in a tall unit - Fig. 2
The appliance may also be installed in a tall unit.
There must be a gap between the intermediate floors and the
mounting wall of approx. 20 mm in order to provide ventilation
to the oven.
Only fit the appliance at a height where removing baking trays
does not present a problem.
Corner installation ­ Fig. 3
To ensure that the appliance door can be opened in the case of
corner installation, take account of dimension D. Dimension E is
dependent on the thickness of the unit front under the handle.
Connecting the appliance to the power supply
Only allow a licenced professional to connect the appliance.
National regulations apply as well as those of the local electricity
The appliance must be disconnected from the power supply for
all installation work.
The appliance corresponds to protection class I and may only
be operated with a protective earth connection.
Power cord: Type H05 VV­F or higher rated. The yellow/green
wire for the PE connection must be 10 mm longer than the other
wires on the appliance side.
During installation, an all-pole isolating switch with a contact gap
of at least 3 mm must be present, or the appliance must be
connected via a three-pin earthed plug. This must be accessible
after installation.
Contact protection must be ensured by the installation.
Identify the phase and neutral conductors in the socket.
Incorrect connection may cause damage to the appliance.
Only connect as per the connection diagram. See the rating
plate for the voltage.
Position the appliance in front of the units in readiness for
connection. The connecting cable must be sufficiently long.
Securing the appliance ­ Fig. 4
? Fully insert the appliance and centre it.
? Screw the appliance into place.
? The gap between the worktop and the appliance must not be
closed by additional battens.
Disconnect the appliance from the power supply. Undo the
securing screws. Raise the appliance slightly and pull it out
the only contact info that I found is the info below:
Dec 08, 2014 | Neff Ovens
Frigidaire wall oven
Does the unit have enough power to run (220V), also above you only mentioned convection? So is this the only cycle you have issues with? So, bake and broil work fine? The reasons for the question are they function work together for preheat. If all you elements are having issue, then check source of power to element and relay power up at board for the issue. Did this issue start after a cycle (self clean)? Check breaker for 220V, check supply to oven 220V, check power from relay / clock for 220V. If all this is good, check the elements for 220V (use caution when doing this). Get me more information and we can solve this, I seek to locate the problem by looking for power or lack of.
I am under the assumption you understand electricity and how to work with it. If not, please seek a service person to preform these tests or repair.
Look forward in hearing back from you on the progress.
Dec 16, 2013 | Ovens
U1442 main oven not heating
If you are sure there is 220v going to unit, it most likely is element or click / control. If you have a ohms meter, you can test the element
Sep 07, 2017 | Neff U1721 Double circotherm Electric Oven
How to connect the defy 600u stove to the main power supply
how to connect defy 600 su on single phase
Jun 25, 2011 | Ovens
Hob is tripping fuse box
If the hob is tripping the RCB or MCB on the consumer unit, there is a fault, usually in the elements or halogon heaters, you will need a multimeter to define but please ISOLATE FROM MAINS POWER BEFORE OPENING ANY PANEL
Some electrical knowledge would be helpful, check each element seperatly, you may have to carefuly disconect each heater on the hob, unless you know which blows the mcb, check all connectings to see thay are secure, work round the hab reostates, make sure there is no shorts to ground from elements, with temp control down at zero. Check wiring into mains as a loose connection will cause heat and mcb to trip.
If it is wired into the same outlet as an oven disconnect oven in case the other appliance is causing the problem. it is realy a question of eliminating causes one at a time, working round the affending appliance to define what is the cause.
Hope this is helpful
Jun 06, 2011 | Ovens
Looking for electric wiring for a defy slimline 600s oven
Gert, dont know if this is too late but I found it on - left hand column towards the bottom under wiring diagrams
Apr 06, 2011 | Ovens
I have a new Defy hob with the colour connections in 4's, but my oven is an older DEFY and has two rows of 6 connectors... please help. How do I connect a new DEFY hob to an old Defy oven?
Mar 04, 2011 | Ovens
I have replaced a Kelvinator hob with a ceramic hob. It works but the owen is not working. What is the problem?
There are possibly a number of options. It could be that in wiring the hob in you have disturbed the wiring for the oven. Normally the oven works off the main oven control switch on the panel and the hob could be wired into something else.
Is the oven totally dead no power at all for everything, or is the clock running but the oven will not switch on?
Dec 29, 2009 | Stoves 720EF Electric Double Oven
Pilot not sparking , where is the pilot light
That all depends on the make and model of cooker.
On many models it's a single 1.5v AA battery and is somewhere under the lower front edge of the unit. If it's a cooker/range you can access it by pulling the cooker forward, tipping it back and supporting it. Built in ovens (and hobs) usually have mains-power and supply the igniter circuit via a transformer, but on the few built in ovens without mains power the battery is usually at the bottom of the unit close to the front. Depending on the design either the entire oven has to be partially withdrawn from the housing or there is often a removable air inlet panel or grille with the battery holder just behind.
Note that because of the location, the battery holder can be hard to find due to being encased in the inevitable gunge and muck which builds up in these areas, so you may want to allow extra time to clean most of this off.
Oct 13, 2009 | Ovens
Ovens Logo
47 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
